I want to buy 2 cvr 15s and run them off a hifonics brutus amp and I wanted to know the differences between the 2 and 4 ohm models. And does 2 ohm mean I wire it straight to the sub and not the terminal on the box??
Something tells me 2 15s won't work in a IS300 if that's your car and CVRs may not be your best choice.
But 2 ohm vs 4 ohm just helps u match up to your amps required impedance for the power u need. What Brutus amp do u have? They are 1 ohm stable so you'll need dual 4s and need to wire them to 1 ohm.
Use this: Rockford Fosgate® - Woofer WiringWizard
What brutus amp?
REFS double 07, toxicity, liftednali, jes42, pieper88, mylows10, taylorfade, homegrown, vertex audio, gameovercca, radwilsons5803, juice+
HU: KDC-X994
Front stage: Phd FB 6.1PRO KIT, Active
Sub stage: 1st gen RE XXX 12" w/Fi recone
Highs Amp: Kenwood Excelon XR-4S
Lows Amp: Mmats D300hc
The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
I'm not a bass freak I just want enough and a 1700w brutus mono
get 2 dual 4's and get em down to 1 ohm for that amp
Pioneer AVH-P2400BT
Stock Pioneer 4" components
Hifonics Brutus BRZ1700.1D
Two SA-12's
cruddy prefab ported box----new box otw
What's the diff between the 2/4?
Wiring configuration. Two dual 2ohm subs can either be wired at 2 ohm or .5 ohm... Two dual 4 subs can be wired at 4 or 1 ohm...
Oh okay. How do you wire 2 4 ohms to 1ohm?
Your car won't support that amp. And like its been said. You won't get 2 15s back there ported. Not kickers for sure.
- 2010 Scion tC
- Alpine CDA-117
- JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
- Hertz HV 165XL
- Hertz HT28
- JL ZR800
- 2 x DD 9512i
- Singer 300 amp 15.1v bypass, 3 XS D3400s
- DD M4a and XS D3100 coming soon
- Viper 5701 with Smart Start
not a bass freak but ur tryin to cram two 15s in ur car?
2005 Chevy Colorado ext cab ( back seats removed )
kenwood DNX6980 DD 4v preouts
Rockford fosgate PA2 equalizer
Sub Stage: x2 18" AQ HDC4
Sub Amp: AQ 3500.1 at .5 ohm
Enclosure: 8.2 cu ft tuned 29hz
highs/mids: RF T2 6.5, 1" super dome tweeters
CA: Rockford Fosgate T800.4
Electrical: Iraggi 320A HO Alt, 3x XS 3400, Big 3, 2/0 welding cable throughout
Metered 9/21/12 after install = 153.9 db. 11/2/12 after break-in = 154.4 db
jungstah liked this post
The 15s are already in the box in the back of my car I just need to know how I should wore them and my car can support that amp....
- 2010 Scion tC
- Alpine CDA-117
- Hertz HV 165XL
- Hertz HT28
- JL ZR800
- 2 x DD 9512i
Look at the wiring wizard up there
- 2010 Scion tC
- Alpine CDA-117
- Hertz HV 165XL
- Hertz HT28
- JL ZR800
- 2 x DD 9512i
Bookmarks
