Re: Sealed 12 Wrangler 2dr
How much space do you have? Is it $125 for the 12" sub and box or just the sub?
$125ish for the sub new or higher quality used. I will deal with the enclosure on its own after I see what some people say about it (type, etc). If sealed is definitely the way to go then I would need something that would perform at its best in the 1 to 1.25cuft range. Some of the non-mainstream subs talked about on this forum seem very promising.
ported sa 10 used gets my vote
How much airspace does your ported SA -10 suggestion need? Would I be able to get the range of the sealed 12 with the ported 10?
I did have a 8" high end Orion in a custom bandpass cube back in the early 2000's for a small truck. Thing was amazing but it lacked range.
Sealed SA-10 is around .6 cu ft and 1.1 ported. If you can find one used great. If you look into the Sundown E series you can get a brand new one from sundownonly.com for around $110. They are the entry level subs from sundown but they are far from entry level quality. Subwoofers - E series - Sundown Only
theres the link. If you are really hard up on space then you could always look into companies shallow mount subs but I'm all about Sundown Audio! My SA-10 pounds in my Nitro!
Loving the feedback! Thanks. I want to stay away from the shallows as I was not impressed with there output when I sampled a few. I have read some good things about the Sundowns and also the DCON and Dayton for budgets. I've been cruising craigslist/ ebay/classifieds here to see what quality used items might be there as well. I was happiest with the sealed 12" MTX 7500 Thunder in my old Jeep and would like something comparable or better. I do not want my lack of experience or comparisons to hold me back on something different. I'm not impressed with my Polk MM10" sealed. Is it the woofer? The size?...idk? Its in the recommended enclosure size. Just not feeling it at all. If you guys tell me ported is the only way...ok. If there is a 8" band-pass that trumps a single sealed 12 and has range I'm open to it. Just trying to be a sponge and absorb others knowledge so I can make the best decision.
I know I do not have the ideal sound stage and cabin reflection for bass production, but what is the best I can do for the open air element to be loud, clean with range? Ported, Sealed, 4th order BP?
