Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: WTF?? JL Audio 10w7 disappointment!!
  1. #16
    another1's Avatar
    another1 is offline Junior Member
    Jun 2012
    Fargo, ND
    2 Post(s)
    Re: WTF?? JL Audio 10w7 disappointment!!
    ok will do
  2. #17
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,647
    106 Post(s)
    7467 Post(s)
    And set the gain right before you fry the sub
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  3. #18
    May 2012
    The Roc, NY
    1,307
    503 Post(s)
    Quote Originally Posted by DCtC View Post
    ^^ +1,000,000
    You don't want to mess up brand new equipment. If you know anybody with a DD1, that would be great so you can test for distortion also
    BOYCOTT SKAR AUDIO!
    2012 TNESPL R2 WORLD CHAMPION
    TNESPL R2 ALL TIME RANKINGS RECORD HOLDER
    TEAM
    TEAM LOUD INTENTIONS
    www.youtube.com/TeamLoudIntentions
  4. #19
    BIGJEFF64's Avatar
    BIGJEFF64 is offline CarAudio.com Elite
    Nov 2009
    GAINESVILLE, FL
    597
    144 Post(s)
    Ill agree with everyone else here that u need more power actually JL says the recommended power rating for the W7 is 1k. trying to find a 1k @ 3ohm is gonna be a bit tricky unless u can find a JL 1000/1 on the cheap. Also I had a few W7's and i can tell u they really come alive in a bigger than JL spec box. IIRC the 13W7's likes 3.5-4 cu ft and we had it tuned in the lower 40's we were getting 48's sub back port back in a 4 runner on a sounstream XXX 4k
  5. #20
    rdlyn13000's Avatar
    rdlyn13000 is offline Senior VIP Member
    Apr 2012
    White Bear Lake
    493
    184 Post(s)
    I have a JL 1000/1 V2 if let go if you were interested. I also have a buddy that may be interested in your 500/1.
  6. #21
    Jroo's Avatar
    Jroo is offline CarAudio.com Elite
    Feb 2007
    richmond virginia
    507
    88 Post(s)
    amp as stated and look at a box design. If you have it in a JL spec ported, you can get much more out the box.
  7. #22
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    LOL, everyone sees Audiobahn then makes fun it. That is actually not a bad amp over all. I wouldn't trade straight up, but if he would add cash I would personally consider it.
  8. #23
    tat2bass's Avatar
    tat2bass is offline CarAudio.com Elite
    Aug 2011
    Cali
    1,680
    614 Post(s)
    This is kind of a question and suggestion possibly. I've recently heard that if you put a sub too close to a port that it can unload causing distortion and can mess it up. How does that work and how often does that happen? Could that be an issue with his considering it only sounds crappy when turned up?
  9. #24
    dross93ranger's Avatar
    dross93ranger is offline CarAudio.com Elite
    May 2005
    Maysville, KY
    30
    1,003
    45 Post(s)
    Got a 10w7 on 750w and it is begging for more. I love that sub.
    Running small stereos so I can haul a stroller.
    2004 Ford Focus SVT - Kenwood DDX370, JL Audio C2-525 Components, Sundown E8v1, NVX MVPA1 Mono Amp, Power Acoustik RZ2-1300D 2-Channel, Pac SWI-RC Steering Wheel Adapter
    1993 Ford Ranger (System still in progress) - Kenwood KDC-452U, E8v1 in Custom Ported Box, amplifiers and speakers still in question.
  10. #25
    BIGJEFF64's Avatar
    Nov 2009
    GAINESVILLE, FL
    597
    144 Post(s)
    Quote Originally Posted by tat2bass View Post
    IIRC that why port length is so important and if u are using a L shaped port it stops this due to the sub essentially being trapped in the box if that makes sense.
    if the box is to JL spec it probably has a L port or a "soundwave" style port which is what JL used in their H.O. boxes so i guess OP can let us in on that
  11. #26
    tat2bass's Avatar
    Aug 2011
    Cali
    1,680
    614 Post(s)
    Quote Originally Posted by BIGJEFF64 View Post
    Ok, makes sense. That is what I was thinking, just wasn't sure. When he said made to JL specs I was thinking he probably means how big his enclosure is and maybe didn't design it proper like you stated. When a sub does unload, is it normally at higher excursion or can it happen at lower also?
    Is there a general rule for port lenght? I plan on fiberglassing my quarter panels in to save space but want to try to port them so I can keep my output but dont want to jack them up with this.
    OP, sorry to thread jack, but the unloading at higher volumes thing might help you as well.
  12. #27
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    lulz at clipping...
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  13. #28
    Radiospank's Avatar
    Radiospank is offline Senior VIP Member
    Mar 2012
    los angeles
    160
    41 Post(s)
    1 is never enough 2 is better
  1. JL Audio 10w7
    By XSovereignty in forum Subwoofers
    Last Post: 09-16-2004, 10:08 AM
  2. what box with a JL Audio 10W7?
    By ASpec818 in forum Subwoofers
    Last Post: 08-13-2004, 06:02 PM
  3. 500w not enough for a JL Audio 10w7?
    By DDDD in forum Subwoofers
    Last Post: 06-03-2004, 04:35 AM
  4. Infinity Kappa Perfect 12.1 vs JL Audio 10w7
    Last Post: 06-01-2004, 01:15 AM
  5. JL Audio 10w7 VS Infinity Systems, improvements?
    By DDDD in forum General Discussion
    Last Post: 05-29-2004, 05:43 PM
