Results 1 to 4 of 4
Reload Thread: new sub box---sealing question
    audiotaylor's Avatar
    audiotaylor is offline Member
    Apr 2002
    Fullerton Ca
    28
    43
    I just installed a custom made sub box in my chevy s-10 ext. cab and am going to seal and add carpet it this week. But before I do that, Do I need to put silicone around the joints inside the box? I did use carpenters glue when I built it along with like a million wood screws so it should be sealed just from the glue right? Thanks for the help.
    -David
    Just because I don't say it, don't mean I aint thinkin it.
    imral3's Avatar
    imral3 is offline Sponge Bob Rules !!!!!
    Jan 2002
    NJ
    45
    526
    you definately want to seal the inside joints of the box!
    good luck and good listening!
    L8r
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Yep like he said I would still use a silicon sealant on the inside seams. The glue holds the wood together. But silicon will seal it alot better.
    5 % equipment
    90 % install
    5% beer
    Apr 2002
    Fullerton Ca
    28
    43
    Thanks. Better now than after I had covered the mounting brackets. Ill seal it today.
    -David
