Results 1 to 9 of 9
Reload Thread: speaker & sub w/no box has no bass....why????
    Gilliz's Avatar
    Gilliz is offline Habitual Tendencies
    Nov 2003
    MidWest
    347
    hello,
    can anyone tell me why a speaker/sub has no bass when it is not enclosed??
    i heard something about how the waves cancelling each other out......but im not sure ...
    thx
    cw
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    41
    2,433
    4 Post(s)
    Re: speaker & sub w/no box has no bass....why????
    Try to imagine a drum with nothing but the skin. or a guitar with no back. The enclosure is like a drum being hit.
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    34
    13,810
    from the way that it has been explained to me, this is what i understand...
    the box helps to contain the back wave coming off of the backside of the cone. in a sealed box it keeps the back wave from coming around and cancelling with the front wave. in a vented box the back wave is actually slowed down and alligned to positively interfere with the front wave.
    hope this helps to shed some light on it.
    Gilliz's Avatar
    Nov 2003
    MidWest
    347
    EXACT answer i was looking for ........
    thx alot man
    hoss's Avatar
    Sep 2003
    34
    13,810
    no prob, its what we are here for
    BumpinDoug's Avatar
    BumpinDoug is offline 15A's B!TCH
    Jun 2003
    Atlanta
    33
    523
    Theres more too it also. It can be explained in scientific terms by using phsyics.
    For every force exerted there is an equal and opposite force exerted as well. For instance, when a person pushes on a wall with a force of 100 N, the wall also pushes back on the person with the same force of 100N. Thus, when a sub moves back with a force of 100 N the air pushes back with a force of 100N, but the amount of air in an open space compared to the mass of the sub cancels out the sheer matter of the air is much smaller conatined to and open environment. Thus a force is pushed back onto the sub and sound waves can be pushed outward. In a ported box this works the same as the air bounces off teh back of the box and goes back to the sub while moving air out of the box also. Hope that helped if you could understand any of that
    Jun 2003
    Texas
    38
    37
    Quote Originally Posted by BumpinDoug
    you're physics is a bit off........Newton's Laws do apply, but they have to be more specific in this case.......what it does have to do with is pressure and phase.....just as Hoss posted
    pressure is created on both sides of the cone, but one side is always 180 degrees out of phase of the other side, meaning when one is a compression, the other side is always a rarefaction.......and since a high pressure system always spontaneously tends to settle into a low pressure system, the high pressure on one side of the cone will spontaneously seek the low pressure side, ie: the back wave........so one wave has been pressurized a certain amount above atmospheric pressure (+1), and the other has been decompressed the same amount below atmospheric pressure (-1), thus canceling out and settling into a ground state of atmospheric pressure (+1-1=0)
    hoss's Avatar
    Sep 2003
    34
    13,810
    doug, i think what you are trying to explain is the Q of the enclosure, not why ouput is increased when you put a woofer in an enclosure. it sounds to me like you are describing the "air-spring" effect. but as far as i know the force that a box imposes on a woofer does not have much of anything to do with output, other than the fact that a large sealed box will decrease output.
    edit: you beat me to it man
  9. #9
    BumpinDoug's Avatar
    Jun 2003
    Atlanta
    33
    523
    Ah ***you im never wrong!!!
  1. Bass Songs
    By flyasspimp in forum General Discussion
    Last Post: 08-22-2005, 11:54 PM
  2. deeper bass in a 28 hz ported box vs sealed?
    By BulldogSr04 in forum Subwoofers
    Last Post: 12-13-2003, 09:34 PM
  3. Bass box size
    By Sharp_Shoota in forum General Discussion
    Last Post: 10-20-2003, 09:04 PM
  4. Tips/Suggestions for Speaker Ring of Fiberglass box
    By Chris02NeonSXT in forum Enclosure Design & Construction Help
    Last Post: 10-05-2003, 07:03 PM
  5. speaker bass...
    By mm_55 in forum Speakers
    Last Post: 07-22-2003, 03:29 PM
