Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 55
Reload Thread: MTX 9500's vs. T3 Audio
  1. #31
    bassin'96's Avatar
    bassin'96 is offline Member
    Oct 2011
    Wisconsin
    36
    Re: MTX 9500's vs. T3 Audio
    I think i'm gonna go with some Fi BL's or BTLN2's with an AQ 2200d powering them what one would you go for with that amp?
  2. #32
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,710
    15
    85 Post(s)
    Quote Originally Posted by bassin'96 View Post
    What about TC Sounds lms-r 12 inch or an fi bl? i just heard them both and they bumpedd the car good.
    i never did like treo's
    Both would be better choices with your power. LMS-r is only good for about 1KW continuous, you can do more but the 3" LMS coil will start getting smelly up over 1200W or so pretty quick. LMS woofers really do amazing things <35hz, BL is a fairly decent all-arounder. DD will also get loud and play relatively well in the right box.
  3. #33
    bassin'96's Avatar
    Oct 2011
    Wisconsin
    36
    alright, i like the idea of fi's but will the tc's put out just as much as the FI's? i like the sound quality and lots of output. i need a middle, it seems that FI's are just way better known.
  4. #34
    morespl's Avatar
    morespl is offline trying to upgrade
    Aug 2009
    carpentersville, il
    584
    t3's are great subs sounds like misuse I would be more worried about damaging the spiders on dd's at the triple joint. But opinions to each his own. Op you can't run any of those setups on stock electric effectively. They will produce sound but you would probably do better with lesser subs.
  5. #35
    Trancer's Avatar
    Trancer is offline CarAudio.com Veteran
    Aug 2002
    Allen, Texas
    27
    2,707
    3 Post(s)
    The MTX 9500's are great subwoofers. They are one of my favorite "main stream" subwoofers I have ever had. However, they are overpriced and if I remember correctly, they have gone on for years and internally unchanged. I could be wrong.
    I think everyone has forgot to ask a very important question. What amp will you be running or are you deciding on your subwoofer first, then pick out your amplifier to spec?
    I have noticed that you must have deep pockets, because the subwoofers you mentioned OP, are pricey subwoofers. So if that's the case, then I recommend a pair of SoundSplinter RL-S. They get loud and sound great doing it.
    As for the TC Sounds, they are geared more towards Sound Quality. They have a different kind of sound. I have a pair of TC Sounds T1000's with the TC2+ motor sitting in my closet with a pair of my RE SE 12's, which brings me to another recommendation of the older model of the RE XXX's. I have read on the board that the newer XXX's arent as great as the previous versions. I dont know about this first hand, but seems to be the general consensus about the newer versions.
    What vehicle will this be going in? Plan on going sealed or ported?
    07 black Yamaha V-Star FI 1300. 08 GMC Sierra QC SLE2 Texas Edition
    Rockford Fosgate 3Sixty.1, Focal Utopia Components, Focal K2P Components with Digital Designs T1 Tweeters, Audiopipe AQX-360.4, Audiopipe 3001D
    References: 21: DesertHeat, Ravens9322, Netherland24, Insomniac119, killahbean, Charlieee, Dustin19, djman37, dirthog, JayRich, JimJ, RassyMX, Slayerx, smgreen20, lyttleviet, RAM_Designs, Gingerbreadman, DarkHart, cwill5, Imtjnotu, Bettr n' Revrse
    Quote Originally Posted by GeekSquad View Post
    Make the port as large and as round as possible. For example, a square port is more round than a rectangular one; an octogonal port is more round than a square port. Also, keep the number of ports down to one, if possible.
  6. #36
    Ronny's Avatar
    Ronny is offline CarAudio.com Elite
    Jan 2010
    Grand Forks, ND
    703
    3 Post(s)
    Alright so what subs would you recommend?? the T3's will take too much too run. and the 9500's are overpriced
    the battery is stock its just a stock good alternator that runs 220amps
    That changes things again. You'll want an upgraded battery and possibly more alternator then.
    There is a reason a 220A alternator was placed in your car.
    Like one of my Mercedes, it has a stock 240A alternator, but that, big three, proper cables, and 2.8kW clamped dimmed everything down ridiculously. I had to place a D3100 in there atop the stock 86aH battery and now it's fine. I'll be adding more alternator soon.
    Anyhow, the vehicle will use quite a bit of that current, hence the reason it's in there.
  7. #37
    bassin'96's Avatar
    Oct 2011
    Wisconsin
    36
    its in a custom ported box, i'm thinking of the FI BL's fully loaded or the Q's. i want a middle of soundquality and spl. i think that fi is the way to go. i would like an AQ2200D powering these beasts. and a 6 cubic foot enclosure. thats net volume
  8. #38
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,671
    17 Post(s)
    Quote Originally Posted by wickedwitt View Post
    Thought I posted this in this thread but guess not...
    First system I was actually impressed by was 4 MTX9500 15s walled behind the first row in a Tblazer. Was rather impressive. Put the right power to them in the right box I think you'll be happy. Haven't seen any DD9500s that were as impressive.
    sorry but I'm still laughing at this, are you actually serious or just trolling?
    I like the mtx 9500 but the DD will rape it not even trying
  9. #39
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,933
    34 Post(s)
    Quote Originally Posted by wenn_du_weinst View Post
    Completely serious. I have seen a MTX 9500 build that was impressive. I haven't seen a DD9500 build that was as of yet.
    People say the same thing about DD9500 raping Solo Xs too, and every comp I've ever been to, I've been louder on less cone area and less power. Vs daily and SPL setups (mine is daily)
    Stupid Loud.
  10. #40
    bassin'96's Avatar
    Oct 2011
    Wisconsin
    36
    I'm not sure you guys have followed the whole thread at this point haha. just saying. we're on the topic of FI BL's or Q's
  11. #41
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Either just pic one really...
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  12. #42
    DDtC's Avatar
    DDtC is offline Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    5,950
    44 Post(s)
    Qs for sq
    BLs for louder
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
  13. #43
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,456
    4 Post(s)
    t3 is a fail...teammate has the new tsns 18's and they're pretty big, that's about it
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  14. #44
    May 2007
    4,671
    17 Post(s)
    When MTX or kicker takes DD down as the world champions then I will give them the same respect. So far the only 180db cars are all running DD
  15. #45
    bhsdriller's Avatar
    Jul 2007
    bakersfield,ca
    4,456
    4 Post(s)
    Guy that did it first was using Pioneer iirc
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
Tags for this Thread
