Results 1 to 9 of 9
Reload Thread: Speaker sounding weird at low frequencies, please help!
    stephens30228's Avatar
    stephens30228 is offline CarAudio.com Elite
    Feb 2012
    Union City, GA
    550
    160 Post(s)
    I recently got 2 12'' Kicker Comp VRs in a vented box. They are the 4ohm DVC versions. I have them wired to a 2600 Monoblock 2ohm stable Interfire amp. The way that I understand crutchfield's illustrations is that I can only wire these subs in either 1 or 4 ohm, therefore I have them wired in 4 ohm so I don't blow the amp. My question is that it was pounding pretty good earlier this morning, then I noticed slight rattle out of what I thought was the subs, found out it was my door panel, but after changing the amp settings I now can't get the subs to play good. When it drops low it sounds like the subs are losing power, and now the higher frequencies on some songs don't sound as good either. Can someone please point me in the right direction? I will do whatever is needed to fix the issue if it means not having to have it professionally done, the only thing that I have absolutely NO clue about is when it comes to the DMM and the gain, so I don't knwo what I am doing there. Thank you very much.
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    Re: Speaker sounding weird at low frequencies, please help!
    Quote Originally Posted by stephens30228 View Post
    Push on them hope you don't have coil rub.
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Phoenix gold zx600.2 ti
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
    Feb 2012
    Union City, GA
    550
    160 Post(s)
    If that was the problem, wouldn't it sound distorted at all frequencies?
    Feb 2012
    Union City, GA
    550
    160 Post(s)
    Okay I did in fact test them by pushing and no scrubbing. I guess that is a good thing, but now I am once again confused.
    murph's Avatar
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    prefab box or not enough power to the subs. Or you could remember they are kicker comp vr's they are not known for anything but being cheap. If you invest in better subs you would be impressed much better.
    Feb 2012
    Union City, GA
    550
    160 Post(s)
    I was always told that the old kicker comp vrs were great, but it may be not enough power. Since I am guessing not full 2600 watts.
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is offline Smoke weed everyday
    Sep 2009
    twenty past four
    4,618
    3 Post(s)
    1779 Post(s)
    Can you give an exact model # to the amp? The 2600 rating is probably a peak rating and is incorrect. The subs are most likely being underpowered in a non optimal box.
    Feb 2012
    Union City, GA
    550
    160 Post(s)
    (-NEW-) Interfire T-1500M 1600 Watt Mono Amp With Bass Knob T1500M Amplifier | eBay This one, and now that I look at the RMS wattage I am suspecting that I am underpowering by a long shot! But I don't know about the box, I have attempted to make boxes in my past but never could make a good one, I even made a couple that blew speakers due to my ignorance.
  9. #9
    Feb 2012
    Union City, GA
    550
    160 Post(s)
    Okay after quite a bit of searching because apparently these things are ancient, the model for the subs are 01c12vr4. Thanks for the help guys.
  1. Low Voltage? Please Help!
    By Nairblop in forum Wiring, Electrical and Installation Help
    Last Post: 03-21-2008, 04:19 PM
  2. bass sounds weird at certain freq's
    By tcguy85 in forum Subwoofers
    Last Post: 03-14-2007, 01:57 AM
  3. Replies: 7
    Last Post: 08-13-2006, 12:28 PM
  4. sub warble at low frequency
    By zephyr in forum Subwoofers
    Last Post: 01-29-2004, 12:23 AM
  5. does your system sound good at low volumes?
    By allyourblood in forum General Discussion
    Last Post: 01-28-2004, 11:29 PM
