Results 1 to 12 of 12
Reload Thread: 2 ohm sub reads 1.8 ohms
    Xanthous's Avatar
    Xanthous is offline Senior VIP Member
    Sep 2010
    St. Louis, Mo
    311
    My alpine swr-1222d reads 1.8 ohms, i bought it used. I've heard a lower # means the coils been hurt.
    Thoughts?
    09civic's Avatar
    09civic is offline CarAudio.com Veteran
    Dec 2010
    Melbourne, FL
    6,690
    30 Post(s)
    Re: 2 ohm sub reads 1.8 ohms
    no, its completely fine.
    2009 Honda Civic 5 speed
    Alpine CDA 117
    CDT HD 61's
    AB SQ500
    AB VFL 8" on 500RMS
    0.85 @ 32 Hz
  3. 08-07-2011
    Reason
    no trolling in the tech sections
  4. #3
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,099
    17 Post(s)
    Quote Originally Posted by maljr1980 View Post
    throw it away
    dont confuse him lol. the ohms on a sub can fluctuate between .3-.4 ohms either way. your good bro. if you see crazy numbers like 13, then it randomly goes to 5, then 6 then 10, thats a blown coil.
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  5. Thanks Xanthous thanked for this post
  6. #4
    brynm's Avatar
    brynm is offline CarAudio.com Elite
    Mar 2006
    Saskatchewan, Canada
    1,008
    18 Post(s)
    What you are reading is the dc resistance (dcr) which is lower than the subs impedance. Sub is fine.
    Being re-worked, waiting on supplies.
    Kickers: SX600.2, SX1250.1, SXRC
    MB Quart: DSC4125, DSC2000.1
    12" SI Mag V3 @ 1 ohm, 2-10" Clarion SSW1000
    2 sets Polk DB6501 Comps
    Quote Originally Posted by iceteebone View Post
    I've only been caught once. I guess it wasn't smart to be fornicating in a tent display at Dick's Sporting Goods on black Friday
    Quote Originally Posted by Loud3 View Post
    we iz teh curaoutioz.coms.
    we is no kan speel
  7. #5
    mylows10's Avatar
    mylows10 is offline WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,046
    360 Post(s)
    sub is fine they dont always read exactly 2ohm or 1 ohm
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  8. 08-07-2011
    Banned
    Reason
  9. #6
    Xanthous's Avatar
    Sep 2010
    St. Louis, Mo
    311
    Alright thanks guys. Would it read higher or lower if it was blown?
  10. #7
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Quote Originally Posted by Xanthous View Post
    depends. it can go both ways , usually ends up in a higher number though , or infinite number because the coil is open.
  11. #8
    KyleBechtold's Avatar
    KyleBechtold is offline Buy my fuses $1.25ea
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    is this just one coil? if so your all good..
    Ca.com
    Bought from: Sctattooer, Korn4Life, wgsj_fortvalley, bk12321, Queball, bumpincrv, Splmaster, 310w6, Buck, liljojo4711
    Everyone I have Bought from has been awesome.. feel safe with any of them..
    Sold To: Iakona, dustinr, squeak12, Worstenemy453, BeAlLsTaR13, rmzsuzuki89, c_b_, mendon mafia, dropped_tb, SPLluminator, violence., power-fanatic07, schackel, michaellane, aviator08, kodak314, dropped_tb
    Ref Link
    Tamparacing
    -b15spec, 727kid, pshull727, Nt_Hardcore
    Want/Need ANL fuses cheap 150a 200a 250a 300a
    CLICK ME
  12. #9
    Xanthous's Avatar
    Sep 2010
    St. Louis, Mo
    311
    Quote Originally Posted by KyleBechtold View Post
    they are dvc subs.
  13. #10
    audioholic's Avatar
    audioholic is offline Moderator
    Aug 2003
    Parts Unknown
    23,749
    36 Post(s)
    What you are experiencing is the difference between a speaker's published/nominal impedance, and its actual impedance. Subs are published as 1ohm, 2ohm, 4ohm, 8ohm, etc to simplify the specs for the average consumer. But the actual impedance of a speaker is rarely exactly a whole number. This is because the impedance of a speaker is determined by its voice coil (the size/type/length of the wire in the coil, and the mat'l type used to make that coil). The manufacturer builds the coil to meet certain specs they want to achieve (like coil height, winding width, number of layers, flat wound or not, etc). In other words, if they want a 8-layer coil that is 2" tall with a certain gap distance, they are going to wind the coil to meet those specs. They will not turn it into a 9-layer coil, or change the whole geometry of the motor to make the coil 2.1" tall, jsut to hit some nominal whole number when measuring actual coil resistance (impedance). Thus if the manufacturer builds the coil to meet all their specs, and the result is a 1.8ohm resistance, they will simply publish it as a "2ohm coil".
    No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
  14. #11
    brynm's Avatar
    Mar 2006
    1,008
    18 Post(s)
    Just a nitpick... He is not measuring impedance with a meter he is reading the dc resistance of the wire in the coil.
    we is no kan speel
  15. #12
    kramer_212's Avatar
    kramer_212 is offline Music-Expression
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    welcome to the less than perfect world we live in.
