Nightshade 15" or 3 Sa-8's???
I was wondering what you guys would go with? If I go with the NS It will have about 3cf after port and sub displacement. If I go with the 3 Sa-8's each sub will have about .9cf after subs and port displacement. Amp being used is a aq2200d. Will be a daily setup and will be used in the trunk of a 04 Chevy Cavi looking for the most "spl" but will not be chasing numbers box will be tuned around 32hz no matter which setup, I go with...
Re: Nightshade 15" or 3 Sa-8's???
Do u think the NS will do well in a 2.9-3cf box?? I would like to go bigger but that is not possible.
Also if I go with the NS box will have to be sub up port can go where ever. If I do the Sa-8's I can planned on doing subs and port back.
I would think the NS would be the best for output. But then again I have never ran one nor do I know what kind of space they must have. Someone with more expertise will chime in I am sure.
The Night shade will like a bigger box then 3 cubes...
the ns will work in a 3cft box. thats what i had mine in iirc.
Quote:
Originally Posted by
hrtbrk1
Ya depends on tuning and power I suppose
if you have 3cf net would do the 15".
do not do .9 per sa8 want .5-.7 is where i found to be best...
I would go nightshade all day. That thing will shine in 3-3.25 cubes. I was going to run mine in a 3.1 cube box on 3k
The 15" has more cone area than three 8's.
15= 176.71 in^2
8=50.26^ in 2 (3)= 150.78 in^2
