Re: Adding 6.5" subs to the rear doors?
Originally Posted by
gckless
Potentially yes. Most of the work done to doors is to eliminate cancellation, and if you are getting cancellation at those frequencies then yes, you will notice something. It is the best first step IMO, and may get you what you are looking for. However, it may not. I think you have some high hopes in mind, and you may not find that without some bigger woofers and/or a 3-way front stage. Again, I am not the subject matter expert on this, though I think doing work on your current setup first is the way to go. If you can go to shows or someone local that has a good front stage and listen and discuss what they have done, I think you will get some idea of the work and time involved and what exactly you want/need to do.
And again, there's a lot of information in this forum. Do some searching and reading. Don't decide on anything right away, give yourself a month or so to absorb some info.
Yeah, that all sounds good. I'll see if I can find any comps around here, that would be sweet to go to.
2000 Volvo v70
HU: Pioneer MVH-8200bt
Front Stage: Focal IS-165
Sub: Alpine Type-R 12"
Speaker Amp: Polk PA660 bridged to 150x2wrms
Sub Amp: Alpine MRX-M50
Sub Box: Custom, tuned to 33Hz
Bookmarks
