Results 1 to 4 of 4
Reload Thread: RD Sonance making funny noise at high volume.
    stanky1219's Avatar
    stanky1219 is offline Banned
    Feb 2010
    tampa,fl
    31
    918
    Ok here is the deal when i turn my gain up on my amp , and very loud low notes play i hear a sound similar to a loose speaker wire. almost like the amp cuts off for a split nano-second.
    i have come up with a few ideas myself and havent had a chance to check either out yet.
    1. i am only feeding this amp with 6 ga scoshe power wire (low voltage?)
    2. i am using scoshe rcas (Crappy signal?)
    3. i remember hearing something about rd tinsel leads shorting out on the basket when cone is under heavy excursion. (Leads are good condition as far as i can tell)
    4. cheap sub amp is clipping at high volume??
    what do you guys think?
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    33
    2,825
    11 Post(s)
    Re: RD Sonance making funny noise at high volume.
    That would be a mix of mostly 1 & 4 IMO.
    stanky1219's Avatar
    Feb 2010
    tampa,fl
    31
    918
    so time to upgrade my cable and i wasnt keeping the amp anyhow. i hate hifonics. its just temporary,i put it in yesterday. got it for a cheap 12" sub i had laying around. i want a pc2350 to match my other ppi's
    do you think the 6 ga hooked to a twin fuse block will be ok to power the pc250 and pc275 off of?
    and then i can upgrade to a seperate run of 4 or 2 ga. when i get a better sub amp?
    stanky1219's Avatar
    Feb 2010
    tampa,fl
    31
    918
    i fixed it. My battery cables were loose as hell. apparently when i was running no amps for a week or two i didnt tighten the cables when i put my new battery in.
  1. Replies: 1
    Last Post: 07-30-2009, 06:24 AM
  2. Amp making very high pitched noise
    By Rashaddd in forum Wiring, Electrical and Installation Help
    Last Post: 10-06-2008, 03:57 PM
  3. sub makes stastic noise at high volume
    By sinosic in forum Wiring, Electrical and Installation Help
    Last Post: 05-24-2007, 06:44 AM
  4. Making internal volume smaller
    By Deamonicus in forum Enclosure Design & Construction Help
    Last Post: 06-04-2005, 06:20 PM
  5. subs making funny noise
    By MrSwiss in forum Wiring, Electrical and Installation Help
    Last Post: 03-29-2005, 04:04 PM
