Results 1 to 2 of 2
Reload Thread: Which option?
    Komsan6063's Avatar
    Komsan6063 is offline Junior Member
    May 2012
    Florida
    25
    8 Post(s)
    Which option?
    Ok so basically one of my subs blew on my average *** system so i was thinking about replacing it. My options as of now are 2 Fi Bl 12s fully loaded in a sealed box or 1 Fi sp4 15 inch sub fully loaded in a ported box. here are the stats for both the subs. Basically im looking for something that will shake the **** out of my car. I typically listen to trap music, some dub step, and a bit of house. I want what is best for that shaking and the one that is most durable and will take the most beating. Thanks!
    SP4 Series: Currently in 15 and 18
    Dual 1 and Dual 2 Ohm (custom options available)
    Extra heavy aluminum basket
    Wrap around gasket
    Kraft pulp fiber reinforced cone
    Single layer wide foam surround
    Push terminals
    144 tinsel count leads
    FEA optimized motor
    High Flux density design
    4 diameter 4 layer coil (Flatwind standard)
    Double stack magnets
    Five progressive 10" spiders
    Optional Heli-cool systerm
    Machined in house at Fi
    And many other custom options
    SP415
    DUAL 1 | DUAL 2
    Fs: 27.6 Hz | 27.9 Hz
    Re: 0.65 Ohms/coil | 1.27 Ohms/coil
    Qms: 6.56 | 6.45
    Qes: .52 | .52
    Qts: .48 | .48
    Mms: 434g | 424g
    Cms: 0.77mm/N | 0.77mm/N
    Sd: 810cm^2 | 810cm^2
    Vas: 70.4 l | 70.4 l
    Spl: 86.4dB 1W/1m | 86.5dB 1W/1m
    Bl: 13.7 N/A | 19.1 N/A
    Xmax: 33mm | 33mm
    Rms: 3000W | 3000W
    Sealed box: 2-3.5cuft | 2-3.5 cuft
    Ported box: 3-5cuft | 3-5cuft
    Sub OD: 15.625 | 15.625
    Cut ID: 14.125 | 14.125
    Mounting depth: 11.250 | 11.250
    Displacement: 0.21cuft | 0.21cuft
    BL Series: 10, 12, 15, and 18
    Cast basket
    Wrap around gasket
    Push terminals
    16 integrated leads
    FEA optimized motor
    3 diameter 4 layer coil (Flatwind option)
    Five progressive spiders
    BL12
    DUAL 1 | DUAL 2
    Fs: 35.2 Hz | 39.8 Hz
    Re: 0.7 Ohms/coil | 1.4 Ohms/coil
    Qms: 4.68 | 4.72
    Qes: .25 | .25
    Qts: .24 | .24
    Mms: 212g | 212g
    Cms: 0.96mm/N | 0.96mm/N
    Sd: 480cm^2 | 480cm^2
    Vas: 31.2 l | 31.2 l
    Spl: 89.1dB 1W/1m | 89.1dB 1W/1m
    Bl: 16.6 N/A | 22.7 N/A
    Xmax: 18mm | 18mm
    Rms: 1500W * | 1500W *
    Sealed box: N/A cuft | N/A cuft
    Ported box: 1.5-2.5cuft | 1.5-2.5cuft
    Sub OD: 12.500 | 12.500
    Cut ID: 11.125 | 11.125
    Mounting depth: 6.750 | 6.750
    Displacement: 0.18cuft | 0.18cuft
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: Which option?
    well no sealed then , go ported you'll get what your looking for then
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  1. which option would you go with?
    By playyamxz550 in forum General Discussion
    Last Post: 06-25-2011, 12:22 AM
  2. which option would you go with?
    By TC2k15x2 in forum General Discussion
    Last Post: 12-29-2009, 01:06 AM
  3. which option is better
    By nismboy6986 in forum Head Units
    Last Post: 07-21-2008, 10:16 PM
  4. Replies: 13
    Last Post: 09-06-2006, 10:49 PM
  5. Which option woud you recommend?
    By Terminator in forum General Discussion
    Last Post: 06-10-2003, 07:53 AM
Tags for this Thread
