Results 1 to 3 of 3
Reload Thread: Need More SPL. Takin' Suggestions.
    james33440's Avatar
    james33440 is offline CarAudio.com Elite
    Oct 2002
    FL
    36
    1,875
    I want more SPL. Check Sig for current setup. I was thinking of 4 10L7s ported with 2 KX1200.1's. However, space is an issue. The box that I am currently using is probably the largest I could use. It's 41"L x 16"H x 20"D. Also, I will probably sell one of my Kicker KX1200.1's to a friend of mine. Regardless, what other setups could I use to yield more SPL? Would 2 12L7s on one KX1200.1 in a little larger box tuned higher with a larger port work? Should I go with 15L7s? Any suggestions would be helpful and I would be very appreciative. Thanks.
    2001 Altima System:
    Alpine CDA-9855 (3Way Mode)
    Kicker Resolution RS6 Components (Active Setup)
    CDT Tweeter Image Enhancement Kit
    3 Ascendant Audio Arsenal 12's (Sealed)
    Kicker KX650.4
    Kicker KX1200.1 @ 0.67-ohm
    My Video Thread
    My CarDomain Rides
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    36
    8,044
    yo man hit soundsunlimited up. he's got a pair of subs that he'll sell you for a good price if you tell him bumpin_blazer sent you. 2.1ohm subs will take that 3kw with smiles on their face and need about as big a box as you can fit. if that is internal it's 7.6cuft roughly and that's enough room for em port em to 56hz ish and slam out some higher #'s. i had them the 12" compared to a prototype L7 15".
    adam
    2006 Bright Island Blue 6s: stock 6 disc in dash, Hertz Hi-Energy 6.5" comps, MB Quart Ref 12", eclipse 5-channel sub amp.
    Car mods: Lowered on Mazdaspeed springs with Koni Yellow shocks, Racing beat front/rear sway bars with AWR end links, LED turn signals, tail lights, front side markers, 18" ADR Cypher rims, 55w HID's in low beam and fogs, 5% tint all the way around. No go fast mods yet...tuning and Mazda6 don't go well together .
    Steve a.k.a. ss3079: So this one lady goes, "These ignorant people who drive around blasting there music, they cant hear emergency vehicles"
    So that set me off, and I said "Well then why do they let deaf people drive?"
    AOL: JmKeenen
    nswartley's Avatar
    nswartley is offline Down and out...
    Nov 2002
    (Near) San Jose, CA
    31
    5,879
    tune your box higher...up around 45hz would be good. you can go even higher if you want. what you have it tuned to right now is kind of a SQL application.
    -nate
