Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: IB woofers water enclosure?
  1. #16
    chefzane's Avatar
    chefzane is offline Senior VIP Member
    May 2013
    Tulsa. Oklahoma
    451
    24
    152 Post(s)
    Re: IB woofers water enclosure?
    Stupid question alert!!!!!!!
    Has anyone ever tried pressurizing or creating a slight vacuum in a box to see if output changes or this plus diff gas?
    Coming soon
  2. #17
    VWBobby's Avatar
    VWBobby is offline PG and SS nuthugger
    Jul 2010
    Nibiru
    35
    1,377
    170 Post(s)
    I would think that a lighter gas, or less dense gas would have a cushioning effect. It would be similar to polyfill in a box, "tricking" the sub into acting like its in a larger box. A vacuum might have the same effect.
    Water would displace the air and reduce the box volume, no? I agree that the sonic transfer abilities of water might make for an interesting effect.... Maybe a worble sound or vibrato?
    It would be easy enough to coat the inside of a box with undercoating, bedliner, or fiberglass resin to waterproof it. Mount the sub inverted and your test could be performed in a few hours.
    '65 VW Bus
    MA Hippo 122, (2) Aura Sound 8's, (2) SoundStream 6.5 coax, (2) Alpine Type-S 6x9's [rear fill], MBQ DSC1500.1D, RF 501X
    '12 Nissan Altima - Bone Stock - Sounds good, but adding subs soon.
    '02 BMW 330xi (AWD coupe), every option - SOLD
  3. #18
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    This has actually been done. The sub doesn't care what gas is behind it, all the sealed part does is act as an cushion for the woofer. A lighter less dense gas makes the sub behave as if it was in a larger airspace, at least vs the same volume of normal air. Fluids would have the opposite effect, so that would be useless. Also realize your cone isn't airproof and you'd have to refill it.
    SPL competitors could, or maybe even have tried to cheat using gases. If you fill the cabin of your car with a gas that is more dense than normal air, you'll increase the cabin pressure leading to a higher SPL measurement. For a "sealed on the dash" type of run this could be an effective cheat. I know I've heard of people running their AC's to make the car colder, which also makes more dense air, but you could really take it to another level with a different gas lol.
    There are a few AES papers with patents on this. They also use gases that are not only lighter than air, but gases that cool down when compressed, which is the opposite of most. This means that when the sub pushes inward, instead of having increasing pressure, the pressure actually remains fairly constant since the dropping temperature DECREASES the pressure and the sub moving inward increased it. That makes the box seem much larger than it is and there no change in compliance over stroke, sorta like an IB box, but you can make the overall Q anything you want, instead of just the woofers Q.. Kinda cool.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  4. #19
    chefzane's Avatar
    May 2013
    Tulsa. Oklahoma
    451
    24
    152 Post(s)
    Someone needs to do this to get it outta my mind
    Coming soon
  5. #20
    Oraclem19's Avatar
    Oraclem19 is offline Senior VIP Member
    Mar 2013
    United States
    177
    74 Post(s)
    Quote Originally Posted by Oraclem19 View Post
    just now realized this was my thread.
    Actual reasoning behind this was to ask if the front of a woofer is waterproof give it is not a paper/pulp cone. Marine applications and such, given that the back of the woofer would not be exposed to any water.
    NOW THAT WE'VE SOLVED IF I CAN HINDENBURG A WOOFER
    Anyone with any ideas on this? Is it possible to spray a woofer with cleaner without damaging anything? Would some water exposure destroy a woofer?
  1. WTB/WTTF 8"s or 6.5" IB woofers
    By budahbuddy803 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 12-15-2008, 11:33 AM
  2. need help with IB woofer please
    By flomofo in forum Subwoofers
    Last Post: 05-01-2008, 07:31 AM
  3. IB or small enclosure??
    By msrpIZtooMUCH in forum Speakers
    Last Post: 05-06-2007, 02:21 AM
  4. Sub Woofer Enclosure
    By knight007 in forum General Discussion
    Last Post: 06-30-2004, 11:17 AM
  5. Replies: 4
    Last Post: 03-17-2002, 03:32 PM
