+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Reload Thread: 2 15" Kicker CVR vs. 1 15" Kicker CVX??
  1. #16
    Molinam123's Avatar
    Molinam123 is offline Member
    Dec 2012
    Coconut Creek, FL
    49
    1 Post(s)
    Re: 2 15" Kicker CVR vs. 1 15" Kicker CVX??
    Okay I've decided the amp which is a 2400 watt hifonics Brutus that has an Rms of 1700w at 2 ohm. Now what would be a good sub that fits my description??
  2. #17
    GAMEOVERCCA's Avatar
    GAMEOVERCCA is online now INCRIMINATOR AUDIO
    Jun 2011
    Hickory NC
    1,722
    9 Post(s)
    garbage vs garbage buy one of my DP15's and be alot happier then running the krappers
    Subs
    2 IA Death penalty 15's
    Highs and Mids
    2 IA Comp sets
    Amps
    1 AB VFL200.1
    1 Mmats SQ4150
    Batteries
    3 Deka intimidator 1000amp 100ah AGM's
  3. #18
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Quote Originally Posted by Molinam123 View Post
    You didn't answer all of the questions asked.
    Have you done any electrical work?
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  4. #19
    Molinam123's Avatar
    Dec 2012
    Coconut Creek, FL
    49
    1 Post(s)
    What do you mean by electrical work?
  5. #20
    cfox10's Avatar
    cfox10 is online now Rock the house.
    Mar 2011
    Albany, Oregon
    486
    1 Post(s)
    Big 3 (Wire from alt, battery, chasis) something like 0g
    Alternator? How many amps is the alt. running?
    Before you ask, stay away from capacitors and get yourself a 2nd batter. Speaking of, kind of battery are you running now?
    You need better electrical. You can't expect your amp to put out as much power as you want if your electrical can't keep up with it. You'll have dimming lights, strain the alt, battery, etc. Your amp won't last long either, keep the voltage up.
    • Pioneer 80PRS
    • db6501's LOOKING for new
    • 4 Gcon 12's
    • Coustic 510DR Amp
    • LOOKING FOR SUB AMP
    • Knu 0g
    • LOOKING FOR BATTERIES
  6. #21
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Just cuz you go get a big amo doesnt mean your car can power it... What all do you have done to the car already? What money do you have to spend? How much space do you have exactly?
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  7. #22
    Molinam123's Avatar
    Dec 2012
    Coconut Creek, FL
    49
    1 Post(s)
    Well I have a brand new alternator installed last month and a new battery I think an everstart gold. And the 0g. New wired from alternator
  8. #23
    Molinam123's Avatar
    Dec 2012
    Coconut Creek, FL
    49
    1 Post(s)
    And as I said I have a Lexus IS300 and about 400 to spend for sub and about 300ish for the amp
  9. #24
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    How big is the alt? What kind of amperage is it rated to put out? Or is it just stock?
  10. #25
    Molinam123's Avatar
    Dec 2012
    Coconut Creek, FL
    49
    1 Post(s)
    I believe 120
    ---------- Post added at 09:49 PM ---------- Previous post was at 09:49 PM ----------
    120 amps
  11. #26
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    So youll need a custom box and wiring as well...
    Western Rep.
  12. #27
    Molinam123's Avatar
    Dec 2012
    Coconut Creek, FL
    49
    1 Post(s)
    The enclosure and wiring aren't my issue I have all new wiring and a box I'm just confused about what sub to get.
  13. #28
    pimpala22's Avatar
    pimpala22 is offline borrocho
    Sep 2011
    West Texas
    1,000
    4 Post(s)
    well that amp is too much for those cvrs...i would get 2 ab xfl 12s on that amp
    2005 Chevy Impala
    In dash - Pioneer avh-p3200
    Front - Alpine spr-17s 6.5
    Rear - Alpine spr-69 6x9
    Amps - Hifonics bxi2610, jl audio 300/4
    Subs - 2 15" Incriminator Audio Death Row
    box- 8 cu ft net tuned to 32-33 hz
  14. #29
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    2,599
    48 Post(s)
    You shouldn't be wired straight from your alt, for starters... About the enclosure... if its some garbage, made in a factory, box.... Its gonna have to go.
    HU: KDC-X994
    Front stage: Phd FB 6.1PRO KIT, Active
    Sub stage: 1st gen RE XXX 12" w/Fi recone
    Highs Amp: Kenwood Excelon XR-4S
    Lows Amp: Mmats D300hc
    The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
  15. #30
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    So you have 2 custom boxes, one for 2 15's and one for 1 15? Since that's the original question and you said you have a box, that's the logical deduction. But, I am going to say you probably don't. You need to measure the space you are willing to lose to a box in order to figure out what size/amount of subs to properly run.
+ Reply to Thread
  1. 2 12 kicker cvrs vs 1 15 or 1 12?
    By JonnyB in forum Subwoofers
    Last Post: 05-20-2012, 02:20 AM
  2. 10 kicker cvr vs 10 jl w3v2
    By bcj2003 in forum Subwoofers
    Last Post: 07-06-2006, 06:52 PM
  3. 2 12'' CVR vs 15'' Type R
    By munchies in forum Subwoofers
    Last Post: 05-14-2006, 11:57 AM
  4. 2 10" Kicker CVRS VS Planet Audios
    By 86yota in forum Subwoofers
    Last Post: 02-22-2006, 05:15 PM
  5. 2 10" Kicker CVRs VS Planet Audios
    By 86yota in forum Speakers
    Last Post: 02-21-2006, 07:53 PM
