Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 31 to 45 of 168
Reload Thread: Testing "SA-12" Prototype
  1. #31
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Testing "SA-12" Prototype
    Quote Originally Posted by Rashaddd View Post
    what are the specs on the box it did a 45 in? and thats off like 1800 watts right?
    About 2.5 cubes tuned in the mid 40s with way too much port for a 12" woofer *laughs*
    96 in^2 of port area -- this box is made for a 15" driver... a 15" Nightshade is 4 dB louder than a 12" Nightshade in this box on the same power.
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is [email protected]
    Simon Eichenberger is THE MAN.
  2. #32
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Quote Originally Posted by rumblebee2 View Post
    so pre-orders in about 90 days? i say i'm on the new "forum boner" bandwagon-lol
    That may be an okay estimate for a pre-order, yah.
    - Jacob Fuller
  3. #33
    jeremiah's Avatar
    jeremiah is offline edit me but not ****? ok?
    May 2006
    Canton Texas
    2,871
    Quote Originally Posted by sundownz View Post
    Depends on how you are on the volume. That is, what, 1500 watts at 2 ohms ?
    It seems very capable of taking that amount of power on music -- on sine waves it still seems to be okay as long as you are within mechanical limits. I wouldn't try to play a 1500-watt sine wave for an hour or anything, though.
    I say this because "music power" is far less than actual RMS power... I'll clamp mine on music to see exactly how much power I was seeing when driving home yesterday, it was more than fine during that time. The music I used yesterday for clamping was Bass Mekanik so WAS pretty much constant power.
    We are also extending x-mech in the motor to equal basket limitations - so it should be ever more resilient to short term bursts of musical dynamics!
    rumblebee2,
    We may do a pre-order once we get a good, solid ETA.
    kmanian,
    Me too! I have a few vehicles I'd love to put these in for friends and family Would also be a good candidate for a huge 4th order wall setup.
    I'm thinking 2 15's on 2300Wrms 1150W a sub 6.cu.ft @37HZ in a CRX for street beat try to get a ~148/150
    subs 1 18" MJ-18
    amps 1 A3000DB
    speakers memphis PR's
    HU some crape pioneer
  4. #34
    jbizzle's Avatar
    jbizzle is offline CarAudio.com Veteran
    Aug 2007
    Chicago, IL
    5,804
    10 Post(s)
    Looks great Jacob
    MW Car Audio - www.MWCarAudio.net
    Feedback Thead: http://www.caraudio.com/forums/buyer-seller-feedback/378649-jbizzle-feedback-thread.html
  5. #35
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    I found the only way to kill this sub within reason - bottoming it out. So, we are going to re-prototype with a few changes to make this a near impossibility (and a few other minor things):
    1) Adding 10mm to magnet stack
    2) Moving vent holes closer to the pole by 5mm
    3) Making the coil 5mm taller and increasing pole extension as well
    4) Creating a plastic spacer ring under the basket
    This makes total x-mech 33.75mm vs 26.25mm now.
    Keep in mind I had 1800 watts on tap too So it was already difficult to bottom out.
    - Jacob Fuller
  6. #36
    SocMunky's Avatar
    SocMunky is offline What happened in here?
    Nov 2006
    Crunktimes
    4,458
    1 Post(s)
    98 Post(s)
    Nice looking sub, goodness what a buncha xmax that is!
    Are you going to dress up the magnet a bit before production or leave it raw as is?
    "you have a face like a bulldog chewing a stinging nettle while taking a constipated dump in a heat wave"
  7. #37
    roarzorz's Avatar
    roarzorz is offline lulzorz
    Jun 2007
    vag
    2,574
    Quote Originally Posted by jeremiah View Post
    Lol. They're only 600watt subs. Everyone is already wanting to shove double rms power down their throats.
  8. #38
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Quote Originally Posted by Reson8 View Post
    Raw most likely - I suppose I could make a magnet boot but 99% of people will never see the back of the woofer again after installed.
    X-Mech is what I am talking about - the point at which the woofer can't physically move farther. The first prototype I've been testing has 16mm of linear x-max but was able to physically move 26.25mm and bottom out. I am making some changes for 18mm of linear x-max but 33.75mm before the coil can bottom out.
    - Jacob Fuller
  9. #39
    SocMunky's Avatar
    Nov 2006
    Crunktimes
    4,458
    1 Post(s)
    98 Post(s)
    Xmech is what I meant. I need more caffine.
  10. #40
    moh.vze.com's Avatar
    moh.vze.com is offline Registered User
    Jan 2007
    Oregon
    524
    I'd buy 2 of them for $350 shipped when it comes out
  11. #41
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    13,402
    68 Post(s)
    2 Thread(s)
    5545 Post(s)
    i like the woofer you got there.. simple nothing fancy... good parts good design nothing cheezy or flashy.... it is nice to have a sweet looking DC though. what you plan to change on this woofer?
  12. #42
    Dec 2006
    New orleans LA
    32
    13,402
    68 Post(s)
    2 Thread(s)
    5545 Post(s)
    16mm is about all you would need for 600 watts... a larger coil will just increase peak numbers...result is lower musical output raise dampning and be peakier unless you give it more power or plan to tune its really really low...none the less your a smart man and i sure anything you build will exceed expectations...
  13. #43
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Quote Originally Posted by papermaker View Post
    Just these things:
    1) Adding 10mm to magnet stack (for more x-mech primarily, FEA shows very slight increase in motor strength)
    2) Moving vent holes closer to the pole by 5mm (if the magnets are slightly off by even 1-2mm at current spacing they can block air flow, accounting for production tolerance)
    3) Making the coil 5mm taller and increasing pole extension as well (since I have so much rearward x-mech I want to make it harder to jump the coil forward too)
    4) Creating a plastic spacer ring under the basket (the pole was getting too close to the dust cap, it could potentially smack the cap with increased x-mech) - this is also why I used a bubble cap in the first place.
    Thanks for the comments I am pretty excited about it - the cap will be exactly the same except with "Sundown Audio" on it.
    - Jacob Fuller
  14. #44
    snoopysnooper's Avatar
    snoopysnooper is offline german engineering= fail
    Feb 2008
    Saratoga Springs, NY
    3,955
    2 Post(s)
    62 Post(s)
    Quote Originally Posted by moh.vze.com View Post
    um, i dont think you understand sonething, lol
    usually when a product comes new from the factory, its usually a "no haggle" type deal
    im pretty sure that he said 200 ea? so 400+ shipping will do it
    2006 dodge caravan
    2 15" tc sounds/tantric hybrid subs
    10 cubes at 28 hz
    massive p3k and 2 runs of 1/0 ga with a juice box black cherry battery
    refs: JaredSPL, oxsign (x2), SPY (x6 or 7), TheDukey42, SundownAudioNY, fearof85, donpisto, 97cavy, dylan1234, DBhittin, woofercooker, hemi= 22s, SMD4life, rumbleee2, ravens9322, terra, bryce-man and countless more
    100% on ebay, and hundreds of craigslist transactions
  15. #45
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    $200 is the MSRP.
    "Street price" pending.
    - Jacob Fuller
