+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 47
Reload Thread: Subs keep blowing.
  1. #16
    blobb454's Avatar
    blobb454 is offline CarAudio.com Elite
    Nov 2012
    LANSING MI
    980
    7 Post(s)
    Re: Subs keep blowing.
    Quote Originally Posted by hispls View Post
    I suspect they are blowing because they are complete garbage and the amp isn't far behind. Like buying a pair of 40$ work boots. You'll go through 8 pair of them before I wear out my 200$ pair.
    There is nothing you or we can do to make that amp put out anything close to clean and rated power, and even assuming you give the subs clean power they likely have about a 30% failure rate right out of the box.
    Hate to agree cause its kinda harsh but... Agree with this. Change out your amp.
    Quote Originally Posted by kpetree View Post
    I feel like you're a waste of your mothers stretch marks, better luck finding your gf next season. Fck off, post dump somewhere else.
  2. #17
    Beatin''s Avatar
    Beatin' is offline Senior VIP Member
    Nov 2012
    MI
    373
    1 Post(s)
    throw everything in the garbage and start over.
    1500wrms on 70A fuse, man I hate these lying ass companies.
    and people dog on me when I mention cea compliancy.....
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  3. #18
    jcrom95's Avatar
    jcrom95 is offline Junior Member
    Mar 2013
    Willowick
    All my speaker wire is 16 gauge and the attatchment shows how i have my subs setupSubs keep blowing.-untitled.jpg
  4. #19
    DDtC's Avatar
    DDtC is online now Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    6,110
    44 Post(s)
    Quote Originally Posted by jcrom95 View Post
    All my speaker wire is 16 gauge and the attatchment shows how i have my subs setupAttachment 26540429
    Have you read any of the post? Start buy setting the gains correct, there is a sticky in the amp section. You are going to be very disapointed.
    Dont set it to the 1500 is says it does. Set it to the 700 it might do
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
  5. #20
    SPLaudio's Avatar
    SPLaudio is online now CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,280
    246 Post(s)
    i will bet its wired to 1ohm being that turning the gain up more it goes into protect.
    its not a sub prob its a amp prob...
  6. Likes wickedwitt liked this post
  7. #21
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    Quote Originally Posted by MOFOMAN View Post
    WHAT!? Subs aren't picky about what load is going through them. The wiring resistance of them determines the load the amp sees. If he has them wired wrong he may be putting out a load the amp doesn't like, but the coil of the sub only cares about how much wattage it is seeing.
    Stupid Loud.
  8. #22
    gettinlouder's Avatar
    gettinlouder is offline Junior Member
    Jan 2012
    trenton, michigan
    14
    yea hate to say it but everyone iv known to by boss learned quick, i mean comon you can get a so called amp rated for 5000 watts which i would doubt it puts out half that for a 100 bucks somethings not right. and i would almost guarntee the subs cant handle the rated power.not trying to hate but you live and learn.i would try and sell them for what ever you can get.and normally i would say check reviews but iv seen thiers and whoever bought it and said great buy is fuc***g retarted.and yes subs are not pickey on ohm load amps are check your wiring again and then double check,i really dont see your amp going into protect from an 8ohm load but if its is in one ohm probably.and also what size wiring do you have.
  9. #23
    MOFOMAN's Avatar
    MOFOMAN is offline Senior VIP Member
    Jan 2013
    Michigan
    150
    Quote Originally Posted by wickedwitt View Post
    im talkin about this sub not subs in general.. iv actually done a fair amount of research on these an everyone says they destroy themselves running at 1ohm
  10. #24
    wickedwitt's Avatar
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    Heat or exceeding mechanical limits are the only reasons a sub will blow. Impedance has 0 to do with it. All these subs were either being over-powered/clipped or bottomed out.
    Stupid Loud.
  11. #25
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    6,110
    44 Post(s)
    You must of been reading reviews on Sonic Electronixs website.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
  12. #26
    TexasThump's Avatar
    TexasThump is offline Junior Member
    Mar 2013
    Enid, OK
    27
    24
    Subs can't handle a 1 ohm load? What are you talking about? Didn't know subs were dependent on the impedance on what they can "handle"
    2004 Nissan Armada SE 4x4
    5.6l 305hp/385ft lbs torque, Tow Package, Auto-Air Rear Leveling, Leather, Sunroof
    JVC KW-NT8000HDT, DVD Player in center console, Dual Headrest Monitors, FOUR Sundown Audio SA-8 V.2 Upgraded Stock SPL Versions, 2 Audiopipe AP18001D's, Focal Utopia 6.5" Components, Focal K2P 6.5" Components, Audiopipe AQX360.4, XS D3400 AGM Battery, Cadence Cool Wire OFC 1/0awg wiring
  13. #27
    TexasThump's Avatar
    Mar 2013
    Enid, OK
    27
    24
    Quote Originally Posted by DCtC View Post
    I don't understand what you mean by this post.
    Quote Originally Posted by gettinlouder View Post
    Wow. I had to read that like 3 times just to understand what you were saying. Try using the spacebar, correct punctuation and capitalize the first letter of a sentence.
  14. #28
    Better-Action's Avatar
    Better-Action is offline Senior VIP Member
    Sep 2012
    SD
    376
    4 Post(s)
    He's saying read the guide on how to set your amp. Part of the process is knowing how much power your amp puts out in rms power. That amp claims to put out 1500 rms, it actually puts out half of that probably. So in the gain set process, you would set it using 500-700 wrms because that's all that turd can do.
    Bought from Underfire, Stephens30228.
  15. #29
    MOFOMAN's Avatar
    Jan 2013
    Michigan
    150
    again im sayin from what iv heard from at least 5 people say "these" subs even at lower power fail at 1ohm
  16. Dislikes Chriszle disliked this post
  17. #30
    Sep 2012
    SD
    376
    4 Post(s)
    No.... no you didn't. That doesn't even make the littlest bit of sense, and the odds that 5 different people told you that is astronomical.
    You made that **** up didn't you?
  18. Thanks brooklynjoy2008 thanked for this post
+ Reply to Thread
  1. wires on my subs keep blowing off?
    By will240 in forum Wiring, Electrical and Installation Help
    Last Post: 06-01-2007, 01:41 PM
  2. why does my sub keep blowing
    By DL97 in forum Subwoofers
    Last Post: 03-26-2007, 11:54 AM
  3. why does my sub keep blowing
    By DL97 in forum General Discussion
    Last Post: 03-26-2007, 09:58 AM
  4. My Sub amp keeps blowing fuses???
    By LowRydr in forum General Discussion
    Last Post: 03-05-2004, 02:07 PM
  5. Replies: 9
    Last Post: 12-31-2002, 04:37 PM
