Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Reload Thread: DD subs are peaky and don't get low?
  1. #16
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,198
    110 Post(s)
    7816 Post(s)
    Re: DD subs are peaky and don't get low?
    Quote Originally Posted by SPLaudio View Post
    27-45hz within a db that is not peaky at all thats great!
    ---------- Post added at 12:15 PM ---------- Previous post was at 12:14 PM ----------
    that is deff a music box
    We all where a bit surprised.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  2. #17
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,188
    15
    38 Post(s)
    4190 Post(s)
    Quote Originally Posted by DDtC View Post
    A freind is running a "DD box" doing a 149.9 with a single 9518 on 2400 rated watts on basically stock electrical. It may not work for every install but its working for his.
    The "DD Box" is very similar to the Shocker box that's been used with good success since '02. Large box tuned in the low 40's will get loud with that type of sub.
    I'll call it musical when I see the numbers up to 70hz. Linear over a 17hz bandwidth isn't really that impressive, and personally I find a box that rolls off above 45hz sounds awful for music to which I like to listen.
  3. #18
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,198
    110 Post(s)
    7816 Post(s)
    Quote Originally Posted by hispls View Post
    I got the mid bass to cover 60 up. The 8s put a little tickle through the seats.
    JBL MS-8
    Hertz HV165XL
  4. #19
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,604
    43 Post(s)
    1435 Post(s)
    Over priced cookie cutter subs.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  5. #20
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,198
    110 Post(s)
    7816 Post(s)
    Quote Originally Posted by whitedragon551 View Post
    Your subs not cookie cutter? Please enlighten me.
    I don't think this combo of basket and soft parts are shared with anyone else. And the motor is unique. Sounds cookie cutter
    JBL MS-8
    Hertz HV165XL
  6. #21
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,198
    110 Post(s)
    7816 Post(s)
    JBL MS-8
    Hertz HV165XL
  7. #22
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,621
    8 Post(s)
    722 Post(s)
    hispls, the dbs so close in that freq is good.
    my spl box is peaks at 52hz, at 58hz it drops 3+ dbs and 47hz it drops 3dbs. spl boxes generally have a nasty peak but its what u want...
  8. #23
    SPLaudio's Avatar
    Feb 2009
    upstate ny
    6,621
    8 Post(s)
    722 Post(s)
  9. #24
    hispls's Avatar
    Sep 2009
    10,188
    15
    38 Post(s)
    4190 Post(s)
    Post your SPL numbers from 45 up and let's see what it looks like then
    This isn't an spl box. This is a "prove how low DD can play" box. You won't convince me that flat over 17hz bandwidth is some kind of accomplishment or testament to the SQ of something.
    Not even knocking the equipment, but seriously, DD's design philosophy has always been (according to their website) buid a sub that works well in a particular box.
  10. #25
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,198
    110 Post(s)
    7816 Post(s)
    Didnt run them that high but there is a bit of output. Deff hard drop off at 50hz plus but what do you expect tunning that low. Show me a sub that will play the entire sub freq flat in a ported setup. One that will play down to 25 up to 80 well
    JBL MS-8
    Hertz HV165XL
  11. #26
    IonRL205's Avatar
    IonRL205 is offline DJ h4z4rdes
    Sep 2008
    Abilene, Texas
    2,449
    946 Post(s)
    I need to get my setup metered
    Mine sounds flat from 23 hz up to about 50 or so
    I don't play music much higher than that, and if I do, it's loud enough for me where it's at.
    Headunit - Pioneer DEH-P8300UB
    Subs - None
    Sub Amp - 2x Crescendo 3kwp
    Front Stage - Polk Audio db651 Coaxial
    Front Amp - None
    Quote Originally Posted by zako View Post
    Most properly done 15 inch subwoofers are not suited for car audio use simply due to box size requirements.
  12. #27
    hispls's Avatar
    Sep 2009
    10,188
    15
    38 Post(s)
    4190 Post(s)
    Not really my scene, but I'm confident that if you asked the question of what sub can do that on a different forum somebody will have some suggestions from personal experience. The ones I've played with that I suspect could do it I never owned a meter when I owned them so I can't much comment. The point is, graph the whole thing from 20-80 and post the response on a home theater site or DIYMA and ask them if the response looks peaky.
    It's cool though, those are great numbers at those frequencies and if your goal is only to play up to 45hz I'd say you nailed it, but let's not sit around pretending that's a flat response. Build the DD spec box and see what that meter tells you, I'd wager the results will be very respectable.
  13. #28
    Ray21's Avatar
    Ray21 is offline CarAudio.com Elite
    Aug 2004
    The Rock
    786
    8 Post(s)
    In addition to the sub itself, response is dependent on the enclosure AND the vehicle.
    From what I can tell, the high qts of the 1500 and 2500 lines will most likely result in a peaky response. The 9512i the OP is running has more of a chance at yielding a flatter response with its specs.
    And flat is not necessarily a good thing for everyone. I prefer a rising response below 80 hz to about 30hz.
    '10 F150 - 3Sixty.2 / MTX 2150x / MTX 275x / Blueprint XBL^2 Subs/ Boston SL80
    REFs: flakko, Naxis2k1, JCJetta, jrgreene1968, NoPh33rRaCiNg, VTECnicalAccord, jadon087, sundownz, lmllopez, Toxic Tuan
  14. #29
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    43
    11,125
    20 Post(s)
    1237 Post(s)
    Quote Originally Posted by Ray21 View Post
    I prefer the same tilt, louder to the ear as it dips lower and lower.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  15. Likes Ray21 liked this post
  16. #30
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    I can show you LOTS. Anything with a well designed shorting ring should be able to do it. Only reason many "high end" car audio woofers can't is because of what car audio guys consider "high end' (notice I keep putting quotes lol) subs to be like. They use super stiff suspensions that lower effeciency and cause lots of mechanical noise, massive motors and coils, but use no faraday rings to control inductance. This leads to MASSIVE drop off above 60 which leads to them being useless for music.
    My last subs were AV15h's. They use faraday rings to control inductance to VERY low levels. If they used a paper cone and not metal, they could easily play up to 2000hz without issue. Metal cone limits them to 500ish before cone breakup. Regardless , I was tuned at 25hz I used them crossed over at [email protected]/octave. Any higher and the trunk began to muffle the output too much. They were playing over 2 octaves of music and while I never metered it, to the ear, it was fairly flat and very musical. You could feel your clothes moving a bit on 60hz kick drum notes and using tones their was FAR more output capability than you'd ever get from a "midbass" from 60-100hz, 80hz modulated your voice when speaking.... Just had to cut at 40-50hz a tad due to cabin gain. My preference for frequency response is similar to the few above.. I like flat to the ear from 80-40 with a rising response below that, can't have too much low low's lol. Really in a car though that's what you want. Flat on a RTA has nothing to do with sounding good, when your talking about anything below 200hz or anything above 4000hz. Beyond that most people prefer a sloping response and it sounds more realistic, especially in a small environment.
    Without at least 120db's of midbass output your not going to sound remotely close to flat on music doing a mid/low 140. My next setup will be 2 21's. B&Cs 21's. They use a 6" voice coil, have a conservative power handling of 2k a piece AND can easily play up into the midbass region with 97db/1w/1m of output.. Easily capable of 130-140db of mid bass as a pair of them, and probably nearing a 150 from 30-60hz on music, probably even larger range in a 6th order. Point is, you CAN be loud full range, just takes a different type of beast than most car audio subs. I know sundown has started using faraday rings, but the last few subs still haven't made it above 60hz very well yet, IIRC.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  17. Thanks hispls thanked for this post
    Likes ciaonzo liked this post
  1. Replies: 9
    Last Post: 08-06-2010, 08:25 PM
  2. Which Subs are better and have better spl?
    By AlpineUser in forum Subwoofers
    Last Post: 03-14-2006, 03:57 PM
  3. Keep HCCAs or Get DD Subs
    By james33440 in forum Subwoofers
    Last Post: 11-13-2002, 12:55 PM
  4. Keep HCCAs or Get DD Subs
    Last Post: 11-13-2002, 03:09 AM
