Re: 2 12" DC Audio Level 3s?
They'd be going in the trunk of a 2000 Chrysler Cirrus, I'll have the amps mounted in angles where they don't impose on the box's room/need for space. I know I could get 15"H, 34-34"W, 20-???L (There's more than 20 inches of length, I'd use whatever length is needed to max the box for the subs). I plan to forward fire the subs if I use a huge custom box and seal the subs off from the trunk, because with such a large ported box filling my trunk side to side, rear firing wouldnt be wise.
36" wide will get you almost 5 cubes which you will need all of...
They are loud if powered properly abd the box is right! They are a little under 300 each
Like I said... I want to maximize these subs to their fullest and the box is in my opinion the key factor in making sure that happens. Now I need to find out how much 2 of these will cost me. 1800RMS together... Sounds like love to me lmao
Quote:
Originally Posted by
Bostonjlguy
How is their sound quality? I want a system that is in the middle... Loud as ****, but sounds good as well.
And believe me I'd get them everything they need to be monsters
Eddie_24
They are pretty nice subs but they may want more power then you can give them with your electrical...
Well I plan to add a 3rd battery to my car soon, a XS brand one, high powered. I think with 3 batteries and the big 3 I'll be able to feed em
Eddie_24
Ya that would but your car probably wont like all the weight...
Bettr n' Revrse
Now that part is probably true... I seen a dude who had a wall built in a car like mine, he had more weight in it then I'll be putting in mine. He had 4 15s in the wall
Eddie_24
My Honda hated all the equipment when I was running my M3a...
I know these subs would beat my car to death...
But what do you mean? Did it start having mechanical issues?
I believe there are in the 200-250 range price wise. I had to of the m1s and they were awesome, and the m2's are better. If u give them recomended power build the box per dc's specs of ur gonna go with more power give them a bit smaller air space. @mylows10 can help you out.
