Re: Calling BS on "breaking in" subwoofers, prove me wrong.
Originally Posted by
Kyle_Keating
nitpick: The Re can't be the same for the hot coil and the BL can't be different.. I'm guessing the second test used the original Re value and then calculated an artificially low BL value? Either way, you get the right Qts and SPL, but its technically the wrong way of doing it.
The Re of the second test should be around 5.98 ohms and the BL should be 5.84 Tm... all other numbers remain. So you have a Dcr rise of ~0.5 ohms after heating up
I found it odd too that the Re wasn't higher when it was just ran hard. I'm guessing that's the only parameter that he missed, as the other parameters shifted accordingly.
Electrodynamic
"On a long enough timeline, the survival rate of everyone drops to zero."
Owner Stereo Integrity
Co-owner Obsidian Car Audio
Associate Sundown Audio
Simon Eichenberger is my hero
Power handling is not a power requirement! Don't install suckage!
Bookmarks
