Who makes the best 6x9 free air subs?
Uhhh, there are no 6x9 subs. There are 6" subs, and 8" free air subs(kickers i believe).
Why do you want free air subs anyways?
Team Kicker (R.I.P.)
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
2008 Bassrace 130-139.9 Regional and National Champion
2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
One DD 9510 powered by two Sundown SAZ-2500's
Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
Kicker wiring throughout.
"free air"....wow I haven't heard that term since the early 90's.
1992 cocaine white Acura Legend ***TOTALED 9/2009****
Pioneer AVH-P4000dvd, Focal polyglass 165v1 front stage, (1) Fi SSD 12" sub ported
RF T3002, T5001bd, monster cable wiring, optima yellow top, batcap, fatmat sound deadening
**NEW VEHICLE**
2007 Chevy Impala SS LS4 5.3L V8
Pioneer AVH 3200BT
Kicker IX5001, IX5004, Kicker wiring
Kicker QS 6.5 comps, KS 6x9's, Xtant x12b 2.0 cubic box tuned to 33 hertz
Tangband makes 6x9" subwoofers. So does Audiobahn and MA Audio I believe.
Infinite Baffle subwoofers are nice since you're not using any trunk space. It's just like mounting speakers on the rear deck, where the front and back waves are separated
Hello GSteg it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
thanks GSteg
I Was going to say prob audiobahn. I heard a pretty wicked little pair of 6x9 subs by them...
Not saying to buy them but for what they were they were pretty cool.
I used to spend a lot of my free time here. It was fun I suppose. Still rocking the 9515 and Better Audio amp haha.
How's incriminator stuff these days?
yea..i rather get the Tangband over Audiobahn. Cost less, no bling bling (good thing in my eyes), probably sounds better, and did i say no bling bling?
Wow, somebody makes 6x9 subs. That's pretty much one of the dumbest things i can imagine. But if they sound good.....whatever.
EDIT: yeah, i have heard of them before, about 6 years ago.
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
I'd expect the TB to outperform the Audiobahn. 7mm of overhang on the TB, that's quite a bit for a driver that size, so real xmax could be anywhere from 8-10mm, which puts it at around 2-3x the displacement of most 6x9s.
W69-1042
Here is the main page.
Not bad for ~$65 for a pair of awesome 6x9 subs. Seriously, I'd recommend running them ported.
Seriously. Build little boxes to go underneath them, but leave them mounted in the rear deck. About 0.7cf@36hz for each driver. Just a simple 1x6 slot if you wish, about 11-12 inches long.
You think that'd be a waste, but honestly a pair of them with 100w each as long as you have infrasonic filtering at around 30hz. You'd be amazed just how loud you can make them get.
Probably outperform most sealed 10s or 12s you can get for around the same amount of money, and with less power.
I have an 04 Acura TSX and just wanted a cheap 6x9 upgrade to clean up my bass until I go with a 10-12" sub/amp setup. How would the TB's compare to similar low price JBL's? Like these:
http://hypaudio.com/hypaudio/p9632.html
Or the Kickers:
http://www.onlinecarstereo.com/CarAu...roductID=11900
The 6x9's only get sub bass freq's from the stock amp/xover so I'm not concerned with higher freq quality on any of these. Also, I don't want to build a box or make any major mods, I just want something I can drop in there easily and run off of the stock amp until I upgrade to a better sub setup later. Which of these would be the best quick fix for my application?
Thanks,
Scott
if your wanting to just clean up the bass then I would go with the TB's. The others are not subs. I just put the TB's in my G35 cpe and I think they sound great. The bass is tight and fast and imho opinion sounds just as good as one 8 or 10" sub enclosure in the trunk.
Thanks cinergi1,
I realize the others aren't subs but from the specs it looks like they'll go lower freqwise than the TB's. Also, they are more sensitive so won't they be louder/more efficient given the same amp? I'm splitting hairs on price with any of them so I could care less that the tweeters in the coaxials won't be used and basically be a waste. Again, I was just judging from the low freq. response and sensitivity.
Thanks again for your input,
Scott
Cinergi1, how many watts are you running to those 6 x 9's? You dont have a box underneath them do you? Do they sound good for rock/metal music? Thanks. Im verrry interested in 6 x 9 subs now that i saw this thread :readytogo
Oh boy! I'm all excited now. I could drop my 2 way 6 x 9's that im using as rear fill and put in some subs there. Run my components up front and subs in the back all off 1 4 chan amp. Then, i could finally have my trunkspace back and pocket some cashe from selling my 12. Muahahahahahhaha. I like I like.![]()
Would having a speaker baffle behind the TB's help or hurt if you have no space to build a box behind them? Something like this (5" deep one):
http://www.crutchfield.com/S-LIhAJNb...=0&cc=01&avf=N
Should I make a hole in them to act as a small port?
I thought about getting these to mount underneath the back of the drivers but I don't think I have enough clearance from the trunk rods, etc.:
Thanks for any input.
Bookmarks
