who knows what the specs are for this sub.
520reaudiosx15s liked this post
Probably about the same as the 05 XXX
Western Rep.
99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
-Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
-Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
-Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
-Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
-Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
Not that I know of...
Western Rep.
ok cuz this is 1.6 ohms per coil quad coil.
Western Rep.
not a big deal quads were big yrs ago.
its a underhung sql woofer, its safe up to 1500rms.
RE AUDIO - Woofers
Enclosure Recommendations
12" Compact Optimal
Sealed: 0.85 1.1
Ported: 1.7@35Hz 2.2@34Hz
T/S Parameters
12"
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 or 4 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Product Dimensions
12"
Mounting Depth - 12.75 inch
Mounting Hole Diameter - 11.5 inch
Overall Diameter - 13 inch
Bolt Hole Circle - 12.25 inch
Motor Width - 10.5 inch
Motor Depth - 5 inch
Basket Depth - 7.75 inch
Displacement - 0.24 cu. ft.
Weight - 72 lbs.
Digital Designs Team Cactus Sounds Kinetik Excessive Amperage Xstatic Alpine Kicker Hyperflex Dynamat
Scott Owens 180 db run at Edge Audio In Phoenix,Az http://vids.myspace.com/index.cfm?fu...eoid=103176001
05 specs
Team Flex Issues
4 18" Mayhems
2 bc5500's
Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
ok so now I am running two of these. What should I tune the box to? I have 34wide x 14 high x 31 deep. THey will have 3k rms minimum power.
its a sql woofer so tune 32-35hz...
these were my dream subs back then NICE
Bookmarks
