Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Does 12" + (5.25" x 4) = 8"?
  1. #16
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,650
    106 Post(s)
    7469 Post(s)
    Re: Does 12" + (5.25" x 4) = 8"?
    Check out second skin
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  2. #17
    DJCool's Avatar
    DJCool is offline Junior Member
    May 2011
    Sydney
    Quote Originally Posted by HazeGrey75 View Post
    Just checked it out, The Luxury Liner Pro is just what I want..
    Awaiting on an email back from them for shipping cost to Australia..
  3. #18
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,650
    106 Post(s)
    7469 Post(s)
    Good choice.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  4. #19
    audioholic's Avatar
    audioholic is offline Moderator
    Aug 2003
    Parts Unknown
    23,747
    8 Post(s)
    411 Post(s)
    Quote Originally Posted by DarkScorpion View Post
    Midbass in kick pods, when built and aimed well, will almost always sound better than door mounted. I didn't know you were doing kicks, so I just assumed you were going door mounted. In this case, sealed kickpods will be fine and there shouldn't be a gap in frequency as you were worried about. Honestly, if you're having a pro build you kickpods, I would go with 6.5" or 7" midbasses. It's much more worth the effort.
    The vast majority of mids/midbass for car audio are designed to run infinite baffle (because most people mount mids in the doors). So stuffing them in some tiny sealed enclosures in the kick panels will only serve to hurt midbass response, not help it. The only realistic ways to get good midbass out of kick panels is to port them, or go aperiodic membrane. Neither choice is easy for a beginner, nor cheap to pay a pro to tackle. This is why I usually recommend speakers that the owner expects to play down to 80hz, should be mounted in well deadened and sealed doors (infinite baffle). The path length and loudness/intensity differences caused by mounting in the doors can (mostly) be made up for with some processing.
    OP, midbass is localizable (your ears can tell where the sound is coming from), so you want it to be in your front stage, in stereo. So mounting a single 8" sub in the back deck as your midbass setup would be far from ideal.
    No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
Tags for this Thread
