Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 37
Reload Thread: Box Design
  1. #16
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Re: Box Design
    Quote Originally Posted by Mongo12 View Post
    I havent got any "real" midrange, still have the factory speakers -- ***** i know---
    I think I can get by tho for now..
    I think ill take your and bucks advice and try that common chamber design and make the port 3" instead of 2 . should I keep it (the port) 22 inches as drawn?
    also my geometry doesnt add up.. i drew the top board wrong it is supposed to rest on top of the side to equal 31.5 (27.75+3+.75).
    here is what I come up with:
    External dimensions: 18"H x 31.5"W x 20"D = 3.6 cubes net. with the port 3" x 18.5" = 55.5 sq" of port
    With the port 39" long, you will see a tune of 30hz.
    Response Curve:
    Last edited by quackhead; 07-02-2012 at 03:27 AM. Reason: 39, removed impedance ch.
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  2. #17
    Jan 2007
    3,282
    1188 Post(s)
    Re: Box Design
    I hope someone like @Buck can double check and verify my geometry as well...maybe offer some advice on the the R's and what they really like.
  3. #18
    Mongo12's Avatar
    Mongo12 is offline Junior Member
    May 2012
    South
    26
    11 Post(s)
    Re: Box Design
    sounds good ill change the plans and go with that. unless buck disagrees thanks for the help. without your work it'd have been trial and error and alot of wasted mdf
  4. #19
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    Re: Box Design
    How tall is the box
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  5. #20
    Jan 2007
    3,282
    1188 Post(s)
    Re: Box Design
    Quote Originally Posted by quackhead View Post
    Response Curve:
  6. #21
    Mongo12's Avatar
    May 2012
    South
    26
    11 Post(s)
    Re: Box Design
    ok so not to sound dumb.. but is the port 18.5 inches or 39 inches in your graph? or would i have to add 20.5" to the 18.5 inch port to get 30Hz?
    30hz sounds good to me since the probox is (i was told) tuned to around 45..
    the redline is scaled to 18.5 inches and the yellow shows where it would be at 39 inches .. unless i misunderstood your dimensions.
  7. #22
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Re: Box Design
    I would do like 4.5-5 cubes.
    ---------- Post added at 07:04 PM ---------- Previous post was at 07:04 PM ----------
    What program is that?
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  8. #23
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Re: Box Design
    The 4.5-5 cubes is personal tastes, the 3.6 will work.
  9. #24
    Mongo12's Avatar
    May 2012
    South
    26
    11 Post(s)
    Re: Box Design
    will the 3.6 be tuned lower than the probox? and any ideas on the port should it be 18.5" or the ?39"? thats got me tripping
  10. #25
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Re: Box Design
    The port should be around 39. I would like to see a shorter box or a different port style to get rid of the 3 wide and 18.5 tall, I'd like more 12 tall, 4.5-4.75 wide to keep the same port area. But that'd if you can fit the extra depth/width.
  11. #26
    Jan 2007
    3,282
    1188 Post(s)
    Re: Box Design
    Quote Originally Posted by Buck View Post
    I used Final Calculator to work out box and port, then use UniBox408 to map it
  12. #27
    Jan 2007
    3,282
    1188 Post(s)
    Re: Box Design
    you think with the dems he has and the port up/sub up it would be better to go Precision port?
  13. #28
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Re: Box Design
    He could do a single 6".
  14. #29
    Mongo12's Avatar
    May 2012
    South
    26
    11 Post(s)
    Re: Box Design
    the precisions are 6" x 18" could one use pvc or do you really get the gains they say using the $40 tube they sell
    also id have to add 3" to the width, that will work but 34" is the max width I can go. Would that xtra cubes make a difference?
    and since the box is 18" tall, how much space is required below the bottom of the port and the bottom of the box?
  15. #30
    Jan 2007
    3,282
    1188 Post(s)
    Re: Box Design
    If you can do that extra width, now we are getting somewhere, assuming you still want subs up/port up configuration. Going back to the original design using these external dimensions:
    20" tall x 34" wide x 22" deep, the top of the box, where the subs and port opening will measure an overall 34" x 22"
    With the slot port at 4" wide and 20.5" across (22" - 1.5") make the port the same overall 39" long inside the box (except using the 4" design, instead of the 3") as post # 21, you will be at 4.8 cubes/net @ 31hz tuning and have less port noise introduced. This is a closer match to Buck's recommendations
  1. sub box designs
    By Unregistered in forum General Discussion
    Last Post: 03-27-2002, 12:36 AM
  2. box design
    By loner7757 in forum General Discussion
    Last Post: 02-08-2002, 01:54 AM
  3. box design for a honda accord 1991 that will hold 4 tens
    By v12rob in forum Wiring, Electrical and Installation Help
    Last Post: 01-30-2002, 12:38 PM
  4. box design
    By penguin in forum Wiring, Electrical and Installation Help
    Last Post: 01-28-2002, 02:21 PM
  5. sub box design questions
    By maylar in forum Wiring, Electrical and Installation Help
    Last Post: 01-15-2002, 04:00 PM
Tags for this Thread
