Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Reload Thread: bass boost=sub distortion?
  1. #16
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    The problem with bass boost is that usually when people tune the sub they tune the gains first.... usually to thier maximum levels (without audible distorstion) Then something clicks in thier mind.... what's this button do... so they turn up bass boost. To the average person it may sound LOUDER, but due to the lack of sensitivity to the untrained ear they may not notice the clipping / distortion. Bass boost can be a good thing if in the right hands but it is constantly abused. I personally never use bass boost because #1 i only have a choice between off @ 0db and on at 18db... that would definately cause clipping since my gains are above 75%-90%. And #2 It's already too loud i want to be able to hear just a little bit when i turn 30.
  2. #17
    LoneRanger's Avatar
    LoneRanger is offline Old Yamahas Give Me Wood
    Dec 2001
    Wellston, Ohio
    35
    1,379
    Re: bass boost=sub distortion?
    I don't use it....
    My head unit is a pioneer 6400, and it's eq is set at -3 low, +2 mid, +1 high
    My amp has a bass boost that's set to zero, and my crossover has two different bass boost and sub gain options that are both set to zero.
    I think the point of this function on most amps/eq's/crossovers is to give that extra bit of "unf" when your amp isn't quite powerful enough to drive the sub to it's fullest potential.
    As it has been stated several times, it usually drives your amp to make those ugly square waves, so avoid it unless you're really sure of what you're doing.
    "There is no 'I' in Tag Team"
    Project 'rex: Coming Soon to An Eardrum Near You
  3. #18
    joshpoints's Avatar
    joshpoints is offline CarAudio.com Veteran
    Jan 2003
    San Ma Tonga Central, CA
    34
    3,165
    1 Post(s)
    Re: Re: bass boost=sub distortion?
    Quote Originally Posted by LoneRanger
    I don't use it....
    But my particular amp is rated at 600 watts rms which should be enough for two 10" ed10k's. My gain is set below 5.5 volts, which is the sub preamp out from my deck. My amp is set for around 6.5-7v inputs and the sub level at the deck is turned way down from max. I'm running about to dashes below 1/2 of max. Now if I had the gain turned up for the 5.5 v preamp outs from the deck and turned the sub level at the deck up to max and then turned the bass boost on at all I say that I was abusing the speakers and would probably break them real soon.
  4. #19
    PeaveyBassist's Avatar
    PeaveyBassist is offline Senior VIP Member
    Aug 2003
    Columbus, IN
    30
    161
    I have an 8A with 300w in a 0.9 cubes tuned at 32Hz with bass boost at 40HZ (on hifonics zeus 5 channel) turned all the way up (+18dB) and I dont hear distortion. I use to have it around 9dB boost and boost it at 50hz with the HU, but now I leave the boost on the HU down most of the time, and leave the boost on the amp up all the way. It always sounds clean to me. Wouldnt it just act like a boost at 40hz on an EQ anyways? Or am I incorrect in the assumption?
    Will
  5. #20
    Wonderbread's Avatar
    Wonderbread is offline Against Avatar Theft
    Feb 2002
    Vancouver BC
    33
    5,152
    that's exactly what it is... a single band EQ... I explained that earlier.
    MSN - [email protected]
    Add me if you have any questions!
    Quote Originally Posted by PT Teal
    I woke up one morning and found a cop at my door telling me he found my car on fire in the middle of the desert.
    Quote Originally Posted by cleanerupper View Post
    Some people have told me that the chrome reflects sunlight, therefore the amp doesn't get as hot as others. Is this true?
  6. #21
    Aug 2003
    Columbus, IN
    30
    161
    So it wont nessescarily cause distortion correct?
    Will
  7. #22
    Feb 2002
    Vancouver BC
    33
    5,152
    correct. but it can.
  8. #23
    Aug 2003
    Columbus, IN
    30
    161
    ah ok. Thanks Im glad my 8A is still ok. I have had the boost up like that for a month at least, and its been perfectly fine. No signs of breakin or anything. I will prolly soon switch to a 2003 12k. Which should help with the low end as well as output with the same power
    Will
  9. #24
    Jul 2003
    In the medium of life
    31
    7,010
    178 Post(s)
    wouldnt bass boost be ok if you adjusted it BEFORE you adjusted your gains.so lets say ur bass boost is set to 18 and THEN you adjust your gains to be set.so therefore you wouldnt have a clipped signal right?cuz mine is at 12ish righ now and my sub is fine.i adjusted my gains AFTER i set the bass boost and its still fine.i have yet to sit down and fine tune it but whats its set to now is still loud as all hell
  10. #25
    Oct 2002
    Fort Meade, MD
    35
    873
    That should be fine like i said bass boost is fine as long as the signal is clear and non clipped. Some amps out there you can have your gains all the way up with a 18db bass boost and still be fine... but most arent that good... and it all depends on the signal being sent to it.
  11. #26
    neonak's Avatar
    neonak is offline CarAudio.com Elite
    Mar 2003
    The Netherlands
    39
    530
    21
    i have the one on my caliber filter set to + 24db and i posted a other thread that my subs stopped playing.. think i found the reason
    am affraid that spl will fall away without the boost
  12. #27
    Feb 2002
    Vancouver BC
    33
    5,152
    SPL should not drop significantly if your other settings are setup properly.
  13. #28
    neonak's Avatar
    Mar 2003
    The Netherlands
    39
    530
    21
    hey bread : u rule mkay?
    problem resolved, subs are stable now and im already addicted to their smell *lol*
    hit 144.9 with one box and 148.x (0 and 1) with two so gonna compete with one on sunday tnx mate
  14. #29
    Feb 2002
    Vancouver BC
    33
    5,152
    no problem...
  1. Bass Songs
    By flyasspimp in forum General Discussion
    Last Post: 08-22-2005, 11:54 PM
  2. remote bass control
    By DaBaller504 in forum Amplifiers
    Last Post: 08-19-2003, 01:59 PM
  3. speaker bass...
    By mm_55 in forum Speakers
    Last Post: 07-22-2003, 03:29 PM
  4. What the hell is the name of the bass test...
    By IowaBoomer in forum General Discussion
    Last Post: 07-15-2003, 03:22 PM
