Results 1 to 9 of 9
Reload Thread: So, difference between a 12 and a 15? Just a tad.
    silenkiller's Avatar
    silenkiller is offline CarAudio.com Elite
    Sep 2007
    zz
    1,088
    1 Post(s)
    So for everyone who's always asking, i.e. Do I want a 12 Inch FI Q or a 15 Inch FI Q??? omgggggg
    I did a winisd for both of them and on the same power. If you check the graph, not that this is all inclusive by any means, but they are pretty **** close.
    Green is the 15. Red the 12.
    They KEY here is that the 15 is in its correct space. Don't go getting a 15 and jamming it into a 2.5 cuft enclosure cuz its "a 15 so it has to be better".
    1999 Pontiac Grand AM SE
    Kenwood KDC-X991
    CDT 3-Way Setup
    ES-01 Tweets
    HD-4 & M6 Mid/Midwoof
    JL 300/2
    Two AQ HDC3A 15's
    Two AQ2200D
    CnD Batt in Trunk
    Stinger Isolator
    250 Amp H.O. Alt Mechman
    amartin_72's Avatar
    amartin_72 is offline Banned
    Nov 2005
    Madison , WI
    1,777
    Re: So, difference between a 12 and a 15? Just a tad.
    A 15 in 4.5ft will kill a 12 in 2.5ft same power. Box space always wins and if its optimum for the subs it will always be louder and lower. Theres no replacement for displacement. Win ISD is not real life. Adjust the sensitivity on the sub paramaters and it messes it all up and since sensitivitys are all measured differently it throws win isd off when comparing two subs. The one rated at higher sensitivity will win most the time even though in real life it could be the opposite.
    Sep 2007
    zz
    1,088
    1 Post(s)
    Quote Originally Posted by amartin_72 View Post
    What I'm getting at is "kill" is kinda taken different from person to person. If being 2-3 db higher at 30-40 hz is killing for someone, it may not be much of a difference for someone else. You know, to not justify someone going crazy and walling off their trunk or some other labor intensive thing. (Not talking about competitions)
    Kenwood KDC-X991
    CDT 3-Way Setup
    ES-01 Tweets
    JL 300/2
    Two AQ HDC3A 15's
    Two AQ2200D
    CnD Batt in Trunk
    Stinger Isolator
    azimuth's Avatar
    azimuth is offline funded*by*soros
    Mar 2006
    Denver, Co
    41
    9,053
    9 Post(s)
    a 15 has a significant edge in cone area. a 12 and 15 of the same model sub, on the same power, both in well designed/same type enclosure, will noticeably be louder with the 15.
    2003 chevy s-10 ext. cab
    hu: jvc kd-avx1
    precision power 356cs components
    front amp: infinity 475a
    sub: diamond audio d6 10d4
    enclosure: 1.1 cubes ported tuned @ 31hz
    sub amp: JL G1700
    GetLikeMe's Avatar
    GetLikeMe is offline Stuntin' is a Habbit!
    Jul 2009
    SoCal
    2,539
    1 Post(s)
    I had my 15" in 3.5 [email protected] and it ****in bangedddd
    Refs: inapontiac, FASTIMES, donpisto, Mike465, TC2k15x2, HyPnAwTiKpImP, stl_styles, SPL140.2, 07ramjam, astrolade, wu501, emperorjj1, dropped_mazda, cuseikan, Zeuslicious, smalltown, dtbrown, svtjoe, Pioneer~Saturn, JoeSmith502, littlepucker, lilmaniac2(x2), rumblebee2, adas, adrian1185, Vermithrax, kmanian, teamsolo, schackel, HmoobSoCal, JHardee, 01 S 10, atsaubrey, tc3k101
    CarAudioNewbie9's Avatar
    CarAudioNewbie9 is offline CarAudio.com Elite
    Nov 2009
    BFE
    844
    Holy **** guys. 2.50 inch boxes for 12s? My Diamond Audio D6 is in a .90 cubic feet box. lol
    skmfkr's Avatar
    skmfkr is offline CarAudio.com Veteran
    Jan 2005
    Savannah, GA
    31
    6,309
    differencebetween a 12 and a 15 was 4db for me.
    '08 Ford Escape XLT
    2 12" DC XL's + 2 RD D9s
    Selenium and Crescendo on AQ4X90
    skmfkr's Avatar
    Jan 2005
    Savannah, GA
    31
    6,309
    difference between a 12 and a 15 was 4db for me.
    '08 Ford Escape XLT
  9. #9
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    wow, learn to use winisd before you attempt to judge a sub with it. Your looking at the gain plot.... That shows frequency responce relative to itself, hence the -1, -3, etc. What actual SPL levels your getting is going to be different. Do that again, click the SPL tab buttom up top then you can see the actual difference in SPL. The frequency response is similar because a 12 needs about half the airspace to sound similar, just won't be as loud.
    Despite what 99% of this forum thinks modelling programs do work if you know how to use them. More importantly how to interpert what they see to fit their goals, when taking into account cabin gain. If you can do this, you can get alot closerthan most people who simply use standard recommendations, such as "well XXX brand likes to be tuned at 43.19249hz.. Anyway I'm done ranting lo and i helped lol..
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
