Results 1 to 10 of 10
Reload Thread: Single 15 vs dual 12s.....
    tweekerz's Avatar
    tweekerz is offline Member
    Apr 2004
    Chicago
    145
    Ok coming down to a decision here, looking at a single 15. I dont want to count out the 12s though. Simply put, I need the biggest back massage possible. Looking for 50/50 SPL to SQ, have about 4 cubes internal to work with. Upgrading electrical system also. What would you run and why?
    Thanks,
    Andrew
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    Re: Single 15 vs dual 12s.....
    Go with the 20 12's. More cone area. Two 12's will hit harder because of the more cone area compared to the single 15.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    tweekerz's Avatar
    Apr 2004
    Chicago
    145
    Quote Originally Posted by monte_carlo97
    **** 20 12s holy **** that would pound hard. LOL.
    24 inches opposed to 15 inches of cone area. Makes sense. Now I need to look into setups with 12s. Any suggestions would be helpfull.
    Chevillac's Avatar
    Chevillac is offline The X Factor
    Mar 2004
    international
    35
    40,991
    1 Post(s)
    10 Post(s)
    was there a certain speaker that you were looking at? i wanted to ask the same questions, the speaker i had in mind was the orion h2 though. im reading and reading, but it seems like everyone usually jsut uses One 15 or one 12. this local shop in st pete when i went there and talked to him, i told him one 15, and said ill give you 2 12s for $425. but i still think i want one 15. can anybody suggest something, im about a month away from ordering, so i have a little bit more time to research.Peace
    C
    tweekerz's Avatar
    Apr 2004
    Chicago
    145
    Quote Originally Posted by Devillain00
    C
    RE sounds VERY appealing! But I am nowhere near figuring out what 12s I want. I had my mind made up for a 15, the XXX. The 12s need to get low and be clean at the same time.
    Feb 2004
    Central Ohio
    30
    3,509
    Sorry my bad i meant 2 instead of 20
    97 Monte Carlo
    tweekerz's Avatar
    Apr 2004
    Chicago
    145
    i can see the 15 getting lower than the 2 12s but if the box is tuned right for the 12s that should help.
    tweekerz's Avatar
    Apr 2004
    Chicago
    145
    What are then general sound differences between the two? Which setup can potentially hit more DBs?
  9. #9
    LimPerT's Avatar
    LimPerT is offline Senior VIP Member
    Apr 2004
    Grapevine, TX
    407
    do you even have the space for 2 12's?
  10. #10
    tweekerz's Avatar
    Apr 2004
    Chicago
    145
    I have about 4 cubed internal to work with...
  1. A single 15" L7 or two 12's...two 10's ...ect?
    By Jeepaudio in forum Subwoofers
    Last Post: 04-09-2004, 02:43 AM
  2. dual mono or single 2ch
    By idnoiforget in forum Amplifiers
    Last Post: 12-20-2003, 12:38 AM
  3. sealed box sizing for a single orion xtr 12s?
    By moturbopar in forum Enclosure Design & Construction Help
    Last Post: 12-06-2003, 12:31 AM
  4. Do I want Single or Dual VC?
    By Forty-Ouncer in forum Subwoofers
    Last Post: 07-12-2003, 02:58 PM
