+ Reply to Thread
Results 1 to 15 of 15
Reload Thread: 10" Sound Quality Sub, and enclosure firing direction suggestions needed.
    Roland's Avatar
    Roland is offline Member
    Dec 2012
    Atlanta
    64
    1 Post(s)
    I'm trying to complete my SQ system with a good 10" sub-woofer and Amp set up and need some input. I'm just after good sound quality no real big thumping Bass here.
    I have Rockford Fosgate T2652-s components, tweeters in the dash, and 6.5's in the door. Driven by Precision Power P900.4 amp with a Pioneer DEH-80PRS Head Unit.
    So i have 3 questions, if you can help with any of them it would be appreciated,
    (1) 10" Sub Choice? This is where i really need help! (i'd rather not spend over $140 for a sub)
    I guess i need a 4 Ohm sub, Single voice coil, If i go with the PPI P600-2 amp.
    I have seen Dayton Sub's come with high recommendations. So is the Dayton Audio DCS255-4 A good choice or should i consider a different one. or brand???
    Shop Subwoofers from Dayton Audio (301 | 14) - 497|3923
    (2) Seal Sub box, Should i have the speaker fire downward or forwards.
    (The one single 10 "sub is going between the front seats of a Odyssey mini-van, it's a two seater, the back is work equipment only.)
    (3) Amp choice? i need small in size (less than 8"-9" square) under $150.
    My current 1st consideration is the Precision Power PPI P600-2, @$130.
    This looks like a good choice for me but i'm open for suggestions? PrecisionPower - Products - Amplifiers - Phantom - P600.2
    mylows10's Avatar
    mylows10 is online now WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    Re: 10" Sound Quality Sub, and enclosure firing direction suggestions needed.
    low budget will not get you the best sounding amp ,fire the sub down ,dayton sub is a great sub ,should be fine
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  3. Thanks Roland thanked for this post
  4. #3
    Roland's Avatar
    Dec 2012
    Atlanta
    64
    1 Post(s)
    $300 for the Amp and Sub is it. I still will have to build the box, and like i say i really don't play my sub very loudly so it partly about what i can afford and what will fit.
  5. #4
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    MI
    12,522
    81 Post(s)
    You should buy my Stereo Integrity SI BM 10" or my pair of Adire Audio Koda 8" XBL^2 subs. You will not find a better sounding subs for the price.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    A Technology Related Blog
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  6. #5
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Elite
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    Go with the Dayton HO 10", and that PPI should power it nicely, sure there's better out there, but not new for that amount of money.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Lanzar 6m
    Tweets: Crescendo CCX
    Fronts Amp: Alpine PDX4.100
    Sub Amp:Hifonics BRZ1.1700D
    Substage: 18" SSA ZCON
    Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
  7. Thanks Roland thanked for this post
  8. #6
    mylows10's Avatar
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    Quote Originally Posted by Roland View Post
    best i can do is 340 shipped for both
  9. #7
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Elite
    May 2009
    Minneapolis MN
    1,704
    6 Post(s)
    i have an elemental designs 10 inch sub. same as this one here 2 flat cone Elemental Designs e10O.44
    i have it in 1 cube sealed and gets loud and low great SQ. i also have an amp. its a infinity 1600a in like new shape with bass knob seen here. FS/FT infinity matching amp mono 4ch
    plus if you wanted a matching 4ch i have that in that add above if needed.
    i could do both sub and sub amp for 300 plus actual shipping.
    or both amps and sub for 400 shipped?
  10. #8
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,245
    5 Post(s)
    As far as Dayton subs go, the HO, HF, and Titanic have very good reputation. However, if I was buying a new 10 inch subwoofer for sealed box application, I'd consider being a guinea pig and picked the new Dayton Ultimax 10 2ohm DVC subwoofer.
    (Dayton Audio UM10-22 10" Ultimax DVC Subwoofer 2 ohm Per Coi 295-510)
    The specs look interesting. 0.67cu ft sealed box gives you a perfect qtc alignment with 45Hz F3. Normally, I'd expect 45Hz F3 in a sealed box from a 12 inch sub, so this one seems better than average 10 inch sub in this respect (including Dayton's HO10). 19mm xmax is also very impressive. There is more linear stroke than in any previous Dayton subwoofer (and most other subs on the market for this price).
    PPI P600.2 is a fantastic little amp for a subwoofer duty (as well as its Soundstream TN2.600D copy). You get honest 600watts RMS, good efficiency and tiny size (6.5x6.5 inches) for under $150. I can't think of a better value for a 600watt amp right now. I went with P900.4 originally when I needed a sub and rear speaker amp. If I knew in advance that I don't need rear speakers, I might have bought the P600.
  11. Thanks Roland thanked for this post
  12. #9
    Roland's Avatar
    Dec 2012
    Atlanta
    64
    1 Post(s)
    Quote Originally Posted by UnderFire View Post
    this one Dayton Audio RSS265HO-4
    Single voice coil 4ohms Right? should be good with the bridged PPI P600.2
  13. #10
    UnderFire's Avatar
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    Yes
    Mids: Lanzar 6m
  14. #11
    Roland's Avatar
    Dec 2012
    Atlanta
    64
    1 Post(s)
    Quote Originally Posted by zako View Post
    PPI P600.2 is a fantastic little amp for a subwoofer duty. You get honest 600watts RMS, good efficiency and tiny size (6.5x6.5 inches) for under $150. I went with P900.4 originally when I needed a sub and rear speaker amp. If I knew in advance that I don't need rear speakers, I might have bought the P600.
    So i would wire this one in parallel to get 4 ohms because it has 2 voice coils???
    (edit. correction, series)
  15. #12
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Wiring it in parallel will result in a 2-ohm load and IIRC, that sub isn't stable bridged at 2 ohms, so it's better for you to either find a svc 4 ohm sub or a dvc 2-ohm for that ppi
    You could go with a SSA dcon or ID10 2-ohm.
    ---------- Post added at 07:50 PM ---------- Previous post was at 07:49 PM ----------
    Disregard, just noticed that Dayton is a 2ohm dvc...so to answer your question, yes
  16. Thanks denim thanked for this post
  17. #13
    zako's Avatar
    Jan 2011
    TX
    1,245
    5 Post(s)
    It's a DVC 2ohm subwoofer. Wiring in parallel gives you 1ohm nominal. Wiring in series gives you 4ohm nominal.
  18. #14
    Roland's Avatar
    Dec 2012
    Atlanta
    64
    1 Post(s)
    Thanks, I needed some help with that, i new something was wrong. (i need to brush up on what series and parallel even looks like, It has been a looong time)
    I will read up some more on these GREAT sugestions .
    BIG THANKS ALL!!
  19. #15
    Roland's Avatar
    Dec 2012
    Atlanta
    64
    1 Post(s)
    So Availablity is an issue with these subs.
    SSA dcon --Build time 21 Business days. That's a month even without holidays, wow I don't no if i am that patient. But wow a solid reputation and great fit for my amp and price! (Are these really made in the USA, for each order?) People actualy wait that long for a order.
    Dayton Audio UM10-22 10" Ultimax DVC Subwoofer 2 ohm Per Coil -- aren't available until the 27th (10 days away, not to bad)
    Looking at their photo, at rest it looks like the rubber surround extends out 1"+ beyond the mounting frame. The "Over 1-1/2" of travel" mean they will extend out another .75" beyond there At rest placement? If so in a fire downward box the box would have to be 3" + off the floor!! Im I correct??? if so, this may not be a good choice and i should rule this out?. Everything else about it looks awesome.
    Image Dynamics ID10 D2 V.3 (i think these are what Noe_style was recommending) are available and do fit the needs. They seem to have good reviews, They look a little strange kind of cheap to me (it probably just the photo). but i see some real good reviews.
    Dayton Audio RSS265HO-4 , Looks good also. maybe on the high side for the amp with it lower sensitivity, and higher watt rating
    Should i rule out the Dayton Audio UM10-22 10" Ultimax for my downward firing box ?
    Looking at some videos i notice all of these play a LOT louder than i will ever play my music!
    A least the PPI 600.2 for my amp is a done deal.
+ Reply to Thread
  1. 10" Sound Quality Sub
    By ItsAJeepThing in forum Subwoofers
    Last Post: 01-03-2012, 08:52 PM
  2. Replies: 7
    Last Post: 10-08-2011, 02:10 AM
  3. Replies: 4
    Last Post: 01-27-2003, 02:40 PM
  4. Sub and enclosure question...
    By kmu in forum Subwoofers
    Last Post: 06-26-2002, 04:58 PM
