Results 1 to 7 of 7
Reload Thread: Does size really matter 10" VS 12"
    darrellred's Avatar
    darrellred is offline Junior Member
    Mar 2004
    arlington, Tx
    23
    Icon32 Does size really matter 10" VS 12"
    Keeping the amp the same and choosing the same brand woofer in a 10" or 12" with a ported box (box being bigger for the 12")
    What would be the difference.
    I bought a Diamond 10" sub in a slotted (ported) box and it sounds awesome and gets loud. What would be the benifits of going with a 12" in a bigger same type box?
    Thanks for all the help.
    Darrell
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    Re: Does size really matter 10" VS 12"
    the difference between a 12" and 10" is that with the 12" you have more cone area hence more air that will be moved. But that is just what i understand it as. Could be wrong. Most likely 12" have more power handeling but if you are using the same size amp that is really not a factor then.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    madmaniac's Avatar
    madmaniac is offline Junior Member
    Apr 2004
    NY
    22
    louder, deeper, more expensive, takes up more space. wants more amp juice. using the same amp wattage the woofers sensitivity will play a factor. if its not an efficient speaker you might not get that much more. i dont know about the diamonds sensitivity.
    Silica's Avatar
    Silica is offline CarAudio.com Elite
    Jul 2003
    Cambridge Ontario Canada Earth
    32
    610
    What matters in the box. A 12" sub will give you a deeper sound, the largers cone area gives a little more spl, and if the motor structure of the 10 and the 12 inch are the same, than depending on the initial power rating of the 10 in woofer, say 200rms, then the 12 inch more or less could handle about 50 watts more.
    There isn't much downfall from upgrading from a 10 to a 12 othan than space and power. Larger the woofer generally the more power required to move it and larger the enclosure required.. Those are the main differences between the two. but a ****** 10 will do some serious damage, dont underestimate the 10's :P
    I've kicked some serios *** with a single 10, in a box that would i guess be understood as a something as a abc style base 6th order quad aero port box. Man that thing was serious serious.
    Have fun
    Tim
    justsayk's Avatar
    justsayk is offline not ******
    Jan 2004
    35
    829
    My girl friend told me size doesn't matter.
    Eclipse CD5444
    DLS R6A's -> Aura RPM2300
    sold the subs because i don't drive much anymore
    no_vendetas's Avatar
    no_vendetas is offline Member
    Feb 2004
    Peoria, IL
    39
    117
    Quote Originally Posted by justsayk
    Thats a bad sign. The only time a girl says that to you is if she thinks you're small. Or she has a lesbian friend.
    Just for the sake of keeping this thread on topic I think 12's are a perfect size. not as bulky as a 15, just the right size. I like how 12's sound.
    I got some dirt on my shoulder, would you brush it off for me?
    justsayk's Avatar
    Jan 2004
    35
    829
    LOL. Size matters. The bigger it is the deeper and harder it can hit...same goes for the subs.
    Eclipse CD5444
  1. Box size for kicker L5 12" Whats too big?
    By ronjon228 in forum Subwoofers
    Last Post: 02-02-2004, 03:46 AM
  2. XXX 12" Enclosure size
    By rob3379 in forum Subwoofers
    Last Post: 12-31-2003, 03:30 PM
  3. What size box for 2 12" Alpine Type R's?
    By 318iSPOLKMoMo in forum Enclosure Design & Construction Help
    Last Post: 11-02-2003, 10:34 PM
  4. Ported box size for a Type R 10"?
    By supernoodles in forum Enclosure Design & Construction Help
    Last Post: 10-14-2003, 12:32 AM
  5. port size for 12" sub
    By cooldoctorb in forum Enclosure Design & Construction Help
    Last Post: 08-04-2003, 05:13 PM
