Results 1 to 9 of 9
Reload Thread: 2 or 4 ohm dual voice coil subs for mono amp?
    Sorrows End's Avatar
    Sorrows End is offline Junior Member
    Jan 2010
    Tempe, AZ
    Good Morning Everyone,
    I'm looking to upgrade my subwoofer setup in my Mustang.
    I am interested in getting a pair of Alpine R-Type 10" subs. These are dual voice coil woofers that come in a 2ohm and 4ohm variety.
    I was also looking at using an Alpine MPR-M1000 monoblock amp to power the pair of subs.
    My question is this: Which ohm rating of subs do I need to get to have the amp properly power the set?
    I do apologize for the novice question. No, I will not be installing these myself, I am just trying to get better understanding of the technology involved.
    Thank you kindly for reading this.
    that r/t guy's Avatar
    that r/t guy is offline Junior Member
    Jan 2010
    Lebanon PA
    21
    Re: 2 or 4 ohm dual voice coil subs for mono amp?
    what is the min independance of the amp?
    Jan 2010
    Tempe, AZ
    Quote Originally Posted by that r/t guy View Post
    From the product listings it shows: Speaker Impedance: 4 or 2 Ohm
    A direct link to the amp I am looking at is : http://www.onlinecarstereo.com/CarAu...MRP-M1000.aspx
    Thank you for your help.
    Jan 2010
    Lebanon PA
    21
    you would want the dual 2ohm to get the most out of them with tht amp... i would post the link but not sure how but crutchfield.com has easy sub wiering diagrams that will help
    Jan 2010
    Lebanon PA
    21
    Jan 2010
    Lebanon PA
    21
    ha ha figured it out hope that helps
    loud-n-low's Avatar
    loud-n-low is offline i give ladies 30mm xmax
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    it produces full power at 2 ohms,get two dual 2's
    Pioneer deh-p7200HD
    Image Dynamics ctx65cs
    Soundstream reference 2.640
    Audiopulse Axis 12/TC sounds lms-r 15
    Sundown sae-1200d
    refs: SPY, oxsign, orangelss, projectpechkin, Dave_Damage, mjbailey21,Jerseyboy,Snoopysnooper
    Jan 2010
    Tempe, AZ
    Thank you for the replies gentlemen.
    I do apologize for the novice question. Trying to get a better understanding of what everything actually does rather than just purchasing what the installer recommends. =)
  9. #9
    loud-n-low's Avatar
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    personally i would buy one 15" unless you already have the 2 10" box. if you go with one sub, you need a dual 4 ohm with the mrp-1000
    Pioneer deh-p7200HD
    Sundown sae-1200d
