+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Reload Thread: ANOTHER Sub Shootout/Design Question Regarding Sundown/Dayton/SSA (SQ Build)
  1. #31
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Re: ANOTHER Sub Shootout/Design Question Regarding Sundown/Dayton/SSA (SQ Build)
    Fair enough. Looks like I'll have to remove the Sundown as a possibility. IDQ and IDMAX were both possibilities at the beginning, but I'm concerned that they might have refreshed the line after the change in ownership. Either way, I don't think I'm going to find either one under 200 which is what I'm trying to set for a project maximum. Who has firsthand experience with the DCON sealed? I'm definitely not looking for frame-shaking bass, just a very nice compliment to the bottom end since it'll be running with the stock speakers for quite a while and I'm trying to avoid an onslaught of upgrade-itis.
  2. #32
    whitedragon551's Avatar
    whitedragon551 is online now Moderator
    Mar 2009
    MI
    12,487
    82 Post(s)
    I have a pair of Adire Audio Koda 8" subs if you dont mind buying from a reputable seller. $150 shipped and they are yours. They utilize an XBL^2 motor which basically ensures the coil is in the gap during excursion for maximum control of the cone (short version).
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    A Technology Related Blog
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  3. #33
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Agh you make it tempting and I will definitely let you know further down the road, but if I have 150 free up, I intend to move on to the sound deadening. Considering how many leisure expenses I've made this paycheck already, it's just not sensible to jump into subs right now. I'd still have to get the amp/wiring/enclosure/etc which would put me close to a grand OOP.
  4. #34
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,260
    6 Post(s)
    Make a list of products you find "acceptable", wait until the holidays. Track this hot deals section. Last year there were some fantastic but short lived offers on mainstream brand gear (JL, Focal, JBL, MB Quart, PPI, etc).
    If you set your mind on an IDQ subwoofer, I believe there was a way to make sonicelectronix an offer through their web site or ebay store. $200 is something they'd probably accept.
  5. #35
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    That's not a bad idea at all. Time to start making up a wish list.
    Dear Santa,
  6. #36
    sam_b03's Avatar
    sam_b03 is offline Senior VIP Member
    Feb 2009
    western OKlahoma
    318
    19 Post(s)
    Quote Originally Posted by zako View Post
    No, the ones I mentioned are SWR-843D/823D. These are from the previous generation Type-R lineup. Alpine didn't update the 8 inch model when it released the 2012 line-up for 10 and 12R, so those 8Rs are effectively "current generation" Type-Rs as far as 8 inch subs are concerned. They are not SPL monsters. Their power handling is 350watt RMS a piece, and you don't want to exceed that. Someone reported that they start to smell funny past that. Nonetheless, two 8Rs in ported inclosure should give you pretty good SPL. Looking at SAZ-1200D's specs, this amp would be perfect for having two DVC 2ohm R8 models wired for final 2ohm load. Running amp at 1ohm can be hard on car's charging system and the amplifier anyways. It seems like this amplifier could also be about right for one Image Dynamics IDQ12v3D4 or Dayton Audio HO12DVC. The Dayton has kind of lowish sensitivity though, while IDQ has more xmax and higher sensitivity, so you can get more SPL out of IDQ and still have good SQ. The IDQ costs almost twice the price of Dayton HOs, but often you can find them on sale for well under $200. Both are fine subs for 1cu ft sealed box, or you can try going with a custom built ported box. People are saying that Sundown SA can be comparable to IDQ in SQ, so I guess it's another subwoofer to consider. On "paper" though, the IDQ seems to have better sensitivity, so you could get a bit more SPL out of it on limited power. I don't know if you can really audit anything at best buy. Their ported boxes are most likely not up to the spec of subwoofer. You can't really audio a sub without hearing the rest of system.
    The SA to me is a clean sub it can keep up with some fast double bass kicks but it isn't as musical as the ID.
    I wanted a little more punch so I pulled my IDQ out of the sealed 1.25ft and installed an SA-12. The SA definitly hits harder but I am still kicking around the idea of going back the IDQ. The IDQ is much more musical. I listen to 95% rock and actually hearing the musical notes of the bass guitar is pretty nice. I messed up my wiring and was running all 600rms to 1 VC. oops. I discovered it when swapping subs. It didn't seem to hurt anything but I don't crank my stereo up that often or for very long. I know have MBQuart1500.1 amp so 1000 @ 2ohm, 500 @ 4, so I am guessing 250 at 8. This is underpowered but still in the ball park.
    CDT 642 powered by Clarion Apx 4360
    SA-12 powered by MB Quart ONYX1500.1
  7. #37
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,387
    74 Post(s)
    Get the Daytons or the Kodas.
    I've actually run the Daytons in an SQ build and they were fantastic.
  8. Likes Flex68 liked this post
  9. #38
    Flex68's Avatar
    Flex68 is offline dilligaf
    Jan 2012
    The Backroads
    1,613
    21 Post(s)
    Quote Originally Posted by neo_styles View Post
    Woke up to some good feedback. Thanks, guys.
    So the general concencus is 1 (not 2) of whatever sub emerges as the victor. I can live with that. Galactic, thanks for the offer, but I only have enough budgeted right now for the head unit which I ordered last night (got a pretty good deal from Crutchfield on an open box).
    Rabbit, based on your experience with builds, what are your recommendations for subs that perform (or at least design) well for small enclosures? I most likely will be coming to you for the box build anyway, so I value your insight.
    Zako, are you referring to the 1KW RMS Type Rs? If so, I think I saw a few references to that thread. At the very least these should be easy to demo at a Worst Buy. Same with the Kappa 12.
    Any Angelenos paying attention to this thread? I'm looking for decent places to go audition more of the stuff we talk about here. Preferably someone who knows 100% about their equipment and can speak with some authority about it.
    and looky looky
    2x Idmax D4 v3
    Quote Originally Posted by Spider Monkey View Post
    Romney will [fornicate] me less than Obama already has and WAY less than what Obama has planned.
    Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
    HU:Eclipse CD7200 MkII
    Subs: Fack Skar Audio
    Front comps: HAT Clarus C61-2 off Sony ES 7547
    Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
    Damping: 60mil FG panels over holes, full worx from SDS
  10. #39
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Holy wow that's a dang good deal. I'll keep my fingers crossed that something that good shows up when I can start buying. Whoever gets those should be pretty happy with themselves.
  11. #40
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    36
    27,848
    15
    73 Post(s)
    Switch the Dcon with Gcon in this case.
    CarAudio.com mod(original)
+ Reply to Thread
  1. Sub enclosure design question
    By bmusial124 in forum Enclosure Design & Construction Help
    Last Post: 08-31-2012, 08:01 AM
  2. 4Runner sub box design questions
    By williemon in forum Enclosure Design & Construction Help
    Last Post: 11-27-2006, 03:26 PM
  3. another sub wiring question
    By GF7PE in forum Speakers
    Last Post: 10-17-2003, 02:43 AM
  4. another sub question from me ::sigh::
    By RMN_05 in forum Subwoofers
    Last Post: 11-04-2002, 07:56 PM
  5. sub box design questions
    By maylar in forum Wiring, Electrical and Installation Help
    Last Post: 01-15-2002, 03:00 PM
Tags for this Thread
