10" SQL moofer for 1.25 cubes @ 30hz on a budget.
Building my sister a sub-stage for Christmas with an enclosure similar to this one..
http://i3.photobucket.com/albums/y97...Picture004.jpg
where that front plate is a "beauty plate" and the actual enclosure is behind that plate like so
http://i19.photobucket.com/albums/b1...eettime002.jpg
I have the dimensions of that enclosure and will be building it to where I can achieve roughly 1.25 after port displacement using a 3" PVC port.
I want to know which 10"s can be had for relatively cheap (idk if there are any sick deals out there) that will perform well in this environment. I will probably be throwing at least 600w on it.
I was thinking about the Mach 5 subs that were really cheap, but also looking at Type R's and stuff like that. The car is a Charcoal Grey Altima coupe so the type R would look pretty good in there.
Also, a 3" Port will be roughly 14" long and I'm wondering if it will be big enough, or if I should try for two 3" ports at twice the length to alleviate port noise. This is sort of an idea as of now so it is still subject to change but what do you guys think?
Re: 10" SQL moofer for 1.25 cubes @ 30hz on a budget.
did you pick up that amp?
and get a Fi Q
Edited to fix detail mistakes.
Fi Q sounds like a decent idea. Just gotta get a good price on one. old RE subs go pretty cheap too
Quote:
Originally Posted by
skylineTT
I have a 12 re se needs recone? Could switch baskets. Otherwise that Ed would be perfect too.
anybody know of anything?
denim
What is SQL?
Lol
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
BrownVanMan
How much would you sell it for and how old is it?
if your building it for someone i would invest in a subwoofer grill.
GavinVoy
I'll probably end up making one
Did you build/hear the setup in the pics? I always wondered how a setup like that sounds because of the beauty panel blocking off the trunk
I did not build or listen to it. I'm sure a 10" sub on 600 will get decently loud in her car and that is all I'm going for in this build. I can let you know how it goes when I am done though.
