Results 1 to 2 of 2
Reload Thread: Making a sealed box,need some suggestions
    adammk5's Avatar
    adammk5 is offline Senior VIP Member
    Jun 2003
    Houston, TX
    159
    I'm going to make a 3cuft sealed box,my 1.7cuft isn't cutting it because it's way too small for my 15" XXX
    1)should I use 3/4 or 1" mdf?
    2)do I seal the box with liquid nails then screw the wood together after the liquid nails dries?
    3)what should I brace it with?
    4)how to you guys keep the wood at the corner in a 90 degrees angle?
    sorry if there is so many questions but this is going to be my first box and I want to do it right.
    Rockford Fosgate 8250Ti
    Rockford Fosgate FNQ3614
    Rockford Fosgate 451s
    Hifonics Brutius 1500
    15" Resonant Engineering XXX(3.5 cubes tuned to 25hz)
    15" Elemental Desighns AE.22(1.7 Sealed)
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    Re: Making a sealed box,need some suggestions
    Quote Originally Posted by adammk5
    1. 3/4" is sufficient, if you can get the same airspace with 1", that's fine as well.
    2. The screws act as clamps ... so slap on the Liquid Nails, and put your screws in.
    3. I use 2x2's or 2x4's, just depends on what I have around the house. You can just screw two pieces of 1" together of you wanted.
    4. Well I use clamps and either clamp a square in each corner, or just use a square to check to make sure its good to go. Or you could measure from corner to corner to make sure you get the same measurment. If all of your cuts are correct, you should be fine. I'll usually screw the sides into the bottom and then the front and back, or vice versa ... seems to work out fine for me that way.
    Measure twice, cut once ... yeah ... do it, it works.
    Count your fingers. How many eyes can you see out of? Write the two numbers down. When you come back from building your box, ask yourself the two questions again, and write the two numbers down. You'll know if you've done something horribly wrong.
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
  1. Would 1 edO get loud in sealed?
    By NitroDuck in forum Subwoofers
    Last Post: 07-24-2003, 08:31 PM
  2. Need Dual 10" Sealed Box, please help
    By djs0lid in forum Enclosure Design & Construction Help
    Last Post: 07-14-2003, 05:20 PM
