Yeah man, with a 3.5k and a beefy 4 channel, batteries just aren't going to cut it if you want to listen to the system for any length of time. You're drawing way too much for your alt to recharge those batteries.
I don't know what board the BC3500 uses. I thought I seen it compared to another 3.5k somewhere, maybe @TaylorFade ?
New Car, New Build coming soon... will consist of:
RF 360.3&Apple iPad Mini
Tantric comps
Sundown subs and amps
Mechman HO alt
Deka batts
Knu Conceptz&Shok wire
Audio Technix deadening
AQ 3500 in the classifieds with toolmaker dual inputs for 570 I believe IIRC
You'll need two group 31s, they don't have to be XS power, other people make batteries, too.. And for a hell of a lot cheaper, call it 300
And you're gonna want an ALT. I suggest an DC XP270, I freakin love mine. Run you about 3 bills used.
Then subs. I leave you at 1170 before subs, way less than 2 k if you sell your current amp and sa8
Tantric comps
Mechman HO alt
Deka batts
gckless thanked for this post
timma100 thanked for this post
headunit : Sony xab-601bt
fronts: infinity kappa 60.9's
subs: 2x dc 12" xls
box : 3cuft net 33hz ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
sub amp: AQ3500.1
others: Mechman 240amp alt, 3 xs3400batts , all 1/0 knukoncepts kollosus flex, stinger deadener
REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
"Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
If you're set on going with 4 8s, for all around loud I would look in to DD1508s. I've 4-5 different 8" set ups and the DDs impressed me the most. 4 1508s on 3-3.5k could be very loud! Other than that, 2 Sundown z v3s would be my choice...just cause they are sexy and I want some!![]()
Refs- DiabolicBass, nismos14,IonSQL,massiveaudiocw,sxpimpin,sundownz,8 7gr, nissan,Louie68,Tips,Trell,integra88,Ellsworthz,bas ebalz13,lil98cabrio,woofercooker,pro-rabbit,Louisiana_CRX,MANTI5,eL_wEEnIe,bubbagumper6 ,jco1385,95saturn,ace_800,micah_jones,assassin1840 ,beat-down69,RAM_Designs,whitedragon551,KTMrida4life
subs: 2x dc 12" xls
sub amp: AQ3500.1
Bookmarks
