Results 1 to 6 of 6
Reload Thread: Which 10" sub for ~.65ft^3, sealed for SQL? CDT QES-1020, Fi Q10, or Peerless XXLS
    thaar411's Avatar
    thaar411 is offline Member
    Oct 2004
    Denver, CO
    46
    Sub will installed in a 2002 Pontiac Firehawk (Trans Am) in a drivers side stealth box in the rear well. The box volume will roughly be .6-.7ft^3. The drivers I'm considering is the Fi Q10 the CDT QES-1020, and two Peerless XXLS. I listen to pretty much everything, however, hip-hop and rock are played a majority of the time, and am looking for an SQL setup. Price doesn't matter. Here are the specs for each:
    CDT QES-1020: http://cdtgold.com/pdfs/QES-1020W.pdf
    Free Air Resonance: 39.8 Hz
    Voice Coil DC Resistance: 3.42 Ohms
    Voice Coil Inductance @ 1 kHz: 4.7 mH
    Mechanical Q (Qms): 6.63
    Electrical Q (Qes): 0.403
    Total Q (Qts): 0.38
    Compliance Volume (Vas): 11.0 l; 0.39 ft3
    Moving mass, Diaphragm: 247 Gr
    Motor Force Factor: 22.89 Tm
    Nom. Diameter: 10” (250mm)
    Cone: Kevlar-Paper Honeycomb
    Surround: NB Rubber
    Sensitivity: 84.4 dB
    Power Handling: 500 WRMS (1000W Pk)
    Frequency Response: 10 ~ 400 Hz
    Nominal Impedance: 4 Ohms
    Voice Coil Diameter: 2.6” (66mm)
    Xmax: 20mm
    Magnet Weight: 140 Oz stacked
    Fi Q: https://ssl.perfora.net/www.ficaraud...iew.shopscript
    Q10
    DUAL 1 | DUAL 2
    Fs: 34.1 Hz | 34.0 Hz
    Re: 0.70 Ohms/coil | 1.4 Ohms/coil
    Qms: 7.31 | 7.38
    Qes: .37 | .37
    Qts: .36 | .36
    Mms: 230g | 2235g
    Cms: .88mm/N | .88mm/N
    Sd: 310cm^2 | 310cm^2
    Vas: 11.8 l | 11.8 l
    Spl: 83.3dB 1W/1m | 83.2dB 1W/1m
    Bl: 13.9 N/A | 19.6 N/A
    Xmax: 28mm
    Rms: 1000W
    Sealed box: .2-.6 cuft HQTS
    Ported box: .5-1.2 cuft @ 28-33Hz
    Sub OD: 11.000”
    Cut ID: 9.250”
    Mounting depth: 6.500”
    Displacement: 0.12cuft
    Peerless 830876: Parts-Express.com:
    Power handling: 175 watts RMS/350 watts max
    VCdia: 2"
    Le: 1.5 mH
    Impedance: 4 ohms
    Re: 1.7 ohms
    Frequency response: 39-2,000 Hz
    Fs: 39 Hz
    SPL: 92 dB 2.83V/1m
    Vas: 0.83 cu. ft.
    Qms: 6.79
    Qes: 0.47
    Qts: 0.44
    Xmax: 12.5 mm
    Peerless 830842: http://www.madisound.com/catalog/pro...oducts_id=1467
    Znom 4 ohm
    Re 2.6 ohm
    Le 4.2 mH
    fs 19.2 Hz
    Qms 8.74
    Qes 0.19
    Qts 0.19
    Mms 133.8 g
    Cms 0.52 mm/N
    Sd 352 cm2
    BL 14.9 N/A
    Vas 88.4 ltrs
    Xmax 12.5 mm peak
    Voice Coil 51 mm
    Sensitivity
    2.83V / 1m 88.4 dB
    Power (IEC) 350 W
    Magnet weight 2.4 kg
    Many thanks!
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,649
    4 Post(s)
    1032 Post(s)
    Re: Which 10" sub for ~.65ft^3, sealed for SQL? CDT QES-1020, Fi Q10, or Peerless XXL
    SSA Shop - SoundSolutionsAudio 10" SSA ICON Sub woofer
    IXL-10 v2 SL [IXL-10 v2 SL] - $109.00 : Mach 5 Audio
    idmax
    all great sealed drivers with heart pounding ability while staying clean
    if you want the ultimate seALED sub then
    the audiopulse revo or tc sounds-2000 is what you want
    thaar411's Avatar
    Oct 2004
    Denver, CO
    46
    The SSA is the only driver that would work, and one I haven't considered. Both the IDMAX and the IXL require more airspace. I'll have to check out the others you mentioned as well.
    TechFreak's Avatar
    TechFreak is offline Member
    Feb 2010
    North Carolina
    97
    2 Post(s)
    Quote Originally Posted by thaar411 View Post
    Hey thaar,
    I'm putting a RE SE-10 in my stealth box in my Z28,we'll see how it sounds. I was looking at the mach5,but the shipping put me off.
    thaar411's Avatar
    Oct 2004
    Denver, CO
    46
    The IDQ rather than the IDMAX is an option as well. Too many options. I'm about to crazy...
    mclerico83's Avatar
    Oct 2009
    tampa
    7,649
    4 Post(s)
    1032 Post(s)
