+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 36
Reload Thread: Is my sub bottoming out? or?
  1. #16
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,402
    23 Post(s)
    Re: Is my sub bottoming out? or?
    Quote Originally Posted by nkrell11 View Post
    You could check this by turning your subsonic filter up and then playing the same song or frequency again at the same volume and if you no longer hear the sound you were probably bottoming it out.
    How would a subsonic filter tell you if you were bottoming out? To test something you want to recreate the problem. A subsonic filter would just cut those frequencies out where it's happening.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  2. #17
    xx-wade-xx's Avatar
    xx-wade-xx is offline Junior Member
    Jan 2011
    Fort Wayne, IN
    I would turn the bass boost down. Chances are it is bottoming out. Continuing to bottom out the coil and it could start to deform/mushroom out. That would seize the sub up and turn it into a paperweight.
    Or its such a low frequency that you could just be hearing mechanical noise from the woofer. Hard to tell without hearing it in person.
  3. #18
    Lowflyin's Avatar
    Lowflyin is offline Sit on my face, B*tch
    Dec 2010
    Monongahela, PA
    838
    5 Post(s)
    Quote Originally Posted by xx-wade-xx View Post
    Sealed box, most likely aren't going to hear mech noise unless it's bottoming out.
    Sold To: Epic0318, Alpine-Accord Bought From: JL Audio, SPLAudio, JS UltimateSounds, ShoelessJake
    This guys a winner...
    Quote Originally Posted by darron016 View Post
    I want to trade my amp but it is currently mounted to my trunk, how do I go about posting a picture with the date etc with it mounted? I can barely get to it
  4. Likes VWGolfMKVI liked this post
  5. #19
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    774
    1 Post(s)
    Quote Originally Posted by Lowflyin View Post
    not entirely true. but then again most pple dont play test tones as low as 15 hz like i do.
    OP, you most likley are bottoming out ur sub like everyone else has said. turn ur bass boost down, and keep ur volume at a sane level. if you hear that noise turn the volume down! go and get an amp with a subsonic filter and your problem will most likley go away. set ur subsonic at ~26hz. this should give you a good enough roll off.
    Matt
  6. #20
    nkrell11's Avatar
    nkrell11 is online now Senior VIP Member
    Oct 2012
    Mt. Pleasant, MI
    219
    3 Post(s)
    Yes but if there was a certain frequency where he was bottoming out and turning up the subsonic eliminated the said frequency causing the sub to bottom out wouldn't that fix the problem and tell you that you were bottoming the sub out? I looked at it like the rule of thumb for about turning your subsonic to about 5hz below tuning of course the box is sealed but I felt the principles were still similar.
    Car:2004 Grand Prix
    H/U: Alpine CDE-102
    Wires: Tsunami 1/0 OFC Positive Run, Audio Technix 1/0 CCA Negative Run, KNU Big 3 1/0
    Batteries: Kinetik HC2400 Rear, Duralast Gold AGM Front
    Amp: Crescendo BC2000D
    Substage:Rebuild Time
  7. #21
    heebs 09gts's Avatar
    heebs 09gts is offline Senior VIP Member
    Jun 2012
    VanCity
    453
    Quote Originally Posted by mat3833 View Post
    Matt
    Thanks, I was kinda looking for someone to tell me what to do lol.
    I am thinking of getting the new JL 1200/1 v3 slash amp, a shop near me can give me a good deal on it. And then down the road if I ever want more bass, I should have enough head room to run 2 subs. Whatda ya think?
  8. #22
    mat3833's Avatar
    Mar 2008
    florida
    774
    1 Post(s)
    i like the JL slash amps. but there are better amps for the money. i cant help you pick an amp simply because i havent been able to decide on an amp for over 6 months...
    Matt
  9. #23
    cdc351jeferson's Avatar
    cdc351jeferson is online now Premium Member cdc351jeferson is a Supporting Member of the forum!
    Jul 2012
    austin tx
    1,590
    12 Post(s)
    Quote Originally Posted by heebs 09gts View Post
    those are good amps but how much is their good deal ?
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    subs: 2x dc 12" xls
    box : 3cuft net 33hz ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
    sub amp: AQ3500.1
    others: Mechman 240amp alt, 3 xs3400batts , all 1/0 knukoncepts kollosus flex, stinger deadener
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
  10. #24
    Jun 2012
    VanCity
    453
    lol, my main reason for the slash amp is the W7 is 3ohm svc, and the slash amp will give me rated power from 1-4ohm.
    Hard to find a amp that will give me 1000w at 3 ohm.
  11. #25
    Jun 2012
    VanCity
    453
    Quote Originally Posted by cdc351jeferson View Post
    I think it retails at 1300-1400 right now. He will give it to me 950 no tax. He said he just bought 50,000$ worth of JL so he got a good deal.
    Is it worth it at that price? I know they hold resale value pretty good.
  12. #26
    Jul 2012
    austin tx
    1,590
    12 Post(s)
    i bought my amp in sig for 820 shipped and it does 4000+rms at 1 ohm point being jl is way over priced
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
  13. #27
    mat3833's Avatar
    Mar 2008
    florida
    774
    1 Post(s)
    for 950 you can get more power at 3 ohms..... check in the classafieds. there are a TON of good amps on there right now.
    Matt
  14. #28
    Jul 2012
    austin tx
    1,590
    12 Post(s)
    even if your set on spending that much you can get a monster of an amp for 950. are you dead set on jl or open to suggestions
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
  15. #29
    Jun 2012
    VanCity
    453
    Yeah, I live in Canada. All audio equipment seems to cost more here. And if I bought in the classifieds or online shipping, duty and customs is a *****.
    I do also want good clean power, not that audiopipe stuff, or I mean popcorn sounds lol
    Do you guys recommend any amps that can give me 1000w at 3 ohm?
  16. #30
    Jul 2012
    austin tx
    1,590
    12 Post(s)
    yeah shipping might be a pain but you could get so much more amp for the money. my amp is clean power as well as alot of others dc sundown skar etc. look into a saz2500 you can snag one for around 800$ brand new with warranty puts out 1200 @2 ohms so youll be right around 1k at 3 those amps are under rated. plus if you upgrade yoru substage eventually youll have a 1 ohm and below stable amp for the future
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
+ Reply to Thread
  1. Sub bottoming out or box issue?
    By Digital Designs in forum General Discussion
    Last Post: 11-22-2010, 02:49 PM
  2. Is my sub ALREADY blown or is it my box?
    By nickolas_j_t in forum Subwoofers
    Last Post: 08-23-2009, 10:10 PM
  3. Is my sub blown up or repairable??
    By Skyline350GT in forum Subwoofers
    Last Post: 06-05-2009, 10:12 AM
  4. Why is my sub cutting out at higher volume??
    By 97JeepTJ in forum Subwoofers
    Last Post: 06-20-2005, 05:36 AM
  5. why is my subs cut out
    By allsport513 in forum Amplifiers
    Last Post: 01-16-2005, 12:37 AM
