Results 1 to 6 of 6
Reload Thread: Soundqubed HDC3 12" in 33hz box
    Curtonamis's Avatar
    Curtonamis is offline Junior Member
    May 2013
    Wichita, Kansas
    29
    7 Post(s)
    I got an alpine type r 12 and an amazing box made from Starr Mountain Sound, I was flexing windows of a local business with just one 12 on less then 1000 watts. But I want to be able to safely stay that louder then 1500 now so I want to get an HDC3 12 and just put it in the box I have considering I just recently got it a few weeks ago. It is tuned to 33hz and 2cu feet. 32x15x14 I think it was, but I could be off. I want to run around 1500+watts daily to it.
    phemps's Avatar
    phemps is offline CarAudio.com Veteran
    May 2009
    PA
    2,023
    284 Post(s)
    Re: Soundqubed HDC3 12" in 33hz box
    Im not sure if the hdc3 has changed at all since AQ changed to SQ, but i dont think i would throw one in a box tuned quite that low they dont like it too much
    Refs: Rio, DbzArson, goodstuff, Worstenemy453
    Quote Originally Posted by Altec View Post
    Then obviously I am asking the wrong person, because you don't know how to hook up subs if they sounded like "****". Maybe learn your ohms and your diagrams before you call something ****. Learn to make boxes to specs and use the right wires and its called dynomat. Then maybe your car wouldn't of sounded like ****, yeah?
    Curtonamis's Avatar
    May 2013
    Wichita, Kansas
    29
    7 Post(s)
    I read online that this person put his in a small box tuned to 30 hz and it slapped hard so I'm debating cause I have heard different things
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by phemps View Post
    Im tuned at 32 with my hdc4.s and rhey have a fs of 41 lot higher than the hdc3 ..thy murder the lows ...in thing is that box isnt big enough and probably doesnt have enough port to suite a hdc3
    ---------- Post added at 07:13 AM ---------- Previous post was at 07:12 AM ----------
    They like big boxes with lots of port ..period...will it function in that box yes will it be all that it can be ..far from it
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,760
    5 Post(s)
    1263 Post(s)
    How much port area per cube? As far as tuning you could cut the port shorter to raise tuning a few hz and gain some box volume...
    phemps's Avatar
    May 2009
    PA
    2,023
    284 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Ive had both and the hdc3 actually did get down when it broke in but I still tuned at 37 or higher or believe. I have a couple hdc4 18s that im trying to get rid of, never tried tuning too low and honestly id be scared to theyre still stiffer than chit
  1. Memphis 12's in ported box problem
    By david01_69 in forum Subwoofers
    Last Post: 07-29-2003, 08:54 PM
  2. One Audiobahn 12" Flame in WHAT BOX?
    By jcavz24x in forum Subwoofers
    Last Post: 12-20-2002, 07:25 PM
  3. can i fit a 12" sub in a box only 12" wide??? i need a cut out of 11 1/8"
    By Jeff22 in forum Enclosure Design & Construction Help
    Last Post: 11-25-2002, 09:45 PM
