+ Reply to Thread
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 75
Reload Thread: RF Power Series T112D2 Blowing Amps?
  1. #46
    its10v1's Avatar
    its10v1 is offline The Caped Rock-Head
    Jul 2010
    Flint, Murda-Mitten(Mi)
    21
    395
    5 Post(s)
    Re: RF Power Series T112D2 Blowing Amps?
    So, its not my outputs that are bad (on the Kole KX1-2000D) its the inputs, Used a power adapter and hooked up a jumper wire to the remote, it powers on and produces sound if I wiggle the White RCA input. Maybe I if I open it up and check the solder, I'll see why?
    S*** where did I put my solder gun..
    The White input does not wiggle now, plus on the in side I noticed the pin on the inside of the connector had been pushed in. I pushed it back out, added a small dab of solder and tightened a screw or two and leaving it to set upside down (for the solder to settle.)
    Update:
    Had an audio shop price match me with another shop that had lower tier stuff. Got away with $20 for fuse/holder.
    New (Says it accepts 4GA/8GA, but looks like it could take 1/0) DB Link Gold Edition ANL fuse holder w/ 150A Stinger fuse.
    Packages
    Team Starr Mountain Nuthugger #4
    Bought From: outsideshot23, bigguy2010, SAZCLASSD, centergod79, SPLaudio, JCRF71, Vertex Audio, assassin1840, woofercooker, double 07
    Sold To: ChucklezZ, Davecub14
    1998 Pontiac Grand Prix GTP Sedan: (2) C&D 102AH Trunk Batteries, Needs Big 3
    Sub stage: Custom SPLaudio 12" DC Lvl 5 m1 motor Dual 2-Ohm
    Box: 1.75ft^3 ported @ 31hz
    Sub Amp: Cadence ZRS C5 (5,100w RMS 1-Ohm @ 14.4v)
  2. #47
    audiobaun's Avatar
    audiobaun is online now Premium Member audiobaun is a Supporting Member of the forum!
    Jun 2011
    rockwall,Tx
    5,923
    36 Post(s)
    Nice Fuse, and Holder..I would say as others havent mentioned to look closely at,as the wire/original 4ga, looks to be burnt inside the Jacket/strands burnt.I know it blows, but it looks to me that the 4ga wire is not any good,and needs to be replaced for sure.Also, the 150 amp anl fuse should be the largest to be used on 4ga wiring safely,no bigger
    Recommended Power and Ground Cable Sizes & Speaker Wire Size and Length
  3. Thanks its10v1 thanked for this post
  4. #48
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,923
    36 Post(s)
    XS Scorpian is made by stinger, and this is a decent wiring kit for the money
    Xscorpion PAK48 2B 4 Gauge Complete Power Dual Amplifier Amp Installation Kit | eBay
  5. Thanks its10v1 thanked for this post
  6. #49
    its10v1's Avatar
    Jul 2010
    21
    395
    5 Post(s)
    Quote Originally Posted by audiobaun View Post
    Priced out and compared sizes at the three shops, One has some XS 4GA for 3.50/ft. That seems to be my best bet. As it's bigger than the largest 4GA I have.
  7. #50
    nkrell11's Avatar
    nkrell11 is offline Senior VIP Member
    Oct 2012
    Mt. Pleasant, MI
    223
    3 Post(s)
    To avoid clipping and damaging future amps just set your gains with a dmm since you have one. I'm guessing this forum has a thread for setting gains with a dmm, if not there is one on ROE you could read. As for power wire I would go with audio technix since you can order it by the foot and it's good well priced wire.
    Car:2004 Grand Prix
    H/U: Alpine CDE-102
    Wires: Tsunami 1/0 OFC Positive Run, Audio Technix 1/0 CCA Negative Run, KNU Big 3 1/0
    Batteries: Kinetik HC2400 Rear, Duralast Gold AGM Front
    Amp: Crescendo BC2000D
    Substage:Rebuild Time
  8. Thanks audiobaun, its10v1 thanked for this post
  9. #51
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,923
    36 Post(s)
    Quote Originally Posted by its10v1 View Post
    It sure would be..Excellent deal
  10. #52
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,923
    36 Post(s)
    Quote Originally Posted by nkrell11 View Post
    I believe there is in the 101/help section Ive never looked it up, but it is on the forum.That is an excellent choice of wire as well
  11. #53
    its10v1's Avatar
    Jul 2010
    21
    395
    5 Post(s)
    Finally, Making progress!!
    Thanks for your input, both of you!!!
  12. #54
    its10v1's Avatar
    Jul 2010
    21
    395
    5 Post(s)
    I'll be sure to look them up, again I can not say it enough: THANK YOU!!
  13. #55
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    223
    3 Post(s)
    While the xs is a good wire you can get ofc 1/0 from audio technix for 3.55/ft or if you aren't looking to run gobs of power you could go with cca for less 1.75/ft.
    Car:2004 Grand Prix
    H/U: Alpine CDE-102
  14. Thanks its10v1 thanked for this post
  15. #56
    its10v1's Avatar
    Jul 2010
    21
    395
    5 Post(s)
    I think I have Tsunami CCA 1/0(Weird thing is the wires appear silver.. and I don't see the orange-ish tint of copper.. (Not 100% that it's Tsunami either, I'll take a look at it and report back sometime tomorrow.))
    I'm not sure how to tell what it's composed of though. I got two 12'6+" runs.
    Going to bed.
    Yet again, it's probably over-kill at this point...but...
    THANK YOU!!
  16. #57
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,923
    36 Post(s)
    Do replace your main run to the amp,as it does look burnt/no good.It looks like its burnt to me.get some clean run /power to that amp.
  17. Thanks its10v1 thanked for this post
  18. #58
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    223
    3 Post(s)
    Honestly I'm not sure how to tell the difference other than if the jacket on the wire tells me. If I had to guess I would say that cca 1/0 is better than 4 gauge ofc in terms of current carrying capacity but I could be wrong.
    Car:2004 Grand Prix
    H/U: Alpine CDE-102
  19. #59
    its10v1's Avatar
    Jul 2010
    21
    395
    5 Post(s)
    Will do FOR SURE
    I'm not positive either but I don't have big 3, or H.O. alt, or a great battery.. I'll be looking into it further as I get time.
    Yet again thanks you guys!
    but bed time GN, TY TY TY
  20. #60
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    223
    3 Post(s)
    Getting the big 3 done will help with your voltage drops as well you may also want to invest in a stinger volt meter as well to monitor what kind of voltage your amp is seeing.
    Car:2004 Grand Prix
    H/U: Alpine CDE-102
+ Reply to Thread
  1. WTB: RF Power Series Amps
    By amoffitt in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 12-12-2007, 10:59 PM
  2. a ? about the rf power series subs.
    By nativeboy in forum Subwoofers
    Last Post: 07-13-2007, 12:54 AM
