Results 1 to 5 of 5
Reload Thread: Subs should like theres an echo or a hallow sound.
    jlaudiow6's Avatar
    jlaudiow6 is offline Member
    Apr 2003
    san diego
    39
    121
    Subs sound like theres an echo or a hallow sound.
    I just built a box for 2 12w7. They sound good but theres an echo sound or a hallow sound on some bass tones.
    I did build the seald enclosure bigger than the recomended size for the speakers. I had to do that for the speakers to fit where i wanted it to.
    I'm thinking of adding the leftover fleece(2 yards) To inside the box as an insulator. Since the box is too big I was wondering if the fleece will count as a displacement inside the box?
    Cause ive seen some boxes that are almost completely filled with insulators.
    thanks for the help
    triphop's Avatar
    triphop is offline im not heaven sent
    Aug 2002
    mexico
    36
    287
    Re: Subs should like theres an echo or a hallow sound.
    are the subs in separate chambers?
    maybe theres a leak... just guessing... see if theres anything wrong visible to ur box
    how are they wired? to what kind of amp?
    what feeds me destroys me
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    40
    2,433
    4 Post(s)
    Icon33 Re: Subs should like theres an echo or a hallow sound.
    Read the spec's on the correct box displacement. Its critical to get the correct displacement with a sealed box cause if you don't it will sound"hollow".Standard is from 1.0 to 1.5 cu ft per sub(12") depending on the speaker.
    jlaudiow6's Avatar
    Apr 2003
    san diego
    39
    121
    Yes the subs are in seperate chainbers and the specks are alittle bigger than recomended. I had to do that just to make the speaker fit where i wanted it to.
    Will the fleece(or carpet) be a good displacement to take up some of the extra space thats unneeded?
    Or do i need to put some extra wood in there as displacement?
    CELLERBR's Avatar
    CELLERBR is offline CarAudio.com Elite
    Sep 2003
    KY
    36
    1,464
    22
    How much bigger is it man????
    Representing Microsoft Paint one Signature at a time........
  1. New plan..Treo..need help on these subs
    By 60_cent in forum Subwoofers
    Last Post: 04-20-2006, 02:15 PM
  2. no sound from subs, help!
    By sk24iam in forum Wiring, Electrical and Installation Help
    Last Post: 11-09-2003, 11:36 AM
  3. Subs hit no sound tho
    By paul83085 in forum Subwoofers
    Last Post: 07-31-2003, 10:44 PM
