Results 1 to 3 of 3
Reload Thread: Need help deciding what to choose
    BassHead99's Avatar
    BassHead99 is offline Senior VIP Member
    Jul 2007
    Arkansas
    157
    Alright, i've already got an amp thats rated at 2000 at 1 ohm. Now I'm looking to upgrade from my other setup of 2 12" L7s. I would like to keep it under $500 as far as the subs go but I'm not sure what to get. I was thinking either 3 15" CVRs or 2 15" Type-Rs or maybe 2 15" CVXs. Which would you go with? Or if you can recommend any other 15s in the same price range that'd be great too.
    2001 Tahoe
    H/U: Pioneer Premier 490ib
    Subs: 2 12" L7s
    Sub amp: Power Acoustik 2400DB
    Box:~4 cubes, sealed
    Comps: stock
    Electrical: stock
    First system, with bigger and better things to come
    amartin_72's Avatar
    amartin_72 is offline Banned
    Nov 2005
    Madison , WI
    1,777
    Re: Need help deciding what to choose
    two sdc 15s for that amp
    KHARPS's Avatar
    KHARPS is offline CarAudio.com Veteran
    Jul 2008
    IL
    26
    3,332
    I think before you change subs you should try them ported first.
    REFERENCES
    cam5860, Godsmack, dropkick13, ls2poweredgoat, bunkerking09, ProjectPechkin, GavinVoy, kmanian, magnum21, natetate, gqjeff, mustangowner, ssackett, hazardous0388, Rusty...WCA, ohsosmooth, grassroots, Leister, Scott S, Pyro_by_Nature, teamsolo, jblcamry, pickup1, got_focus?, fasfocus00, Zellner, Goindef154, Darknight, orangelss, Thorshammer1, BigSix
