Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 95
Reload Thread: Audible difference between SA-12 and L7?
  1. #76
    whitedragon551's Avatar
    whitedragon551 is online now Moderator
    Mar 2009
    IL
    13,563
    39 Post(s)
    1408 Post(s)
    Re: Audible difference between SA-12 and L7?
    Quote Originally Posted by jungstah View Post
    read someone say it's got somethin to do with the square cone being heavy in order to make up for it being a weaker structure than a circle. the added weight makes the transitions between notes sloppy? idk man, i'd take an SA cuz you can recone it easily
    Nope. The outer edge of a circular woofer has the same force at every point along the diameter based on the center of the cone. A square woofer does not have the same force. The corners are weaker because of it hence the ribs in the corners of the cone and the surround on square woofers. This adds weight to the moving mass.
    As mentioned before the only positive to a square woofer is you can literally save baffle space in the sense you can butt gaskets right up next to each other. You cant do that with a circle woofer without leaving a gap.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  2. Likes DJSmooth245 liked this post
  3. #77
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,582
    61 Post(s)
    but i thought all squares were louder cause the woofer makes a square pressure wave that cuts through the air easier?
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
  4. Dislikes whitedragon551 disliked this post
  5. #78
    DJSmooth245's Avatar
    DJSmooth245 is offline Member
    Dec 2012
    Dallas
    112
    45 Post(s)
    Quote Originally Posted by whitedragon551 View Post
    Def makes sense....
  6. #79
    Dec 2012
    Dallas
    112
    45 Post(s)
    Quote Originally Posted by DCtC View Post
    Lets not forget he 12 L7 needs a box the size of a round 15 to get loud and sound half decent. So whats the point of a L7? Round 15 will be more accurate and get louder. The guys with the 'living loud' boxes that are WAY to small think they are loud, put them on a real meter and you will see they are not loud at all. A lot like distortion sounds loud to the ear but its not on the meter.
    that makes alot of sense..but is that true vice versa? Loud to the ear isnt loud to the meter...but is loud to the meter loud to the ear?
    And the reason this is still going is because i actually wanted someone to take the time out to explain in DETAIL why the L7 is trash..not constantly repeat themselves over and over again to no avail...too many noobs in this world (car audio world) to expect them to take minor advice on a major subject and believe it 100% and move on with their lives. Thats the same as telling a backup QB..."aye dont throw an interception, its bad for your rating and your team" when you could say "Instead of throwing directly at the receiver, look off the coverage by the Free Safety by looking at the opposite side receiver and then throwing to the man on man receiver..that will yield less interceptions" it helps to break down in detail why not to do something as opposed to a few key points
  7. #80
    SilverSquared's Avatar
    SilverSquared is offline Fat guy on the GROUND.
    Dec 2005
    Southeast Louisiana
    2,190
    2 Post(s)
    73 Post(s)
    ALL of the best subs are CIRCULAR...
    Voice coils are....CIRCULAR...
    Circular VC pulling Circular Cone = No EXTRA cone flex
    No EXTRA cone flex = Better Linearity
    Better Linearity = Cleaner Sound, Longer Lasting.
    Im noob. I could be wrong. This is JUST an opinion.
  8. #81
    Boomsday's Avatar
    Boomsday is offline CarAudio.com Veteran
    Apr 2010
    My House
    3,885
    62 Post(s)
    785 Post(s)
    SMH at all of this
    The L7 will get louder both subs in there optimal enclouser, now the SQ argument should almost be thrown out the window, because neither of them are what you would call sq drivers, so they will both sound like SH1t compared to a real sq sub..
    90% of daily installs the L7 and SA will preform similar and be ok for most..Anybody saying this one will be louder on the meter etc.. Need to shut up, thats a stupid argument, every install is different. I have seen ppl up there power and lose on the meter..
    OP just get whichever is cheaper, build the optimal box for it, and let it wang..
  9. #82
    Mar 2009
    IL
    13,563
    39 Post(s)
    1408 Post(s)
    Quote Originally Posted by Boomsday View Post
    SMH at all of this
    Even if they arent SQ subs the SA will still sound better than the L7. Doesnt need to be a top of the line sub to want a sub that doesnt sound like a wet fart.
    CA.com FAQ's
    Forum Rules
  10. #83
    Boomsday's Avatar
    Apr 2010
    My House
    3,885
    62 Post(s)
    785 Post(s)
    It will sound better is subject to install you and I both know that..L7's use to win sq titles if im not mistaken
  11. Likes DJSmooth245 liked this post
  12. #84
    Mar 2009
    IL
    13,563
    39 Post(s)
    1408 Post(s)
    Each and every driver/technology has different levels to which they add coloration/distortion to the music. The SA sub is by far the more technical sub when it comes to low distortion drivers out of the 2 mentioned. Sure you can say its all box dependent, however if both subs are in their optimal power range, box size, etc. the SA sub will sound better.
    CA.com FAQ's
    Forum Rules
  13. Likes DJSmooth245 liked this post
  14. #85
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,647
    106 Post(s)
    7467 Post(s)
    Those where not the l7s of today and I think mark Eldridge used the 8s with the x in the back. He could make audiopipe sound good enough to win
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  15. #86
    Boomsday's Avatar
    Apr 2010
    My House
    3,885
    62 Post(s)
    785 Post(s)
    It just goes to show install is everything, im not sure what has changed about the L7 between now in then, but im sure its not as much as most would think..
  16. #87
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by jdawg View Post
    If that wasn't a troll attempt, I don't think everyone seen that thread.
  17. Likes jungstah liked this post
  18. #88
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    78 Post(s)
    Quote Originally Posted by gckless View Post
    thread was quite good.
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  19. #89
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    It was. I got taken for a ride in that thread lol.
  20. #90
    Dec 2012
    Dallas
    112
    45 Post(s)
    whoa whoa...audiopipe? those subs are that bad? i was just recommended those the other day and am looking to buy a BF12 or 15...the way u put it made it sound like those subs are full of it...any truth?
  1. Whats the difference between SA-8v1 and v2?
    By ace_800 in forum Subwoofers
    Last Post: 02-27-2012, 11:09 AM
  2. So, difference between a 12 and a 15? Just a tad.
    By silenkiller in forum Subwoofers
    Last Post: 01-20-2010, 06:49 PM
  3. Difference between 2 12s and 1 15
    By newyork2050 in forum Subwoofers
    Last Post: 06-05-2008, 06:46 AM
  4. Whats the big difference between a L5 and L7
    By bunkerking09 in forum Subwoofers
    Last Post: 01-23-2008, 03:01 PM
  5. difference between 10's and 12's
    By Vorak in forum Subwoofers
    Last Post: 07-25-2002, 04:21 PM
