Results 1 to 15 of 15
Reload Thread: HeLp Me dO iT RiGhT ThIs tImE!
    marvelusmarvcus's Avatar
    marvelusmarvcus is offline Junior Member
    Sep 2009
    williamsburg, va
    24
    ok, back to the drawing board.
    i need some help. i need some recommendations on a subwoofer. i have a porsche carrera and the space in the back behind the seat is very small. i recently had a custom box built for a jl 13tw5. that jl sub blew for some reason, maybe too much power. i have decided to get a different speaker for this application and i will most likely need to have the box redone.
    my options are limited. the current sealed box was built for the jl sub and has an airspace of about .80 cubic feet. i cannot have a bigger box or i will lose my rear view. i am using a fosgate 800.2 amp for the sub.
    at this point i am ok with spl or sq. i just want something durable that sounds good. i would spend up to $500 if justified, although i do not need extreme bass as the sub is pretty much behind my head.
    i do not wish to mount the sub anywhere else. i know there are options for other locations but it makes the most sense behind the rear seat.
    you guys are the experts, please help me out here. im hoping that my options are not just shallow mount subs as they seem to be very fragile. i would love to get a 12" back there :>
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Re: HeLp Me dO iT RiGhT ThIs tImE!
    Worry about why that last one blew first...
    l7runner's Avatar
    l7runner is offline Amidst the Static
    Jan 2008
    NC
    1,005
    whats your mounting depth?
    HU: Pioneer 880-prs
    Mid/High Amp: MB Quart DSC4125
    Front Stage: PG mids/Vifa tweets running active
    Sub Amp: DD Z1
    Sub: 10" Mach 5 SPL/Hybrid 1.25ft^3 @ 38hz
    DC Power Alt
    mxer657's Avatar
    mxer657 is offline Web Designer :]
    Oct 2009
    Charlotte, NC
    1,303
    2 Post(s)
    thats actually a good sub for that application..You might be overpowering it though.
    It's one of the few thin subs that still have quality. Most other companies like DD, DC, Sundown, etc. don't make thin ones because they are for competition
    So...figure out why it went bad maybe need an appropriate amp, could be incorrectly built box, and have the shop inspect the sub. Maybe coils got burnt. Need more info.
    But you can send in your JL under warranty :p
    Quote Originally Posted by CarAudioNewbie9 View Post
    They prolly measured it inside the car or something to get a bigger number.
    "Try not. Do, or do not try. There is no try"-Yoda
    Sold to: 85_blazer (Double Din Touch Screen), PowerShow (PG 600.4 amp), danielsmommy19 (Diamond Audio D3 1000.1), irish0170 (Kenwood KOS-V1000 + KOS-V702 + KDV-S211P), anthonyp07 (PDX 4.100), vwbuskid (BNIB Leviathan)
    Bought from: michaellane (4 10" subs + Box), f150john (1/0 gauge wire), Teampsi (sub parts)
    Traded with: 46panel (t2000.1bd for AQ 1200 +cash), Beaver1992 (AQ1200 + cash for AQ2200),
    cx-7heaven's Avatar
    cx-7heaven is offline The dash don't be silent
    Sep 2007
    Savannah, Ga
    1,582
    62 Post(s)
    IIRC, the tw5 is a 500rms sub, the 800.2 is an 800 watt amp..... coincidence?
    edit: 600 rms, with about 300 reccommended from jl.
    http://mobile.jlaudio.com/products_s...p?series_id=30
    '08 Dodge Dakota Crew Cab
    Head: Clarion VZ401
    Mids: Diamond D9-71 component set
    Subs: Team PSI platform 2 18"d4 in 4 cu.ft
    Amps: Soundstream REF 4.760, Hifonics BXI2610d @ 2ohms(1700 rms)
    refs-here: Spooney, mj-tc, Cleansoundz, rc10mike, kmanian, cozce, Spy, ewoevo, stylez12321, stirfri4202,nihl8ion
    ssa: sundownz, [email protected], BKOLFO4
    DIYMA: lashlee, nigel1977, Ibizonacid
    CACO: snyderd758
    Skullz's Avatar
    Skullz is offline Junior Member
    Sep 2009
    Michigan
    19
    I'm not sure if they have released these yet but this would be a good option to go with.
    http://stereointegrity.com/bm.php
    Sep 2009
    williamsburg, va
    24
    i dont know if i will ever truly know what happened. i am getting a refund on the sub. the audio shop said it was a bad voicecoil. i think i agree that too much power was possibly used. however, if i used any less, the sub would barely move. i think i need a sub that will put out a little more. if i only gave it 250-300 watts, it would be a disappointment and not keep up with the 6 focal speakers.
    are there any shallow mount subs that can take some power?
    are there any regular subs that would fit into a box with .80 cu ft air space?
    any way to get (2) 10's or a 12 back there?
    thanks guys
    dvldogyut's Avatar
    dvldogyut is offline CarAudio.com Elite
    Sep 2009
    loretto, tn
    33
    1,199
    Quote Originally Posted by marvelusmarvcus View Post
    thanks guys
    Memphis has a pretty bad a** thin line sub. My buddy has one I don't know much about it other than it sounds really good.
  9. #9
    Sep 2009
    williamsburg, va
    24
    i checked the memphis, looks promising, i just hate buying something i am so unfamiliar with.
    anyone used the fosgate p3? i have had a few recommend it and could hear one before buying.
  10. #10
    cx-7heaven's Avatar
    Sep 2007
    Savannah, Ga
    1,582
    62 Post(s)
    How deep is that box? there are 12's that wil work in .8, but depth may be a big problem here.
    Head: Clarion VZ401
    CACO: snyderd758
  11. #11
    stangman67's Avatar
    stangman67 is offline CarAudio.com Veteran
    Feb 2009
    Seattle
    2,519
    I have used the non shallow p3, and I loved it. Great sub for the price. took every bit of 600rms with ease.
    04 Focus
    4 sa-8
    Solid f2500
    JVC highs amp
    Parts express drivers for high end
    REFS
    Sold to: RidnClean, thegreatestpenn, MrChow, Tuck05, whitem1ke88, moo_awn, Ray21, ben031681
    Bought from: Mike465, Shinju (x3), azngotskills, Hazardous0388
  12. #12
    Sep 2009
    williamsburg, va
    24
    anyone used the fosgate p3 shallow?
  13. #13
    snb778's Avatar
    snb778 is offline blaugh!!!!
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    i'd look into the S.I. shallow mount
    Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle (picked up box) mlstrass (box design) Mazzasec (bought 18" RD Alpha from him) SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic on steave meade forum. NJTStang11- picked up 18" SSX and box from him krispy cream SCAMMED ME $200!!!
    2 Pistol Shrimps in a 4.0 cu^ft box tuned to 32 hz for the WIN !!
    "You can't compare, don't stare, cause I got the ultimate Mary Jane"
  14. #14
    skateboardkid's Avatar
    skateboardkid is offline CarAudio.com Elite
    Nov 2007
    Ashland oregon
    1,430
    STEREO INTEGRITY pwns Fosgate
    “It takes only one drink to get me drunk. The trouble is, I can't remember if it's the thirteenth or the fourteenth.”
    -Benjamin Frankin
    Quote Originally Posted by FoxPro5 View Post
    True midbass begins when the impact is so accurate and realistic that it sounds like someone is beating on the front part of your dash with a baseball bat.
  15. #15
    corrie32's Avatar
    corrie32 is offline CarAudio.com Elite
    Jul 2009
    atlanta ga
    583
    15 Post(s)
    Mb quart makes some new shallow mount subs, check them out http://www.sonicelectronix.com/item_...t+RLP+304.html
