Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 47
Reload Thread: man o man.. I'm confused.
  1. #16
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Re: man o man.. I'm confused.
    Those prices lol @Vertex Audio ; check them out you'd prolly really like the lethal injections and maybe even a 20.1 ... Fucckk new Memphis ....
  2. #17
    Beerdrnkr's Avatar
    Beerdrnkr is offline CarAudio.com Veteran
    May 2006
    San Diego
    5,931
    73 Post(s)
    I don't think you'll need an extra battery. Try it without it first and see how it's holding up. If you're having bad voltage drops then you can add one. It's not hard to add one later.
    References: galacticmonkey, 2lo2flo, mwe-maxxowner, xxxbasshead, cynicz, CHEMMINS, phantom240, blazron22, Imtjnotu, Blove1991, jeeper07, biker911, juniorab, spl_robb, monarae21, vitveet (x3), RidnClean, jdubbau, Nevada, SubNit, tEh koRnDog, infamous_e46, stuckinok, FASTIMES, RAM_Designs, btdickey99, Slammed, SPY, orangelss, dalucifer (x 3), dtbrown, khanhfat, iamamp3pimp, slam, 350zspl, latinplaya22, silvercookie, us3, bikinpunk, kpozr2, Biowaste, Zeuslicious (x 5+), and many many more....
  3. #18
    djmixx79's Avatar
    djmixx79 is offline Member
    Jan 2013
    nc
    50
    31 Post(s)
    Quote Originally Posted by Beerdrnkr View Post
    ok.. stupid question here.. and thank you by the way.. I am seriously thinking about choosing from your list.. voltage drop? is this like.. headlights dimming?
  4. #19
    ewadz3006's Avatar
    ewadz3006 is offline CarAudio.com Elite
    Jan 2012
    erie, PA
    768
    283 Post(s)
    I've got a tad under 2000$ in mine. I bought it all new except for my subs. Also im only running @2 ohms. Everyone that gets in it cant believe its 2- 12's.
    I feel sorry for those who do not drink, when they wake up on the morning that's the best they're going to feel all day.-Frank Sinatra
    2004 mercury mountaineer
    Hu Kenwood excelon x996
    Fronts Incriminator audio comps
    Front amp Aq 120.4
    sub amp Aq2200d
    subs 2 sundown sa 12's @ 32hz
    wiring knu 1/0 ofc
  5. #20
    djmixx79's Avatar
    Jan 2013
    nc
    50
    31 Post(s)
    Quote Originally Posted by ewadz3006 View Post
    I don't know the difference in these ohms I hear ranging from 1-2 or whatever.. no clue.
  6. #21
    djmixx79's Avatar
    Jan 2013
    nc
    50
    31 Post(s)
    Well - from your list.. if YOU were to create a system that will give you major clarity at high vibrating volumes.. you know.. volumes that will shake the car next to me with my windows up.. like the guy was saying on page one.. he rolled down the road and made car alarms go off.. thats the power i'm looking for...yet, I want to the mids, highs, and bass to be on the same level.. not having the bass drown out the vocals.. so.. what would you chose from your list.. and if that's not powerful enough - what would you upgrade to?
  7. #22
    ewadz3006's Avatar
    Jan 2012
    erie, PA
    768
    283 Post(s)
    S
    Quote Originally Posted by djmixx79 View Post
    What that means is im only putting abot 1000-1100 watts to the subs. The amp is rated at 2200 watts at one ohm. So at 2 ohms it only puts out 1000-1100.
    I should have said im only running 1000-1100 to them
    Front amp Aq 120.4
    sub amp Aq2200d
    wiring knu 1/0 ofc
  8. #23
    djmixx79's Avatar
    Jan 2013
    nc
    50
    31 Post(s)
    S
    What that means is im only putting abot 1100-1200 watts to the subs. The amp is rated at 2200 watts at one ohm. So at 2 ohms it only puts out 11-1200.
    I should have said im only running 11-1200 to them.
    gotcha, thanks
  9. #24
    djmixx79's Avatar
    Jan 2013
    nc
    50
    31 Post(s)
    So I researched "the big 3" ... that's pretty involved it seems.. would it be easier to just get a extra battery in the back? Should I be worried about my alternator with this type of setup that beerdrnkr mentioned on the first page?
  10. #25
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    I don't know how big your alt is but I used to run around 1000 rms on stock alt, 4 gauge wire and no batt. I had little voltage drops but nothing too major and this was in an older Honda Odyssey. Sometimes the Big 3 and 0 gauge and all that isn't necessary.
  11. #26
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,424
    141 Post(s)
    1 Thread(s)
    6010 Post(s)
    Ok I can help you out here. The m class amp are decent amps. But it sounds like your being charged full retail as most shops do the rest is mediocre at best. I have used the amps before back in the day. But like stated there is better for the money and maybe less to. I can give you prices for everything you want but I need your wants and needs what type of music do you listen to and some measurements to build a box My rep here speaks for its self ask anyone everything I sell is new warranty and shipping included in all my prices
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  12. #27
    double 07's Avatar
    double 07 is offline CarAudio.com Elite
    Nov 2011
    Etowah, TN
    1,960
    13
    3 Post(s)
    626 Post(s)
    You are just a state away from me....I can save you some coin and build you a sweet enclosure for whatever subs you decide to go with....
  13. Likes brooklynjoy2008 liked this post
  14. #28
    Tenacious's Avatar
    Tenacious is offline Banned
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    You'll want to do the big 3. Stock wires don't allow your alternator to reach its full output. It's actually not hard to do either.
  15. #29
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    Did they give you a full run down on how they would be doing the install? I think that price is a bit high, but it does depend on how the install is done to some extent.
    Everyone here will jump on the "that cost to much" band wagon because of online prices and the diy market. If you're a dyi kind of person then of course much better can be had out there for your budget. However, if you are more of a pay to have it done kind of person then finding a shop that does amazing work will cost s bit, but will be worth it for their quality of work.
  16. #30
    southernboom88's Avatar
    southernboom88 is offline Shut It Down Boyz
    Oct 2011
    ATL.
    226
    54 Post(s)
    the big 3 is super easy and imo, a must have. 30-45 minute job if you can locate the ground wires (google it for your car).. seriously worth the time and the cost is very low considering the benefit it has. plus you should be able to do it at home if you have a few simple tools (order wire online, 0awg ofc is best).... as far as that shop goes, they are screwing you bad on those prices. dont be afraid to buy used or online in general.. couple awesome dealers on this site that can hook you up and will not lead you in the wrong direction. GL.
  1. Man oh Man, I need some insight. 6x9 vs components + sub
    By raymonddd in forum General Discussion
    Last Post: 03-12-2011, 10:34 AM
  2. Man- O -Man- O -Man
    By only126db in forum Subwoofers
    Last Post: 03-06-2008, 09:48 PM
  3. oh man oh man oh man. BRAHMA RULES!
    By d audio 450 in forum Subwoofers
    Last Post: 07-09-2003, 03:20 AM
