Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: 12" Brahma or XXX? Spec by Spec / Myth by Myth
    theimpaler's Avatar
    theimpaler is offline Member
    Feb 2004
    Louisiana
    31
    86
    Which is the better sub for a SQ system? A 12" Adire Audio Brahma Mark II or a 12" Resonant Engineering XXX? In a quest for my answer, i have poured over the specs for both subs.
    1. Both use Adire's patented XBL2 motor so both should a have a flat BL curve and
    a linear sound.
    ............................Brahma................ ...XXX
    2. BL.......................15.9..................... 17.1
    3. SPL 1w/1m............84.4.....................85.9
    4. FS.......................28....................... .27
    5. SD.......................436...................... 480
    6. Xmax....................28........................ 32
    7. Power (rms)..........1600....................1600
    Am i missing something are do the specs clearly point to the XXX? And interestingly, according to the SPL spec, is it not MORE sensitive than a brahma? I have read all of the threads concerning these 2 subs and have always noticed that people claim the brahma is the more sensitive of the 2 and the XXX will need more power to move the same as a Brahma. It is just the opposite no? The only spec that i am confused on is the BL. What is the significance of having a higher or lower BL?
    I will be powering this sub with about 800 watts RMS. Per Adire's website this would be almost enough to achieve the mechanical max of a brahma. Does the same hold true for the XXX. Intuitively, especially from the SPL specs, i would think so. Even more so with the XXX since it is more sensitive. Am I misunderstanding something here? Criticism/corrections welcomed.
    P.S. Before any of you post these are not SQ subs, you are wrong, check their websites. "Designed to be the ultimate in sound quality" is a direct quote from RE's website about their XXX line.
    Mark_ab's Avatar
    Mark_ab is offline The Alpha Male
    Feb 2002
    Edmonton, Alberta
    31
    4,210
    Re: 12" Brahma or XXX? Spec by Spec / Myth by Myth
    Not speaking from personal experience, as I have not heard an XXX in person as of yet, it is the general concensus of the knowledgable that the Brahma has slightly better SQ (in the form of transients and transparency) whilst the XXX is a touch louder (Xmax + Sd). To an untrained ear, however, the two will sound very similar. As a former Brahma owner, I can assure you that it is a very capable and potent subwoofer and I can only imagine the XXX is of the same leaf.
    There are other subwoofers in the same class, however. More options are always better, albeit harder to decide on. The Stereo Integrity Magnum D2 comes to mind, first and foremost. Cheaper, and IMHO, better sounding and louder (not opinion). Just something else to think about. Likewise, Crystal, Diamond, JL are other options as well.
    Is this not a reasonable place to park?
    GSteg's Avatar
    GSteg is offline Custom User Title
    May 2002
    whee!!
    2,831
    Quote Originally Posted by theimpaler
    Depends on your goal. too much or too little is a bad thing. But remember, that is only one part of the equation. What's listed is the peak BL. Peak means nothing, just a reference point. Don't worry too much about it.
    Being here long enough, I think everyone knows about the brahma and the XXX. lol!
    Hello GSteg it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    hold up you are saying the magnum D2 is louder than the xxx or that it will be louder with 800wattts considering the xxx is supposed to be all power hungry and what not
    limitkid7's Avatar
    limitkid7 is offline sell wite
    Oct 2002
    GA
    6,861
    27
    Quote Originally Posted by nismboy6986
    i HOPE THAT IS NOT BEING SAID...
    White Dodge Charger 3.5L V6
    Diablo Predator
    Alpine d310 TV
    Set of Focal Polyglass 6.5 Comps
    Set of Infinity Perfect 6.5 Comps
    1 JL Audio 300.4
    1 JL Audio 1000.1
    2 9510 mtx subs
    xjmadness's Avatar
    xjmadness is offline The beauty of green
    Dec 2002
    ATL
    1,708
    Quote Originally Posted by Mark_ab
    Wait......how can it be better sounding when u haven't heard the xxx.
    Of course the Mag will come to mind first, your an SI rep. lol
    xjmadness's Avatar
    Dec 2002
    ATL
    1,708
    a linear sound.
    You gotta remember. ..... With the spider/basket RE uses...32mm xmax really isn't a possible number.
    And Just an FYI. Mobile Entertainment did a review of the Brahma Mk1. Was tested to do 29.5 mm xmax. Mk2 is supposed to have a little more xmax from what it says on the Adire site. So you can pretty much come to conclusion that the xmax between the two is a very SLIM difference, not the advertised 4 mm difference
    Feb 2004
    Ridgecrest, CA
    27
    418
    Quote Originally Posted by xjmadness
    I believe he was saying that the Mag D2 is louder and better sounding than the Adire Brahma he used to own.
  9. #9
    geolemon's Avatar
    geolemon is offline Senior VIP Member
    Mar 2003
    Buffalo, NY
    385
    Actually, the basket and spider that both RE and Adire use allow for excursions up to around 33-34mm.
    The XXX is definitely pushing that limit harder than the Brahma... what I mean is, Xmech is not very far past Xmax on the XXX (and actually, it's Xsus limited... Xmag is actually beyond the capability of the basket!).
    With the Brahma, neither Xmag or Xsus are longer than Xmech... but it's really of little consequence, as both these drivers realistically have enough excursion to be more than comparable in that respect.
  10. #10
    bigbassman's Avatar
    bigbassman is offline Master of all things loud
    Apr 2002
    Southern WV
    32
    2,890
    they are virtually identical in performance, and sound, to most people..
    flip a coin, pick which you like to look at more...
    I've accumulated hour upon hour of ear time with every size Brahma and XXX made.. unless you're trained, **** retentive, or both (me), you'll tell almost no difference..
    *rant*
    dunno why people hang up on the 'SQ' portion on a woofer, and they'll pick a cheap set of front speakers in five minutes to cover the other 7 octaves...
    *end rant*
    Loyd L.
    SQL Prolly
  11. #11
    ghs_wrestler189's Avatar
    ghs_wrestler189 is offline CarAudio.com Elite
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    find a bias quickly, that always helps
    another way to tell is find someone you know with one or the other, then pick the one they don't have. who wants the same sub as their friends?
    AIM:ghs wrestler 171 - hit me up anytime.
    My Sounddomain Page
    1998 Oldsmobile Intrigue
    RE SX 15" D4 is here with a 5.0 cuft box tuned to 46 hz for comps.
    Port plug for 32hz daily.
    MTX 81000d give it 1225 rms at 2 ohms.
    143 on the new termlab (old box...5.1@36hz).
    Quote Originally Posted by jemorgan85
    ^I wish I were a woman .
  12. #12
    Steven Kephart's Avatar
    Steven Kephart is offline Senior VIP Member
    May 2003
    Seattle, WA
    36
    406
    Quote Originally Posted by ghs_wrestler189
    Apparently all my friends.
    Steven Kephart
    Adire Audio
    Sony CDXC-90 -- Sony XDP-4000X -- Adire Koda 6.1 -- dual Adire Brahma 10's isobaric -- Arc 1500dr -- Soundstream Reference 300
    "We got tired of the "Xmax" wars, so while everyone else is playing with bows and arrows, we went nuclear." Dan Wiggins
  13. #13
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    lol, that doesn't count
    My Sounddomain Page
  14. #14
    drkodin's Avatar
    drkodin is offline CarAudio.com Elite
    Sep 2002
    Gainesville, TX
    30
    581
    something that wasn't touched too well is that 800W isn't really going to be enough for the XXX unless it is in a large box (3^3 at least) for the 12" model to really show its SPL potential. i'm not going to speak for the brahma since i have only had experience with the 15", but if it were me i would consider a different sub if space could be a problem (or get a new/another amp).
  15. #15
    dbornotdb's Avatar
    dbornotdb is offline Custom Fabricator
    May 2004
    Bradenton, FL
    1,491
    19
    Quote Originally Posted by bigbassman
    *rant*
    *end rant*
    Loyd L.
    Most true thing I read all day.
    The bitter after-taste of a poor quality job will last far longer than
    the sweetness of that cheap price!
  1. 15" XXX Sealed? or 12" XXX Ported?
    By Omarvelous in forum Enclosure Design & Construction Help
    Last Post: 01-18-2004, 02:50 PM
  2. XXX 10" vs. XXX 12"
    By fb4076 in forum Subwoofers
    Last Post: 12-19-2003, 07:44 PM
  3. xxx or brahma
    By speedyo in forum Subwoofers
    Last Post: 12-17-2003, 09:06 PM
  4. 12" XXX vs 15" XXX
    By RFIRE15 in forum Subwoofers
    Last Post: 12-06-2003, 11:20 AM
  5. new brahma or xxx 15"...please help
    By kixazz2529 in forum Subwoofers
    Last Post: 12-03-2003, 05:57 PM
