Results 1 to 12 of 12
Reload Thread: Subwoofer box- bolts for terminal connector?
    chevyaddict83's Avatar
    chevyaddict83 is offline Senior VIP Member
    Apr 2009
    medway,ma
    279
    28 Post(s)
    As stated in the title, i see people using bolts as terminal connectors in sub boxes? can someone explain?
    99mitseclipse's Avatar
    99mitseclipse is offline say what?
    May 2009
    omaha, NE
    60
    Re: Subwoofer box- bolts for terminal connector?
    I use it for looks. Good connection if it's a conductor.
    TEAM LETHAL BEATZ
    1999 Mitsubishi Eclipse
    HU: pioneer avh-4000
    front: db drive 6.5 mids and 1" tweets
    rear: db drive 6x9
    sub: kicker solo x 18
    amp: ma audio hk4000
    batts: 2 optima yellows, 1 optima blue
    box: 8.5 cubes, 38hz
    marcotheclepto's Avatar
    marcotheclepto is offline CarAudio.com Veteran
    Feb 2009
    United States
    2,464
    1 Post(s)
    wire subs to desired impendence attach ring term et cetera... drill hole insert bolt attach pos and neg and your done?
    need a box design? click here or email [email protected]
    1997 Buick LeSabre Limited
    wiring:2 runs (2 pos 2 neg) of 0 ga big 3 in 0 ga 50 ft of knu cca, and 36 ft of the wire loudcartunez sells...
    Head unit: Kenwood excelon KDC-X692
    Sub Amp: Autotek Mean Machine 4000D
    Subs: 2 custom 15s built by ssackett
    Sub box: 4th order bandpass 2.52 cubes sealed 5 cubes ported tuned to 59 Hz
    comp amp: CDT SQA4100
    Comps: 2 sets of CDT CL-61i
    Deadening: 50 cld tiles and 20 sq ft of damp pro.
    feedback please post if you have had any transactions.
    http://www.caraudio.com/forum/showth...19#post6113819
    Feb 2009
    United States
    2,464
    1 Post(s)
    Quote Originally Posted by 99mitseclipse View Post
    most use for looks, i will use one because it makes me feel like its better sealed than say a 1 inch drilled hole.... for term cup
    Apr 2009
    dallas tx
    6,930
    55 Post(s)
    most spl ppl use it for ohm load ease. so u dont have to take the sub out to wire it down. mines like that. 1.4 then switch a couple wires then poof, .35
    May 2009
    omaha, NE
    60
    Quote Originally Posted by marcotheclepto View Post
    Agreed. Makes it very easy to seal off.
    TEAM LETHAL BEATZ
    rear: db drive 6x9
    May 2009
    omaha, NE
    60
    Quote Originally Posted by basscort2009 View Post
    I never thought of this, and from now on every box I build I'm doing it. You're a genius..
    TEAM LETHAL BEATZ
    rear: db drive 6x9
    lowriderram_95's Avatar
    lowriderram_95 is offline VW Surgeon
    Jun 2007
    Little Rock, AR
    28
    1,658
    1 Post(s)
    34 Post(s)
    easy to seal, stays connected better than the push tab terminals and looks alot better IMO
    (b):hoxie08, dacheatham, Mr.Foca, RetroAudioInc, pro-rabbit (t):dave_damage, j.clark90, tubermaguber
    RE XXX v1 10
    SQ2200.1
    AQ120.4
    SQ200.2
  9. #9
    Abarca's Avatar
    Abarca is offline Member
    Jan 2008
    Dub-C
    51
    can anyone show a picture of what it actually looks like, just the bolts??? ive seen them but only installed...
  10. #10
    Apr 2009
    medway,ma
    279
    28 Post(s)
    Any specific bolt? or just regular stainless? I would imagine i dont need grade 8, although thats all i have laying around.
  11. #11
    May 2009
    omaha, NE
    60
    Stainless isn't the best conductor, but it works. Can be achallenge to find something else
    TEAM LETHAL BEATZ
    rear: db drive 6x9
  12. #12
    Korn4Life's Avatar
    Korn4Life is offline SUB LOVE
    Feb 2008
    PA
    7,249
    This is the reason I used bolts also... Works great
    Feedback Thread's
    http://www.caraudio.com/forum/showth...21#post4632421
    http://www.caraudio.com/forum/showthread.php?t=317112
    Current Setup
    Headunit= Pioneer 790BT
    Highs/Mids= 4" Lightning Audio & Kicker R25 Tweeters
    Highs/Mids Amp = Jensen 2 channel
    Sub Amp=
    Sub=
    Battery=(4) Stinger SPV70's
    Wire= 1/0 Hypeflex & 1/0 Knu
    All Connectors and fuseholders are Stinger
    Will Recone Subs for Free!!
