+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 36
Reload Thread: SSA Icon vs ARC Audio Flatline vs IDMAX vs Arc Black Series
  1. #16
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    3,480
    89 Post(s)
    Re: SSA Icon vs ARC Audio Flatline vs IDMAX vs Arc Black Series
    Just going to state most people will not recommend the Arc Flatline because they don't know jack about it. If you want impressive sq with a nice thump it would be quite a refreshment.
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Eclipse Xa5000
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
  2. #17
    Mixman's Avatar
    Mixman is offline Premium Member Mixman is a Supporting Member of the forum!
    Oct 2003
    Central NJ
    336
    We will see. I have an Arc Flatline inbound. I'll try it out. If it's close to an IDMAX.....as it should be then it will sound good. Heck I may keep both subs in two different size boxes.
  3. #18
    ge_off_me's Avatar
    ge_off_me is offline I sound better than you ge_off_me is a Supporting Member of the forum!
    ge_off_me is a Supporting Vendor of the forum!
    Apr 2010
    Ohio
    22
    6,330
    75 Post(s)
    Trust me on this, I have used many subs. If you want a sound quality subwoofer and are not looking to spend more than say 500 or so, the IA Flatlyne is your best bet, hands down. I have one in my house in a Transmission line, amazing sounding sub.
    PHD Audiophile Systems Dealer
  4. #19
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,472
    81 Post(s)
    Haven't had any experience with the other subs but my xcon exceeds all my expectations so the icon gets my vote
  5. #20
    ge_off_me's Avatar
    Apr 2010
    Ohio
    22
    6,330
    75 Post(s)
    The Arc Audio flatline is essentially a decent sub, though it is not very impressive. I would much more recommend going for the Arc Audio Black Series sub if you wanted to stick with Arc.
  6. #21
    Mixman's Avatar
    Oct 2003
    Central NJ
    336
    I have seen several people mention this sub. It's too expensive new. I would have to wait on a used one to come by to try one.
  7. #22
    Mixman's Avatar
    Oct 2003
    Central NJ
    336
    Good mono amps to power these subs in the $350 and under range ? Figure I need about 700 watts 4ohms or 1000 2 ohms.
  8. #23
    ge_off_me's Avatar
    Apr 2010
    Ohio
    22
    6,330
    75 Post(s)
    Do you need them to be efficient?
  9. #24
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    6,182
    12 Post(s)
    Quote Originally Posted by Mixman View Post
    I see a lot of people are recommending the SPG555. Well that means you have to get a custom cab and that adds to the price of the sub. So even with a blowout price of $269, you have to add another $100 or so for a custom cab......And then you better like it, because that's the only sub it will fit.
    I guess it seems my best bets are the IDMAX and the ARC Flatline, unless there are more recommendations?
    spg555 is 229 now
  10. #25
    Mixman's Avatar
    Oct 2003
    Central NJ
    336
    Quote Originally Posted by mclerico83 View Post
    spg555 is 229 now
    Well then please find a reasonblely cheap box for it ! I sure couldn't.
  11. #26
    Mixman's Avatar
    Oct 2003
    Central NJ
    336
    Quote Originally Posted by ge_off_me View Post
    Yes please. Efficiency is key. I do not want to upgrade my alt or even doing the big 3 upgrade on my new car.
  12. #27
    xShoWTeKx's Avatar
    xShoWTeKx is offline Drop Bass Not Bombs
    Jan 2011
    Greer S.C.
    23
    1,198
    4 Post(s)
    Soundstream REF1.1000 Mono Subwoofer Amplifiers at Onlinecarstereo.com
    great amp here would fit what you need perfect and give you a little head room.
    only vid
    http://youtu.be/8NRfhnWAo8o
    mobileaudioforum.com is better than CA.com in every way :o
  13. #28
    mclerico83's Avatar
    Oct 2009
    tampa
    6,182
    12 Post(s)
    are you not going to get a custom box built. the price will not change due to cutout. if you are going pre-fab then i would entirely suggest that you go cheaper on the subs and then contact pro-rabbit or star mountain on here
  14. #29
    Mixman's Avatar
    Oct 2003
    Central NJ
    336
    I actually like this amp a lot. The only thing that puts me off about it is that it needs two sets of power/ground connections. I really don't want to run more wire than what I have. I already have 4 gauge coming from the battery.
  15. #30
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    2,258
    Someone already said it man, but you really are wasting money.. The JBL is the mos effecient wooferc out of everything listed due to the dual drive system and the safest to run in a sealed application with as much xmax to boot. For an analogy It's like spending 500 dollars on shoes to see which one makes you the best basketball player.. Not gonna be much of a difference, time on the court is what you want to focus on lol. Try different boxes for your JBL, different orientations, external ports, etc. Those things are going to be a much better use of time and resources. Unless of course your only real goal is to blindly trynew product based on the opinions of others. Alot of people on this forum do that, and 3k and 12 stereos later consider themselves "knowledgeable" yet still can't create a setup they actually know they will like without guessing. If you haven't experimented with custom boxes yet then your really missig the boat. I can tell you from experience while the JBL's like a moderatly big box, they sound as good and gets as loud as really any other woofer can manage to do both at the same time, keeping cone area constant.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
+ Reply to Thread
  1. ARC AUDIO KS 1000.1BX vs KS 1200.1 w EPICENTER
    By cleansoundzz in forum Amplifiers
    Last Post: 12-10-2011, 12:45 PM
  2. IDmax vs. Arc audio Flatline
    By loud-n-low in forum Subwoofers
    Last Post: 03-28-2006, 02:01 AM
  3. Pics of the Arc Audio Flatlines
    By 3.5Max6spd in forum Subwoofers
    Last Post: 08-26-2005, 06:54 PM
  4. Replies: 6
    Last Post: 06-13-2005, 07:11 PM
