Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: What gets louder a Fi Q or a Fi BL?
    acura3.2tl's Avatar
    acura3.2tl is offline Member
    Sep 2012
    CO
    112
    32 Post(s)
    I was wondering what will get louder using a 1500 watt amp, an 18" Fi Q or a Fi BL 18". And what are all the options for these subs? Which ones are necessary? Heres a link to all the options you can choose from: BL18 - Fi Car Audio Store
    And the Q's options: Q18 - Fi Car Audio Store
    Chriszle's Avatar
    Chriszle is offline CarAudio.com Elite
    Jan 2011
    SD
    1,718
    373 Post(s)
    Re: What gets louder a Fi Q or a Fi BL?
    Either will work on that power. How well they will perform will depend on the box.
    Boomsday's Avatar
    Boomsday is offline CarAudio.com Veteran
    Apr 2010
    My House
    3,885
    62 Post(s)
    785 Post(s)
    I had both, and imho the Q is the better overall driver. It killed the lows better, and I didnt notice a dif in output to the ear. Im sure on a meter it would probably be louder tho
    Apr 2012
    Danville, KY
    1,109
    414 Post(s)
    Stfu @Boomsday ;
    acura3.2tl's Avatar
    Sep 2012
    CO
    112
    32 Post(s)
    WHat options should i get on the Fi Q?
    Apr 2012
    Danville, KY
    1,109
    414 Post(s)
    Fully loaded.. But it will take a while to get your sub.. Haha
    40oz's Avatar
    40oz is offline Senior VIP Member
    Dec 2011
    detroit
    261
    59 Post(s)
    If you only have 1500wrms on tap then there would be no point in getting any options, the stock would be just fine. If you plan on upgrading your amp to over 2k then you should get the cooling option and the extra spider.
    If you are going sealed then get the High QTS option, if you are going ported or unsure then stick with the Low QTS option.
    The internal lead is unnecessary according to one of the people that used to work at Fi.
    Also I would get the Q over the BL most definitely, unless you are looking to compete.
    acura3.2tl's Avatar
    Sep 2012
    CO
    112
    32 Post(s)
    Thanks everyone! I will just get the stock Fi Q then. Will 6ft3 work tuned at 32hz? Or should I tune lower? Box will be made with 1" MDF, 2" front baffle, and braced well.
  9. #9
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    thats fine
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
  10. #10
    acura3.2tl's Avatar
    Sep 2012
    CO
    112
    32 Post(s)
    will a port that is 2.5" x 24" be big enough so there is no port noise?
  11. #11
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Back to ATL
    13,028
    33 Post(s)
    3127 Post(s)
    BL has the greater potential to be louder.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
  12. #12
    acura3.2tl's Avatar
    Sep 2012
    CO
    112
    32 Post(s)
    How many square inches for the port so theres no port noise?
  13. #13
    Slo_Ride's Avatar
    Oct 2005
    Back to ATL
    13,028
    33 Post(s)
    3127 Post(s)
    Quote Originally Posted by acura3.2tl View Post
    From FI
    Q 18 – We recommend using a sealed box in the range of 4-8 cubic feet of volume.
    Ported box we recommend using 6-10 cubic feet @ 28hz tuning, you can tune a little higher if you wish but we recommend keeping it under 32hz. Again the same 12-16 square inches of vent area applies per one cubic foot of volume.
  14. #14
    acura3.2tl's Avatar
    Sep 2012
    CO
    112
    32 Post(s)
    thank you!
  15. #15
    prajeet's Avatar
    prajeet is offline Junior Member
    Feb 2013
    Rajasthan, India
    21
    3 Post(s)
    Hi,
    Both are good I think but I used 18" Fi Q...
  1. Replies: 4
    Last Post: 04-11-2008, 03:13 PM
  2. which one will get louder?2 12"s or this 1 15"
    By nikosbuddy in forum Subwoofers
    Last Post: 11-28-2004, 10:37 PM
  3. What would be louder, 2 12" L7 or 2 15" L5, what would you choose?
    By nofriends46 in forum General Discussion
    Last Post: 10-09-2002, 03:01 PM
  4. What would you get a Pioneer Premiere 740 or a Pioneer 8400MP?
    Last Post: 10-05-2002, 09:15 PM
  5. Replies: 3
    Last Post: 09-25-2002, 01:27 AM
