Denim do you really expect us on this forum to only do one post. We have to argue on every thread here.
I have done a few tests over the years with many setups and products. In some cases depending on the application and enclosure build the L7s did do better. I'm not saying it is a better sub or that AQ is a better sub. I'm saying it is dependent on the application for which will perform better.
If we are talking thermal handling even though the HDC does not have to good of cooling it still beats out the L7 easily.
Its simple buy and aq motor and basket have it reconed using quality soft parts. Will cost around the same price as a new AQ but alot better.. But stock vs stock I would still go with AQ..
RIP Christopher Maynard Martin "My heart"
HU - Eclipse CD7000 For Sale
Front Stage - 4 Silver flute 6.5's & 4 Seas Prestige tweets Sold
Front Stage amp - DB Drive A7 125.4 For Sale
Subwoofer - 3 Skar VVX 10's (Looking for 4th so I can run amp at .5ohm) Sold
Subwoofer Amp - Skar SK-2500@.67ohm For Sale
Box - 4.25cf tuned to 30hz using a 6" internal aero 15" long.. For Sale
Wiring - Knukonceptz everything, Big 3, Sprinter S12V370F & HC1800 Sold
pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
ab vfl 150.4 ,2 pc 2150 ,
cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
NOR CAL DB DRAG JUDGE
http://www.dcsoundlab.com
TEAM AUDIO TECHNIX
TEAM SSC
TEAM CADENCE
Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
+1 hdc3
~~ SSA Dcon / Icon / Xcon ~~
TeamSSAudio.com ~ SSA Forums ~ SSA MySpace ~ SSA Facebook Group ~ SSA Facebook Page ~ SSA Youtube
CarAudio-Forum.com ~ HomeAudioForum.net
CarAudio.com mod(original)
Anybody who says L7's have potential to get loud because they have more cone area than a round sub obviously has no idea what they are doing.
I've owned L7's and built SPL enclosures for them. Key word in that sentence is OWNED. As in no longer own. As in "sold them as soon as I could".
If you're going for maximum SPL, 9 times out of 10 the sub with higher motor force/BL is going to win, no matter the power level. My 9510 absolutely STOMPS every other sub I've tested on power ranging from 600 watts to 4000+. Just because one sub is rated for 500 and another is rated for 2000 doesn't mean the 500w sub is going to be louder than the 2kw sub on 500 watts.
Hell, my 9510 is louder than several 12's I've tested, once again proving that more cone area is not always better.
In this scenario I would go HDC3's without a second of hesitation.
Taylorfade pretty much summed up the rest of my thoughts.
Team Kicker (R.I.P.)
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
2008 Bassrace 130-139.9 Regional and National Champion
2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
One DD 9510 powered by two Sundown SAZ-2500's
Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
Kicker wiring throughout.
TEAM AUDIO TECHNIX
TEAM SSC
TEAM CADENCE
My statement still holds true. I have done tons of testing and application is everything. Not every setup likes the same the thing. Again, I'm not arguing which is better at all. I will admit that it is not very often and takes a special circumstance for the L7 to win out, but it could/can. But to make a general statement that one sub is louder then another is not accurate. There are many factors that come into play when considering SPL and depending on each specific application different subs and enclosure designs are required to achieve the numbers wanted.
Now if you want to say for this particular application/build sub A works better(is louder) I could agree with those kinds of statements.
I did state in my post that in this particular case I would go with the HDC3 without a doubt.
However, given all the testing I've done and have seen others do, I honestly can't think of one setup where if somebody was running L7's and they dropped in a more "spl" oriented sub that they wouldn't gain. L7's just don't have the motor force/efficiency that larger subs do.
It would take a weird set of circumstances for an L7 to be the loudest sub of the bunch. Hell, most sub builders (jacob @ sundown included) that more often than not the larger/stronger subs will be louder on less power than the smaller subs.
The main reason why people don't buy them is because of the cost and noticeable difference. Most people can't hear the difference between 145 db and 147 db. Might not make a difference to the average listener, but that's an astronomical difference for an SPL competitor.
I know it's bad to make general statements when it comes to SPL, but I have a hard time not doing it under these circumstances. I can get a type-r louder than probably 95% of this forum. That doesn't mean it's a good SPL sub, it just means that I know what I'm doing.
In most cases people will get better results from the bigger sub. It's, for lack of a better term, "easier" to get the more powerful louder, especially if you aren't an SPL competitor and don't do a lot of building/testing.
The main beef I had about the posts in this thread are with the people saying that based on specs and/or cone area, the L7's should be better. I was merely trying to prove that specs mean jack crap most of the time, as does cone area.
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
Very true. It does take some odd circumstances for the L7, but I found them a few times. I agree though that motor force will make a huge difference. That is one of the reasons the HDC subs do so well in SPL.
I still think building for SPL is easier then doing a daily myself.
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
Bookmarks
