Results 1 to 4 of 4
Reload Thread: Opinions on an SPL setup...
    Spkrman's Avatar
    Spkrman is offline Banned
    Jun 2003
    matteson, IL
    27
    3,166
    As it is now, I have 2 stroker 15's and 4 kicker dx700 amps. I need 4 1 ohm loads for the amps to put out their peak power...and I'm certain I can get louder subs than the stroker for my purposes.
    I have an 8 cub box..which fires straight into the cabin of my 99 monte carlo. The goal is to get the seats back on at some point...its gonna be tricky but its dooable.
    I am considering running a single 18" sub, but it would have to be a quad coil... Considering the DD 9917 or a XXX 18. I get a nice discount on RE, but I doubt that is going to fart out the best SPL..and I also doubt it will be able to take 4k on a daily setup. A single MT 18 is also an option.
    Also, I am thinking about tossing 2 different 15's in there, they would have to present me with 4 1ohm loads. Quad 2, dual 1...really don't care. I'm looking at the audiobahn immortals...but they get such varied numbers I'm a bit wary. Still...for the price they seem to be a bargain. I have used the search function and have read the horrible flaming you guys give abahn..lol. As it is, they are decent subs for the guy who wants to street beat around at 1 AM, which is why they get such a bad rep. The subs also tend to be overrated as far as power handling.
    Anyway, I'm worried that if I buy the immortals I will wish I would have spent more money and gone with a better sub. XXX 15's, SX 15's, 9515's...
    Another issue is that I'm not so confident 8 cubes net is good enough for a pair of 15's...especially something along the lines of a 9515.
    Any suggestions?
    Please don't give me the n00b treatment...I'm a mod over at realcaraudio...but typically the guys there don't have much experience with the subs mentioned...and it never hurts to get some opinions...nor does it hurt to start a good discussion
    bigbassman's Avatar
    bigbassman is offline Master of all things loud
    Apr 2002
    Southern WV
    32
    2,890
    Re: Opinions on an SPL setup...
    HIGH NOOB! j/k..
    I'll try to tackle this.. but I dont know much about this SPL thing I keep seeing..
    Quote Originally Posted by Spkrman
    you sure can
    aw.. then you gotta haul deadbeat friends around..
    throw the 9917 away, it won't stand up to 4kw daily, and sounds like rancid *** in play.. the XXX will do the best daily type, but is down from the 9917 in fart ability..
    the MT.. sounds better daily then the 9917, and is louder.. so there's my choice.. will also handle 4kw..
    honestly nothing wrong with the immortals quality wise.. they are built by a rather reputable builder.. thats the only audiobahn woofer I'd touch.. they aren't a gifted sounding woofer though.. see above post in reference to the 9917
    if you can't afford those, ability and knowledge can make the audiobahn fart well..
    if you can.. well.. install and ability will make them louder too
    it'll work well with them.. since you'll be aiming for a high tune, small volume will work best with your power..
    I've tested / installed / killed all of the woofers you've mentioned..
    My rankings...
    SPL FARTING
    1. MT
    2. DD 9917 (its a 9515 with a kevlar cone, resonance uses the exact same motor / coil / suspension on it)
    3. DD 9515
    4. XXX
    DAILY ABILITY
    1. XXX
    2. MT
    3. (tie) 9917 / 9915 they both sound like *** at full volume
    POWER HANDLING
    1. MT
    2. (tie) 9917 / 9515
    3. XXX
    hope this helps.. if not.. catch me on AIM, bigbassloyd and laugh at me..
    Loyd L.
    SQL Prolly
    Spkrman's Avatar
    Jun 2003
    matteson, IL
    27
    3,166
    Very informative...
    I can see this turning into a wall...although my car isn't the most wall worthy with those long doors. It does start off pretty solid though..which is a plus.
    Perhaps 4 d3000m's on a single mt18...that would be interesting
    DiB's Avatar
    DiB
    DiB is offline Meber
    Mar 2003
    San Diego
    29
    221
    What is wrong with atomic? I've seen those take insane amounts of power but then again I've never actually heard them play music. I bet a SoloX would work but kind of pricey.
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 06-30-2008, 11:33 PM
  2. Everything you need to know about every sub
    By Gauntlet in forum Subwoofers
    Last Post: 08-08-2004, 01:27 PM
  3. Average SPL for this setup?
    By rk7779 in forum General Discussion
    Last Post: 01-26-2004, 08:38 AM
  4. Opinions wanted on new setup
    By Kaos in forum General Discussion
    Last Post: 07-28-2003, 02:43 PM
