+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: Recommend 400 watt sub in sealed enclosure
  1. #16
    nas786's Avatar
    nas786 is offline Senior VIP Member
    Sep 2004
    central cali
    216
    Re: Recommend 400 watt sub in sealed enclosure
    Quote Originally Posted by Tenacious View Post
    If you're wanting SPL of any sort you should always go ported unless space is an issue.
    Some subs to look in to: Sundown E, Audioque SDC2.5, American Bass XD and as you mentioned the DCON.
    And is there a reason you're running at 4 ohms and not lower?
    ---------- Post added at 04:42 PM ---------- Previous post was at 04:42 PM ----------
    The amp I'm looking at is sundown 125.2, which can be bridged at 4ohm to 400 watts. There is also a sundown 1000d for $80 more which can run 600watts @ 2ohm. It can also do 1000watts@1ohm, but then (from what I've read) I'll have to get 0 gauge wire and also some other things in order to make sure it doesn't **** too much juice out of my battery. I guess I wouldn't mind running it at 600watts@2ohm. But if I can get a decent set up with the weaker amp I'd rather do that and save the $80.
    The reason I'm sticking with sundown amps is cuz I already have a sundown 125.2 amp to run my components, and want the amps to have the same design so that I could set it up in my trunk looking nice.
  2. #17
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Quote Originally Posted by nas786 View Post
    Those are both good amps, but I'd recommend the monoblock and running at 2ohms. It'll give you an upgrade path further down the road and, with the current draw you'll be using at 2ohms, shouldn't need to do anything beyond the Big 3.
  3. #18
    nas786's Avatar
    Sep 2004
    central cali
    216
    Quote Originally Posted by neo_styles View Post
    O really. The big 3 is actually what I was trying to avoid. I thought it was for systems 1000+ watts? If I'm doing 400+250=650watts total, would I still need big 3?
  4. #19
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    It's good for any system of any power. Not a requirement, but it'll keep you from taxing your stock electrical system to the point where you might need to replace an alternator. Big 3 isn't too hard, though, and you're really only adding wire to existing points. Something to consider...
  5. #20
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,245
    5 Post(s)
    The 2012 Alpine Type-R subwoofers are very good for the money (SWR-12D2/D4). I was reading a review in a Russian web site. Measured T/S parameters are extremely close to the published ones. Very low distortion performance. Practically non-existing 3rd order harmonics. These subwoofers are supposed to have a very symmetric BL over a stroke and extensive inductive treatment. Measured sensitivity about 86dB at 1watt/1meter. Compare this to Dayton HO-44s abysmal 83.2 dB 1watt/1meter. So on your 400watts the Dayton HO-44 will sound about as loud as a Type-R on 200watts. Type-R's are also optimized for a reasonably sized sealed box. These are rated to handle 1000watt RMS, but I don't see why these subwoofers will perform worse on 400watts than another subwoofer that's rated for less. 86dB sensitivity 1watt/1meter is pretty standard for this class. You can't go wrong with these IMO.
    Having said this, another sleeper SQ sub for sealed box is Infinity Kappa 120.9w. These sound very clean to my ears, and then drop low and have a strong impact when you need. Very low published inductance indicates someone worked on shorting rings and such for better SQ. Fine qtc in a 1-1.2 cu ft sealed box. There is pretty good review of these on talkaudio.co.uk. I power mine in 4ohm with a mono block that does 600watt RMS, although this sub sounded pretty sweet even on modest 250watt RMS being sent by a 5-channel amplifier.
  6. #21
    nas786's Avatar
    Sep 2004
    central cali
    216
    I'll keep that in mind, thanks for the heads up
  7. #22
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,525
    1 Post(s)
    Cool, I will look into that. Do they do well sealed?
    Also, I've come across tc sounds epic, soundsplinter rl-i, and dayton audio reference hf. Any comments or suggestions on either of these?
    they do better ported but yes they will work well sealed im still gonna mess around on my 18 with a sealed box just havent had the time to do so
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
  8. #23
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    6,100
    12 Post(s)
    i have a rd audio sonance sub and 12 inch basket i will ship to @SPLaudio ; for him to custom build a sub and he can build it from 500rms up to 1000rms amazing subs for exactly what you want, sealed, small ported, or big ported
    Splaudio's custom subs thread
    40 shipped to his door
  9. #24
    Tenacious's Avatar
    Tenacious is offline Banned
    May 2012
    Lebanon, TN
    549
    2012 model Type Rs don't have very good SQ from what I've heard. Older models do however, and are even cheaper. They've got a 600rms rating too. Maybe look for a couple Type R 1242 or 1243s
  10. #25
    Tenacious's Avatar
    May 2012
    Lebanon, TN
    549
  11. #26
    nas786's Avatar
    Sep 2004
    central cali
    216
    Quote Originally Posted by mclerico83 View Post
    hmm, interesting. So he basically builds old subs back up? What type of sound characteristics would I expect? Same as the original sub he's rebuilding, or does he have his own sound signature?
  12. #27
    nas786's Avatar
    Sep 2004
    central cali
    216
  13. #28
    zako's Avatar
    Jan 2011
    TX
    1,245
    5 Post(s)
    You probably heard a highly subjective and misinformed opinion, which is very typical of "internets". (But if you know of a review that says "I played A B and C with this sub, and then swapped for another one, retuned and gave a listen again, and here is the result", give me a link) Put a subwoofer into a wrong box or bad tuning, and it will sound like poo. The 2012 Type-R is supposed to be pretty much like the previous model, but with stronger motor. As I have said, hard measured _objective_ numbers say it's supposed to be a good product. It's not always that a subwoofer's published T/S parameters are pretty much the same as measured, as well as combined with good distortion profile. I could post a link to an article if it was in html format. It will be out in a few months.
+ Reply to Thread
  1. Sub in Sealed enclosure
    By blowsoot in forum Subwoofers
    Last Post: 12-03-2005, 06:55 PM
  2. RF subs in sealed enclosure
    By bryguy1701 in forum Subwoofers
    Last Post: 05-25-2004, 12:46 AM
  3. Inverted sub in sealed enclosure?
    By MXJMR in forum Enclosure Design & Construction Help
    Last Post: 02-28-2004, 07:43 PM
